I'm thinking about having a new exhaust and intake installed. However, I'm not doing it for the sound. I like the stock sound. Just enough rumble without it being overbearing. I want the performance enhancement. But, I want a quiet setup.
I also want to include a bigger Y in the exhaust as well.
Recommendations?
It's not rocket surgery.
'06 CC 4X4 SE Born Oct. 05
Big Tow
Eclipse GPS Navigation/DVD/CD (Dealer Option)
Smoke
World's fastest beer cooler (see photo gallery for explanation)
You wont find a quite exhaust system. You will have to have one custom made. If you don't mind a little rumble the JBA Evol is great. And a quite intake with good response would be an AirAid quickfit.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
My Zoomers are just a little louder than the stock pipe and that is what I wanted. Not loud! I also have no drone inside the truck from the zoomers either. My volant intake on the otherhand increased the loudness 2 fold.
Some people like just swapping out the muffler and use the stock pipes and others like a whole exhaust system swap. There is a sticky posted on another titan site that covers almost all of the exhaust systems except the banks which is the loudest. I've pasted it below:
I know that there are many peole on here who know more about exhausts than I do as far as the technical stuff. But, in the last two months I have done around 40 dynos with many different combinations of modifications and exhausts. The systems that I have had include the following now:
1) Full Stock set-up with 22" magnaflow muffler
2) Magnaflow Catback
3) Gibson swept side
4) Borla Dual
5) Flowmaster 40 series
6) Flowmaster 70 series
7) JBA single exit
I will provide what I observed during the whole process to try and help others determine what is best for their needs. When I mention drone, I am extremely sensitive to the frequency that exhaust emits. So your level of hearing may be different than mine.
1) The full stock set up with the 22" magnaflow provided great numbers. The hp and torque increase from stock was 8 and 14. Sound was a little louder than stock and there was noticeable drone to me at 58 to 62 mph. Bang for your buck can not be beat here. Once again I ONLY changed out the muffler.
2) Maganflow catback single exit provided the best gain period with the STOCK titan. The numbers on the website of 18 and 22 were factual peak to peak numbers. Not a play on numbers like many manufacturers do and show how much you gained at a certain rpm when you actually gained on 2 or 3 peak horsies. One odd thing that needs to be realized with this set up is it uses the STOCK Y-PIPE. I tried this set up with a custom 3 1/2" Y-pipe and lost a lot of torque. drone once again, is pretty noticeable at speeds mentioned above.
3) Gibson Swept Side is in my opinion a great all around exhaust for a couple of reasons. One it does provide medium gains in hp and torque. But two it has a great sound with almost no drone. It is louder than stock at WOT, but at start up it is just a deep tone that sounds great. But if you want something that is loud and mean, this is not for you.
4) Borla dual. It sounds really good to me. Cruising speeds had no drone, drone was only around 45 mph. the gains in hp were comparable to the gibson (12), but the toque gain was very minimal. But it is a very clean sounding exhaust that will please MANY and the finished look is very nice.
5) Flowmaster 40 series did not stay on for an entire day. Drone felt like my head was going to cave in. I greatly apologize for not being able to tolerate it to give a full evaluation, but the drone was heavy between 40 and 70 mph to me. And that is where I drive 90 percent of the time.
6) Flowmaster 70 series. Very good sound. Not to loud, drone was minimal around 1600 rpms. Provided nice hp gains that were equivalent to Gibosn and Borla, but once again the torque gain was very minimal. This exhaust at wot was definitely able to turn some heads with its volume and I did notice a couple of pops after going WOT and then letting completely off the gas. So it performs like the Gibson and Borla but has a little more agressive sound than both of them.
7) The JBA provided the best gains AFTER the header install. I do not have perforamnce numbers with the stock exhaust manifold, because I purchased this system AFTER headers. Previously the Magnaflow had the top gains hands down, but after the headers, this one etched out on top by 4 hp and 6 pounds of torque. I think that JBA did a good job matching their systems up. One thing that is interesting though is the muffler that came with it was a K & N muffler. The Y-pipe is smaller than ALL OTHER catback systems at 2.5"...EXCEPT where the bend in the tubing is and at the Y. The bend in the tubing on the drivers side expands to a little under 3" and then shrinks back down and it seems to act like a velocity channel. And the Y has two 2.5" pipes that come together to a 3" collector. There is some drone at 1600 rpms does not matter the speed, but it is definitely tolerable to me. This is a fairly loud agressive exhaust but is still not up with the Flowmasters or Bnaks.
So one conclusion that I was able to come to is that the 5.6 loves back pressure. That is where the low end torque comes from as does the max torque. It is funny that the 3 systems that produced the best numbers (hp and torque) used the smallest diameter Y-pipe and 2 of those were with the STOCK Y-PIPE and the other has the same diamter as the stock y-pipe. The dual systems lost speed in the lower range (below 40 mph) and I am convinced that is because of the minimal torque gains and I believe loss of back pressure. So if you want pure sound, the duals are the way to go. But if you want performance, the single exits with the smaller Y-pipe proved to be the best.
I will also be installing and dynoing the bassani system soon. I know that they are big into vette's, but I heard one on a friends Z06 and it had a great sound and provided pretty good gains on his vette.
Now please do not start writing in and bashing me because of my findings. All of this was done on the dyno and the on road findings were times with a Bel FX2 and my ears. Times can be affected by humidity, temperature and wind.
Alot of people have tried to bash the JBA, but I have stood my ground and backed it up. I love mine and would put it on all over again. I would love to have the headers. How much hp/tq did the JBA combo give?
Mods to date:
If you read it again it says "came out on top after header install by 4hp and 6 lbs trq". It doesn't say the exact measurement. That is what I was wondering about. Why didn't you just post it instead of making it an arguement?
Mods to date:
After reading three times, it looks like JBA gained 22hp and 28 tq. You could have stated that in your post to make it easier for all of us, but thanks for all your R&D.
__________________ Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY BLUE LED DASH LIGHTS MOD[COLOR="Green"]1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 485,000 miles and I'm hoping to get 500,000.[/color]
Just my opinion if your looking into headers look at the long tubes, keeping in mind what other mods you might be doing, supercharger, chips " when available".
4x4LE:SUPERCHARGED:HEADERS:CUSTOM INTAKE:CUSTOM RACE EXHAUST:LIFT KIT:&HIGH PERFORMANCE MODS TO BE RELEASED SOON',STAY TUNED!!!
I’d stay with a single 3'' out bottle neck to maintain some low end......I would also make sure the system replaces stock y-pipe if you plan on headers or higher output...then choose by sound taste! I've owned 3 diff exhaust since adding headers; Banks, 2.5'' mandrel bent duals w/x-pipe and JBA Evol....I like my JBA compared to banks much milder tone and costs less....From a design I would have to give JBA the nod also due to the 2.25'' to 3'' Y-pipe...higher exhaust velocity yields more TQ. (2) 2.25 will still outflow a single 3'' so don’t be worried about the smaller y-pipe.
Just my .02 cents
i've heard that tanabe goes for quiet power but i dont no if they make a titan setup. i dont think so they are more of a import tuner company. but the tian is japanese so hope that helps you out.
I didn't do the work, I listed that it's from another titan site as a sticky and I pasted it. The reason I didn't quote the figures is that I just dislike when people ask what something because they're not willing to read the whole post. If the magnaflow was 18 and 22 and the jba beat it by 4 and 6 then....
