Old 09-15-2006, 02:31 AM   #46 (permalink)
Banned
Re: Stock Y pipe junction NOT a good design
just did the +2 timing on my banks/cai and got back my low end. truck now feels like its on steriods.
this completely blows away stock, no dynos, just seat of the pants feel.
noticed an increase in temp, but still below the half way mark on the temp gauge.
damn this thing is awesome now. even feels smoother with the +2, and tranny doesnt downshift as much as it did without the +2. thanks guys for all the tips!
mecedesboy is offline   Reply With Quote
Old 09-15-2006, 05:42 AM   #47 (permalink)
Blackbeauty's Avatar
Do you have a handle on your average fuel economy before doing this? Keep an eye on that and let us know if you see much difference. Then again, you may be too busy using the right pedal to worry about fuel mileage! LOL!!
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 09-15-2006, 01:26 PM   #48 (permalink)
Banned
step 1, cai only: exhaust temp went up a bit, slight loss of low end, mpg slightly less.
step 2, TBS added: low end returned, mpg improved
step 3, Banks installed: exhaust temp dropped almost back to stock(cooler), mpg slightly worse because motor had to perform at about 100 rpm higher to reach the low end power, but on level ground, mpg seemed to improve because tranny would stay in lower gear. otherwise tranny would downshift earlier than in step 2.
step 4, +2 advance added: temp went back up a bit, about 10-15 degrees F,
good low end is back and feeling smoother, mpg improved because higher rpm not needed.
question: dealer claims that +2 will cause motor to run leaner. is this because fuel is burnt ealier in the stroke leaving less fuel remainding for the normal part of the stroke of the piston?
is this harmful in the long run, and can raised temp be due partly to this?
thanks!
Old 09-16-2006, 11:09 AM   #49 (permalink)
gr8titan's Avatar
Originally Posted by Blown330
Anyone have any timeslips of a direct before and after with just the exaust system changed? Dyno's are tuning tools first and foremost....not something to be trusted as much for hp/tq figures over any period of time.
Though I can't speak for other owners with larger diameter exhausts, I personally gained power accross the RPM band.
0-60 ft decreased from 2.3 to 2.1 seconds
Trap speed increased from 87 to 90.6 mph.
ET improved from 15.5 to 15.0 seconds.
If you're interested in more timeslips, Dragtimes has data of tabulated timeslips voluntarily submitted by members. It also list their mods including what type of exhaust they're running. Interesting data.
gr8titan is offline   Reply With Quote
Old 09-21-2006, 11:22 AM   #50 (permalink)
BRACEYOSELF777's Avatar
After reading all this I'm considering that I should but a new Y-pipe...why? Just because of the gains across the bands. The stock Y-pipe is good if you gonna Tow stuff or haul big loads. It keeps the low tourqe band the TITAN is good for. But for us speed junkies...we don't really tow....or we occasionally tow a load.....so low end tourqe isn't much of a big issue....all we want is more power...thats where the new Y-pipe will come in. Considering my options....any suggestions on what Y-pipe I should get?
2006 Nissan TITAN XE KC. Totaled 11-13-2008. REST IN PEACE.
BRACEYOSELF777 is offline   Reply With Quote
Old 12-03-2006, 08:07 PM   #51 (permalink)
AgTitan06's Avatar
agreed. I am glad I got the Volant with the slightly larger y-pipe. I feel there is gains all across the board with it. They also included an additional pipe and clamp if I wanted to keep the stock y-pipe.
Old 12-04-2006, 08:34 AM   #52 (permalink)
EVO8's Avatar
Originally Posted by Matchgrade
By going with a better flowing (bigger) Y-pipe you should make more torque, but it will be higher in the powerband (at a higher rpm). This will help with high speed runs or even drag racing (especially with the trans and gears that the Titan has). What will be lost is the higher torque numbers in the lower rpm range. This hurts the guy pulling his 6500 lb. trailer at the 2000 to 2500 rpm range. He will have to rev the engine higher to get to the same towing torque that they used to have with the smaller Y-pipe.
More dramatic changes can be seen when changing size and length of headers and intake runners. Thats when going bigger could not only move the torque curve, but also raise HP at the cost of peak torque numbers.
If you want to go fast, go big. If you want to pull well, stay small.
Believe this man. He knows what he is talking about. Less back pressure are great for turbocharged vehicles but in this case we are talking about a N/A vehicle. If you go big you will loss torque down low to mid but will gain it in the upper rpm. People go big because they want to drag race and need that big surge of power in the upper rpms when shifting.
2006 Titan XE 4x4 (PRG 4" Performance package)
2003 Evolution VIII (358awhp/354awtq) that's on 91octane,stock boost, stock turbo.
2007 GSXR1000 (not enough road to touch redline)
"Dream as if you'll live forever, live as if you'll die tommorow" : James Dean.
EVO8 is offline   Reply With Quote
Old 12-04-2006, 08:40 AM   #53 (permalink)
EVO8's Avatar
For you drag racers out there, this would be a good idea but if I was going this route, I would also do the headers at the same time too.
Old 12-04-2006, 08:59 AM   #54 (permalink)
Send a message via MSN to Toomnymods Send a message via Yahoo to Toomnymods
that nasty stock y pipe was gone within the first 2 months of owning the truck, just looking at it it's amazing the truck moves at all,lol restricting the airflow down that much can't be good for the motor in my eyes, let her breathe!!
05' Blizzard White 4X2 KC SE
Foose Speedster 6 22's /w Nitto 420-S 305-40R-22, Hoosier Pro 28x11.50x16 Slicks, McGaughy 2/3" drop kit, Jim wolf Technologies Camshafts, IPT 3400 RPM TQ converter, IPT Valvebody, IPT Built Tranny, AEM Bruteforce CAI, NX Express Import WET kit 125 shot, Stillen Longtube headers, Dynatech 2.5" Powercats, JBA Evol catback, Detroit TruTrac LSD, Flex-A-Lite electric fan conversion kit #295, AirRaid Throttle body spacer, TB Coolant By-pass mod, Line-x spray in bedliner, Trenz 3 Piece framed perimeter billet grille /w matching bumper billet insert, Chrome tailgate cover /w handle, MCulloch HID 6K lows and fogs, Altezza Chrome taillights
BEST 1/4 Times
12.929 @ 103.28 NA FMP 7/18/08
12.8591 @ 106.74 (125 shot) 3/2/08 FMP Before IPT tranny
Dynotech Dyno SAE #'s
N/A Map 330.12 RWHP / 367.59TQ in 96F heat
N20 Map = 430 RWHP / 515TQ
UpRev ECU Tuning!!
Toomnymods is offline   Reply With Quote
Does anyone have a sub box design? Useless_2_get_id Titan Visual & Audio Discussion 10 02-17-2006 08:06 AM
stock exhaust pipe size 04SECC Titan Performance Modifications 2 02-08-2006 01:05 PM
stock 17" BFG's - any good in snow? C4RACER Titan General Discussion 13 12-25-2005 07:32 PM
Stock tires any good? destro Titan Wheels, Tires & Brakes 5 08-27-2005 09:40 AM
Sub Box design HELP!! RFosgate Titan Interior Discussion 5 08-25-2004 10:04 AM
