Re: tail gate HELP
Bigger screws should work, the parts inside the tailgate that the screws is attached to is also plastic. I suspect instead of using a hand held screw driver he use a electric drill or similar. It don't take much to strip them plastic piece. Just fill in the hole with epoxy or other type filler/glue wait till it dry and rescrew using your hand not cordless drill. I did this after stripping two of the hole also.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
