Update on DIY airbox mod and Amsoil Eaa-104 air filter.
Today I wanted to see how the Amsoil air filter was holding up compared to the OEM filter. Each filter was in for about the same time, that being about 4.5 months each and 2300 miles each. The OEM paper filter was in before the airbox mod and the Amsoil shortly after the mod. The pictures clearly show the difference in air travel. It is very hard to see in the pic, but the Amsoil filter has a slightly darkened center, where the OEM, before the snorkel mod, was dirty only on the bottom corners. Actually I'm shocked at how clean the Amsoil filter looked tonight. Oh, I did the snorkel mod with a red hot knife back in May.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.660@93.14 MPH running BD reg 87 tune +2 timing and DA@1830' in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Re: Update on DIY airbox mod and Amsoil Eaa-104 air filter.
I did the samething, but I first used the K&N filter. I just put in the Amsoil filter and now see how it works compared to the K&N far as airflow and performance. I didnt use a hot knife, I used a bandsaw at my old job-aircraft mechanic.
2008 SE CC 4X4 RED BRAWN w/popular package, Big tow, Bed utility w/bed extender, Fog lights and back up sensors, Homelink
MODS:
Sirius
TomTom GPS
DIY Intake Mod w/Amsoil EAa104 filter
Activetune Grounding Kit Red wires
Magnaflow Cat-Back
Silverstars
Luminics Pure Blue 6000k fog lights bulbs
Nissan Steprails
2* Timing
Nissan Bug Shield
OEM Weather Floor mats
Armada Airdam mod
I did all this without wife knowing
In your first pic I cut the tube at an angle upwards
MODS:
Sirius
TomTom GPS
Magnaflow Cat-Back
Silverstars
Nissan Steprails
2* Timing
Nissan Bug Shield
Armada Airdam mod
"A veteran is someone who, at one point in his life wrote a blank check made payable to "The United States of America" for an amount of "up to and including my life." That is Honor, and there are way too many people in this country who no longer understand it."
The red hot knife worked well, under 15 minutes. You don't have to disassemble anything. It was all done with the box still mounted in place.
You probably won't be able to tell much of a difference. If there is a gain, it's minimal. If your check engine light isn't on then you probably don't need to reset your ecu.
Boy he gave me a hell of a frisk, he was firm, but incredibly respectful at the same time. You guys are pros.
Originally Posted by MississippiTitan
Well I couldnt tell a difference with air filter. Should I do the ECU reset?
The gains are minimal but present. Were you expecting gains like a super charger?
Originally Posted by Jery t
I know I am stupid, but what is red hot knife? A super heated knife or a tool? I thought about a cut off tool or dremel??
Just an ordinary kitchen knife that you heat till it's red hot.
Tonight I pulled the Amsoil filter out to clean it with a vacuum since it has been in for 10 months. It still looks new, but vacuumed it anyway. I took a pic before I cleaned it. With the airbox mod, you can easily see how well distributed the airflow is.
