Old 11-20-2006, 07:16 AM   #1 (permalink)
goval's Avatar
Adding another battery. I need help.
I have no idea on the issue, but I'm currently running a 700 and a 150amp amplifier, with 2 off road lights on my brush guard. Soon I'll be adding another off road light on the grill, and also 4 driving lights on my roof.
I definitely need to replace my battery with a bigger one, change the alternator, or add another battery. What I really want to do is add another battery just for the lights, and leave the amps on the factory battery since they don't require a lot of voltage.
When I put my truck on idle with the lights on, I can see the meter drop, but only at iddle. Figure all the stuff running at the same time is too much for the factory battery.
Anyone can help me on this? I need how-to, diagrams, anything that would help on adding another battery.
07 Charger 3.5.
-Anderson B.
goval is offline   Reply With Quote
Old 11-20-2006, 07:35 AM   #2 (permalink)
pi3yeargrad's Avatar
Re: Adding another battery. I need help.
shoot, this would help me also... my damn battery keeps dieing... Ima need another battery I think as well...
Im running a 150 watt amp and will be running a 700 watt amp as well...then I got 2 pairs of HIDs, my headrest monitors, my in dash monitors, my PIAAs up front... my battery SUX!!! it died with me puttin gas dude... I was puttin gas this weekend with the door open when I finished it wouldnt turn on... I was PISSED... had a friend haul over and give me cables...lol..then this morning coming to work, it wouldnt start either...
Im thinkin optima, but I dunno...im also thinkin another alternator, but I dunno... how would this 2 battery thing work?
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 11-20-2006, 08:03 AM   #3 (permalink)
goval's Avatar
Someone at the other forum suggested going to a bigger alternator, with more output. But I cannot find one that will fit our trucks.
07 Charger 3.5.
-Anderson B.
Old 11-20-2006, 08:26 AM   #4 (permalink)
i<3mytitan's Avatar
Send a message via AIM to i<3mytitan
PM Rcantu, he's added BOTH a new alternator and a battery.
No more sig for me
i<3mytitan is offline   Reply With Quote
Old 11-20-2006, 08:49 AM   #5 (permalink)
ye they advised me to contact iraggi...do a google and ull find em...
they run about 500 + bucks...
Old 11-20-2006, 10:37 AM   #6 (permalink)
If you want to make sure you can start the truck, I think you need to use an isolator with the second battery. Otherwise you can just end up with two dead batteries.
Old 11-20-2006, 11:00 AM   #7 (permalink)
Thrust_Titan's Avatar
These Powermaster battery isolators are designed to separate the auxiliary battery from the starting battery, to ensure that extra loads will not drain the starting battery. They feature blue anodized aluminum heat sinks for maximum heat dissipation. The battery isolators are available in a 3 or 4-post design, and will work on alternators with up to 200 amp outputs.
http://store.summitracing.com/partde...5&autoview=sku
Share the wealth of knowledge and go as fast as you can.
IRC Member "International Racers Club VK56"
TESTING: GTech/Pro RR, AutoTap, Auto Enginuity Enhanced, UpRev, Audio Spectrum Analyzer for Knock Sensors Monitoring, HP nx9420 Notebook PC T7700, Sprint Mobile Broadband
MODS: Custom PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, Custom Throttle Body Intercooler, Custom Ram Air, Custom 160 degrees Thermostat, Custom CAI, Nismo Headers, Custom B-Pipe NO Cats in line and NO Simulator without CODES (LOL), Custom MagnaFlow Exhaust, Custom Tune, Flex-a-Lite 27 Electric Puller Fan #295, Jim Wolf Technologies Camshafts, Detroit TruTrac LSD.
Thrust_Titan is offline   Reply With Quote
Old 11-20-2006, 11:02 AM   #8 (permalink)
Kronos1965's Avatar
I recommend an Optima Yellow Tops to drive both your truck and your goodies.
I think Titanblue may have some experience with alternators and has previously posted on the topic.
As far as an upgraded alternator, aren't you already possessing one that is 136 amps?
Kronos1965 is online now   Reply With Quote
Old 11-20-2006, 11:06 AM   #9 (permalink)
The problem is that it doesn't make 136 amps at idle. As a result, a high powered stereo will discharge the battery even with the engine running.
Old 11-20-2006, 11:07 AM   #10 (permalink)
CVTITAN's Avatar
I agree with Thrust Titan. this would be the least expensive and easiest way to go. I was thinking of going this way as well.
BIG WHITE TRUCK...
CVTITAN is offline   Reply With Quote
Old 11-20-2006, 01:04 PM   #11 (permalink)
TitanBlue's Avatar
It is safer to have an isolater to prevent being caught dead, it just depends on how you use (manage) your system. 2 batteries (or more) can be be run in parallel without an isolator. It is common on diesels, small and especially large trucks. Both batteries always share the load. No significant increased load on alternator, to maintain 1 vs 2 batteries. I've increased 2 of our Internationals from 2 to 3 batteries, simply because there was already room in the box, and it saves wear on the starter in cold weather. Battery is cheaper than wasted labor cost.
If buying an isolator, go to mfg website and carefully choose proper size, as too heavy of an isolater will cause poblems too. IIRC, don't go below 60-75 % of isolaters capacity, or go over its capacity either, of course. I hope to install 2 batteries in bed (or underbed) and just run in parallel. I am installing a 1200 Watt invertor, additional lights, but no high power sound system.
Alternators can sometimes be rewound by a local alternator/starter shop for increased capacity, for a very reasonable price.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
TitanBlue is online now   Reply With Quote
Adding amp and sub. The Titan Kid Titan Visual & Audio Discussion 0 09-19-2006 09:14 PM
Adding foglights on SE rfs830 Titan General Discussion 6 12-06-2005 08:00 AM
Adding factory DVD set-up.... TitanicSE Titan Interior Discussion 10 12-12-2004 01:58 PM
Adding Navigation? TIGHTIN Titan General Discussion 16 03-16-2004 06:25 AM
