thanks for the info and pics gr8titan......
did you notice any marked increase in power or economy after installing the ram air in your titan?
also, i was wondering if you put any water drain in the ram air, or is it up high enough you think that it's not required.
now i wonder to myself, to go around the radiator like you did, or come from the top with a scoop down into the top of the volant box....... i guess the fabrication would be a bit easier around the radiator, but im not sure if thats the most efficient way to do it....taking bernoulis principle into account.
thanks again for any info you can help me out with.....
