Old 01-10-2007, 11:36 AM   #1 (permalink)
markislive78's Avatar
New Tundra Dyno
Thsese things are pretty spunky.....but heavy!
http://www.edmunds.com/apps/vdpconta...9/pageNumber=1
From the article....
Stronger than strong
Our dynamometer test of the Tundra returned a rear-wheel power reading of 321 hp, about what one would expect if you assume drivetrain losses to be 15 percent. We couldn't measure peak torque, as the automatic transmission kept kicking down and we couldn't make a pull through the rpm range of the torque peak.
Quicker than quick
Unleashing this powertrain down the drag strip, we recorded a stunning 0-60-mph time of 6.3 seconds, while the quarter-mile came up in 14.8 seconds at 93.7 mph. Our best efforts came with the traction control switched off, a move that activates Auto limited-slip differential, a brake-based, electronic-limited-slip function. Mind you, this is a Double Cab 4x4 truck that weighs 5,637 pounds.
I imagine a single Cab (4,800lbs) would be fun...lol!
markislive78 is offline   Reply With Quote
Old 01-10-2007, 11:39 AM   #2 (permalink)
FlimFlamMan's Avatar
Re: New Tundra Dyno
Pretty impressive stock numbers there.
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 01-10-2007, 11:40 AM   #3 (permalink)
Re: New Tundra Dyno
Yep a good 50-60 more rwHP than us stock!
Old 01-10-2007, 11:43 AM   #4 (permalink)
BKW
Re: New Tundra Dyno
Bloated HP figures are what car salesmen sell cutomers.
Torque is what drives the vehicle.
1/1/2008...it's all gonna change...only net HP can be used in ads, sales promotions, and other stuff after that date.
New Law...enacted and passed by the Congress and Senate...despite heavy lobbying by GM to the contrary.
Wonder how the semi hemi group will react?
BKW is offline   Reply With Quote
Old 01-10-2007, 12:02 PM   #5 (permalink)
Re: New Tundra Dyno
Quicker than quick
If the dc weighs 5600lbs I guess the huge crewmax will weigh 3 tons.
SKEET is offline   Reply With Quote
Old 01-10-2007, 12:03 PM   #6 (permalink)
Re: New Tundra Dyno
I thought the rwh done on the Toyota would be considered net hp.
Old 01-10-2007, 12:07 PM   #7 (permalink)
Re: New Tundra Dyno
Quicker than quick
Those numbers sound really good but until one group does the different trucks all at the same time we dont know how real those numbers are.For all we know if they had tested a Titan at the same place and at the same time they might of got that good of numbers out of the Titan,I doubt it but you never know.
Old 01-10-2007, 04:14 PM   #8 (permalink)
Blown330's Avatar
Re: New Tundra Dyno
Don't know where you are getting that from. SAE standards are what is used and GM was the first to validate a vehicle to SAE J1349 (SAE NET) using the procedures outlined in the new J2723 standard. As far as I know that is purely optional but any vehicle manufacturer who wants to use the "SAE Certified Power" in advertising must use the J2723 procedure.
2000 F-150 XLT SuperCab
370+hp/450+tq SAE and not on the meth...yet...
Blown330 is offline   Reply With Quote
Old 01-10-2007, 04:22 PM   #9 (permalink)
BKW
Re: New Tundra Dyno
I type facts, not fiction...The SAE..Society of Automotive Engineers figures don't reflect gross HP....So if the SAE figures are being used now, why did Congress implement a new law to lower the bloated HP figures?
And why did GM lobbyists fight to keep the new law from being enacted?
Read the reports in Automotive News.
For many years SAE NET figures were used, but there's no way the SAE figures reflect current bloated HP posted figures.
btw...I'm also a member of FTE. The subject is and has been discussed...quite a bit. See "Ford vs. The Competition."
Old 01-10-2007, 04:30 PM   #10 (permalink)
Blown330's Avatar
Re: New Tundra Dyno
SAE has two published standards J1349 (NET) and J1995 (GROSS). J1349 was recently revised to correct some of the procedures that allowed certain manufactures loopholes in product testing which resulted in inflated figures. GM is the first and so far the biggest advocate of the new, more stringent standards. I have yet to find any mention of the Feds stepping in. Care to cite this Automotive News article? I'd be very surprised as nothing in any SAE International magazine has stated this.
