Re: What does a a 2 degree timing advance and a Poweraid throttle body spacer do????????
UPDATE: According to Cipher and some other data logging it shows the voltage at the Throttle Body decreasing near redline.
Well finally someone created a homemade CAI with a camera installed to watch the TB plate through a wide open throttle run.
It did show the TB flutter at shift but not enough to hurt performance a measureable amount.
So it does close.....but just for a quick instance and then it's wide open again. So companies like Technosquare that raves about fixing the TB problem is just feeding off our data logging fears.
The Titan has four cams built for low end torque. Now what we need is a programmer that can alter the TCM and bring the shift points of this truck down so it shifts at approx. 5300 rpms to keep the truck runing within it's cammed power range.
If this truck got a good quick shift at 5200-5300 rpms it should bring down 1/4 mile times a good bit.
2006 SE Crew Cab, Big Tow, Traction Package, SE Popular Package...mods....yup...and they seem to work well together! UpRev Osiris now installed!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Horsepower Sells Cars, Torque Wins Races!
