Old 08-17-2006, 03:33 PM   #1 (permalink)
Yellomantis's Avatar
True dual exhaust. Worth it???
Tell me guys, is all the trouble of going to a true dual 2.5" exhaust worth it? Or am I better off with a single 3"? I plan on using supertrapp mufflers and dumping them in front of the passenger rear tire.
I am planning on going supercharged eventually, when an alternative to the stillen kit comes out. I like centrifugal chargers.
So that being said, would a dual 3" be better? I want to get the exhaust done first so I won't have to re-do it later. I am stead fast on the supertrapps because I like the adjustability for backpressure/sound. I can tune it down for when I have to drive someplace that frowns on loud exhausts and open it up in places that don't care. Not to mention that they qualify as forrestry service spark arresters. Need those on some trails here in cali.
Thanx guys!
Casey
www.myspace.com/yellomantis
Old 08-17-2006, 03:40 PM   #2 (permalink)
CVTITAN's Avatar
Re: True dual exhaust. Worth it???
My opinion only for the looks. You can get same sound and performance from a single. Besides if you dont have an H-pipe, Y-pipe or X-pipe there goes you power. And I know Im in trouble with that being said...lol Let the attack begin.
CVTITAN is offline   Reply With Quote
Old 08-17-2006, 05:55 PM   #3 (permalink)
On a true dual exhaust, some sort of x pipe or h pipe is a must so it will have the "scavenging" effect. Otherwise it will be like two bangers fighting each other.
Old 08-17-2006, 06:33 PM   #4 (permalink)
gr8titan's Avatar
It's a personal preference depending upon the school of thought someone believes in.
Some say that you need back pressure so you do not lose low end torque, however, my "personal experience" indicates otherwise. My documented 0-60ft is 2.1 seconds. I still have to read someone with a stock exhaust claim better launches than 2.1 secs.
The 3" Monster Banks has very good documented exhaust flows and significant reduction of back pressure compared to Titan stock exhaust. Click here for some comparative (bottom of page) flow rates between the 3" Single Monster Banks VS 2.5" True-duals. The 2 x 2.5" has a very "insignificant" advantage. It is a toss-up. It's your preference.
The link also describes why the x-pipe (or H) is important in a dual system and some basic Exhaust 101 principles/theories.
gr8titan is offline   Reply With Quote
Old 08-17-2006, 06:40 PM   #5 (permalink)
markislive78's Avatar
Check it out the experts say dual 3'' will kill low end....I hear a single 3'' is good for 400hp and a dual 2.5'' is good for 450hp while still maintaining some backpressure to preserve low end...
http://www.pypesexhaust.com/faq.html
markislive78 is offline   Reply With Quote
Old 08-17-2006, 06:53 PM   #6 (permalink)
Thats just it. I want to eclipse the 500 whp mark with an alternate s/c when it comes out. Probably a combo with NOS. And with the supertrapps I can preserve the back pressure until I get the "other" s/c.
Old 08-17-2006, 07:18 PM   #7 (permalink)
Lemme say this on the Magnaflow I just installed. Mine is shown in the forum and is labeled Magnaflow Installed. The single input and dual output from the muffler in this installation is loud when goosed and really has no drone at a cruise. With the Volant CAI and the Magnaflow, I have increased horses thru the range. This is noted in medium and hard throttle. I venture to say that I have gained 20-25 HP.
Born: 2/24/2005 Christened 3/18/2005: TomaSmoke
2005 Smoke Titan KC 4X2 LE
18 X 8" alloy wheels, 265 X 70R18 OWL
Chrome Grille, Mirrors, Handles and Rear Bumper
Leather, 350W Rockford Fosgate Audio
AM/FM/6CD, Captains Chair Package
Fogs, 12V power points, Big Tow package
Volant CAI, Magnaflow Cat-Back Duals, 2* Timing Advance
TomaHawk is offline   Reply With Quote
Old 08-17-2006, 08:16 PM   #8 (permalink)
gr8titan's Avatar
Titan OEM exhaust has 3.55 psi back pressure
1x3" Monster Banks measured 0.275 psi back pressure good up to 400 HP
2x2.5" True dual = 0.110 psi good up to 450 HP
If you have great plans in the future for your motor, plan wisely ahead.
Do it correctly once now or do it twice later.
Old 08-17-2006, 08:29 PM   #9 (permalink)
Exactly why I have posted this.
Old 08-17-2006, 09:43 PM   #10 (permalink)
kartman's Avatar
My dual 2.5 with H pipe works great.
Rebar Wrangler
Old 08-19-2006, 08:44 AM   #11 (permalink)
kartman you have a dyno?
Old 10-24-2007, 09:44 AM   #12 (permalink)
I have a question i was told my only choice for my 07 titan would be true duals do know if thats true.
Thanks
plunge is offline   Reply With Quote
Old 10-28-2007, 03:14 PM   #13 (permalink)
kartman's Avatar
Thanks
false .
Rebar Wrangler
Old 11-04-2007, 08:45 PM   #14 (permalink)
sligsta's Avatar
The NISMO exhaust is a true dual setup I believe. From what I can tell it's new and I don't know if anyone on here has it yet.
sligsta is offline   Reply With Quote
Old 11-05-2007, 11:34 AM   #15 (permalink)
EVO8's Avatar
Yellowmantis, if your going for seriouse power like 500whp, then I suggest going with at least 3" tubeing. That way, you don't lose too much low end but get the benefits of all the top end. I would also suggest that you don't go the duel route either. For that type of power, the straightest pipes with no resonators are what you are looking for. With running a supercharger, I don't think you have a problem with low end anyways, as superchargers produce enough power from idle on.
2006 Titan XE 4x4 (PRG 4" Performance package)
2003 Evolution VIII (358awhp/354awtq) that's on 91octane,stock boost, stock turbo.
2007 GSXR1000 (not enough road to touch redline)
"Dream as if you'll live forever, live as if you'll die tommorow" : James Dean.
EVO8 is offline   Reply With Quote
Magnaflow True Dual Exhaust Installed 1bigtexastitan Titan Performance Modifications 8 12-03-2005 01:44 AM
True dual exhaust update. 04TitanXECC Titan Performance Modifications 1 05-02-2005 04:57 PM
New SS True Dual exhaust installed gr8titan Titan General Discussion 55 04-22-2005 01:56 PM
Just Installed A True Dual Borla Exhaust!!!! NOLA TITAN Titan General Discussion 3 03-14-2005 07:14 PM