Old 01-10-2007, 05:35 PM   #11 (permalink)
Re: New Tundra Dyno
Not necessarily! I believe there are people here with close to 280ish RWHP practically stock. I'd say it's a good 35-40hp more than a Titan. Toyota probably has the ECU tune pumped up a little and the VVT on both intake and exhaust no doubt helps as well.
Get the UpRev tune, full exhaust and CAI (TB coolant bypass and a lower stat) and the Titan will spank it. Add long tubes and it's no contest. The new 6-sp auto definitely helps the 0-60 times though. Hopefully, the Titan will get a 6sp auto in the near future.
The bloated curb weight is going hurt. If the double cab 4X4 tips the scales at 5,600 lbs, the huge Crew Max 4X4 with all the bells and whistles is gonna be a real porker. Probably approaching 6,000 lbs. The only Tundra we really have to watch out for will be the 5.7 single cab short beds. But, at 4800lbs, it looks like they will be porkers too.lol!
When Nissan adds variable cam timing to the exhaust side of the Endurance and fattens up the ECU tune, that new Tundra won't be a problem stock vs stock.
'05 Titan XE
K11 Smoke
18" LE wheels-Leer 700 tonneau cover-Ram air hood scoop-SRT-10 rear spoiler-PRG leveling kit-OEM bodyside moldings-OEM foglights-Dunder upper/lower grill-Painted brake calipers-Stainless exhaust tip-Hellwig rear swaybar-Armada front airdam-Rear storage bin-All weather mats-Microfilters-Alarm with power door locks-Hood decals-Fram airhog-Tint.
Coming soon: Painted rear bumper-Bullydog-OEM bed extender....
miketan is offline   Reply With Quote
Old 01-10-2007, 08:38 PM   #12 (permalink)
Blown330's Avatar
Re: New Tundra Dyno
I'd withold putting much stock in that dyno reading. Can tell by looking at the photo that it's very likely a DynoJet 248. Only see the vehicle as being tied down by the rear axle...which makes me wonder what the dyno operator would have done if those straps had failed. Not a good way to run or get accurate, repeatable results.
Old 01-10-2007, 11:01 PM   #13 (permalink)
JeridJohnson's Avatar
Re: New Tundra Dyno
I know nothing about dynos but in this pic the front looks strapped and wheels chocked..
2007 Titan CC 4x4 LE Red Alert
OEM: Off Road, Tow, DVD
MODS: PRG Level Kit, 20% Tint, 2* Timing Advance, Rockford Fosgate 200.2 amp and 10" JLAudio sub
www.jeridjohnson.com
JeridJohnson is offline   Reply With Quote
Old 01-10-2007, 11:45 PM   #14 (permalink)
docopharm's Avatar
Re: New Tundra Dyno
holy crap those tailights are huge! sorry, off-topic, but I had never seen them until now...uck.
Click for my Site
Retrax, Bushwackers, American Racing Prism,
305/55/20 TerraGrapplers, Interior LEDs,
Painted Side Steps, Hitch Flag, Westin Bull,
PIAA 40's, PRG lift, AFE Stage II, B&B Exhaust,
Front Tint, blah, blah, blah
And no, my screen name does NOT mean Do Cop Harm, it's Doc o Pharm
Vir sapit qui pauca loquitur
docopharm is offline   Reply With Quote
Old 01-11-2007, 06:24 AM   #15 (permalink)
Re: New Tundra Dyno
Most Stock Titans Dyno 256-270 rwHP..I've seen all the Titan Dyno's since day one! If that thing dyno's 321 stock it's not close...it's safe to say 50-60 rwHp more....A RC will weigh 800lbs less than the tested 14.8sec 4x4 truck. Stock that thing does mid to low 14's. Nothing to sneeze at for stock.
New 07 Tundra ad on TV dmc601 Off-Topic Discussion 0 11-26-2006 03:32 PM
07 Tundra. SKEET Titan General Discussion 23 08-17-2006 06:47 PM
Ram vs Tundra Srt-8 War Stories 9 08-02-2006 01:42 PM
New Tundra 07 Le_Titan Titan General Discussion 4 02-10-2006 06:06 PM
New Tundra? flyguy Titan General Discussion 50 01-25-2006 01:01 PM
