Old 11-21-2006, 01:31 PM   #1 (permalink)
K&N FIPK question
After reading some post here I pulled my throttle body spacer off to remove the screen behind it. I simply put everything back together. Then monday on my way home I was running about 80 on the highway and felt a little surge in the motor (this was a good surge) then noticed a rattle. Once off the highway I found the filter came off the tube. I didnt check that because I didnt take it apart. Any how should there be that much differnce without the filter. I keep it pretty clean so its not like it was clogged. Is there another filter I can use that will let more air in. I would think the one on it was pretty free flowing.
Hurricane is offline   Reply With Quote
Old 11-21-2006, 01:39 PM   #2 (permalink)
gixxer0.6g's Avatar
Re: K&N FIPK question
Are you talking about the air filter coming off? How did that fall off? Just not screwed on tight enough? I wouldn't ever run it without an air filter but if everything seems to be running ok I'm sure you're fine. Also, the filter is one of the most restrictive parts on your truck so it's not surprise that it would have more power with it off.
05 4x4 SE~
Performance Mods:
Banks exhaust, Nismo Intake, 2-Deg Timing Advance,
Exterior Mods:
Euroguard Brush Guard w/ 100w Spot Lights, fog lights, PRG Mini Lift, Low Profile Tonneau Cover, In Channel Vent Visors, Billet Grille, 17x8.5 MB Motoring Razor Wheels w/ 285/70R17 Kumho KL78s.
gixxer0.6g is offline   Reply With Quote
Old 11-21-2006, 01:57 PM   #3 (permalink)
Apparently when I was moving the tube around it knocked the filter loose. The it just vibrated off. Only drove about 2 miles without it. Got it back on no problem. Just wondering now if there is another filter that will let more air in.
Old 11-21-2006, 02:05 PM   #4 (permalink)
gixxer0.6g's Avatar
I see. I'll bet that was quite a difference with the filter off.
The setup you have is about as good as you can get. A lot of people say the injen is really nice but I don't know. I've only had the nismo on and it's loads better then stock but that's all I have to compare it to.
05 4x4 SE~
Performance Mods:
Exterior Mods:
Just installed K&N FIPK HemiETR Titan Performance Modifications 0 11-11-2004 02:00 PM
K&N FIPK HemiETR Titan FAQ & Howto Area 2 10-30-2004 12:03 PM
K&N FIPK 77 Kit Installed TheKog Titan Performance Modifications 6 09-07-2004 04:32 AM
FIPK Kit ATitan4Me Titan Performance Modifications 6 04-04-2004 07:32 AM
