Has anyone don't any type of testing of performance or gas milage changes removing the half screen between the throttle body and the intake manifold? I was wondering if this was the most restrictive point of the intake after installing a cold air intake and a cat back exhaust system to free up the air flow. I asked the dealer about it, but they seemed to feel that the screen was to straighten out air flow. I was wondering if anyone has removed the screen from the rubber O-ring gasket and what they experienced doing this.
People are removing it in conjunction with a Throttle Body Spacer. The screen kind of fights what a TBS is supposed to do by straightening out the air flow.
I don't recall anyone without a TBS cutting the screen out.
2006 SE Crew Cab, Big Tow, Traction Package, SE Popular Package...mods....yup...and they seem to work well together! UpRev Osiris now installed!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Horsepower Sells Cars, Torque Wins Races!
Actually, several people did it a while back. I know the head gr8titan, and a few others that I can't remember right now did it.
They did this without adding the TBS.
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD
**SOLD
SOLD **2005 Titan XE KC w/ Preferred Package BLACK **SOLD
OK, some have and some haven't taken it out, so if u have or not have the TBS and cut it out, has it helped? Does it set off the CEL? Is there any real harm even in taking it out, even without a CAI?
Radiant Silver '06 Titan SE CC 4X4 w/BT&OR w/ ATS Fender Flares
PC 6" lift w/ PRG A arms & traction bars, SAW's front/rear combo & Deaver pack
34" Nitto Terra Grappler's on 17" Helo Maxx 6's
Volant CAI, PowerAid TBS, Flowmaster 40
DECEPTICON center grill, SS Hood Deflector & Chrome Truck Nutz
i took it out, i dont think there is any real benefit.. it dont look that restrictive as the holse are at least 1/8'' and it only goes in the top half of the TB... i took it out because i heard something about it and i did it in my s-10 extreme.. the s-10 one was in the maf and extremely (no pun intended) restrictive... didnt know what the one in the titan looked like.. i wouldnt do it now knowing what i do but if i was going to put a TBS in i would remove it... just be careful... use the proper allen head they are metric remember.. and they are tight, and youll need a good set of cutters, my snap-ons barely got through the metal without bending the metal in the rubber,, but if it does bend jsut straighten it out and it will seal good, so far no probs and its been 1000 miles.... any other questions let me know....
i think the airbox snorkel is the most restrictive part of the intake.. the part in the box needs to be removed and then it will flow just as good as any aftermarket kit with i drop-in ( i have nothing to back it up as i know someone will attack this statement) but the tube that actually goes through the fender is plenty big enough and the rest is bigger than the throttle body itself, and there are no sharp bends (with the exception of the snorkel inside the box) but with that removed viola.. free flowing...
maybe mine was different because i took the throttle body off and there was no way to remove the screen from the o-ring/gasket without cutting it....
That's what I found as well. I installed a TBS yesterday, and I cut out the screen with my dremel. It was very easy, I just had to go slow to make sure I didn't slip and cut the ring itself. Looking at it, there was no other way to get it out on mine without cutting.
To answer the original post, I have heard it is best to leave it in with the stock throttle body, and remove it with a TBS, since the screen counteracts the swirl produced by the TBS.
