"Share the wealth of knowledge and go as fast as you can"
. http://home.tampabay.rr.com/thrusttitan/
I'm putting together a website to share Titan data logging info for all to see. This is a work in progress that will take sometime to put together we have just started.
Look at the Info page for some good reading. See the data uploaded page for Excel files of logs. For generic logging download version 2.0. For UpRev logging download version 2.6
. http://home.tampabay.rr.com/thrustti..._684__V2.6.xls
This is the list of parameters to log for UpRev data
1) A/F CORR-B1 (%)
2) A/F CORR-B2 (%)
3) AFR WB-B1 (AFR)
4) AFR WB-B2 (AFR)
5) A/F WB-B1 (V)
6) A/F WB-B2 (V)
7) ACCEL PED POS 1 (V-Accel)
8) B-FUEL SCHDL (ms)
9) CAL/LD VALUE (%)
10) COOLANT TEMP (F)
11) ENGINE RPM (rpm)
12) IGN TIMING (BTDC)
13) INJ PULSE-B1 (ms)
14) INJ PULSE-B2 (ms)
15) INTAKE AIR TMP (F)
16) MAF GM/S (gm/s)
17) NB-O2 SEN 2-B1 (V)
18) NB-O2 SEN 2-B2 (V)
19) THROTTLE POS 1 (V-Throttle)
20) TURBINE REV (RPM)
21) VEHICLE SPEED (mph)
22) VEHICLE SPEED (mph)
Share the wealth of knowledge and go as fast as you can.
IRC Member "International Racers Club VK56"
TESTING: GTech/Pro RR, AutoTap, Auto Enginuity Enhanced, UpRev, Audio Spectrum Analyzer for Knock Sensors Monitoring, HP nx9420 Notebook PC T7700, Sprint Mobile Broadband
MODS: Custom PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, Custom Throttle Body Intercooler, Custom Ram Air, Custom 160 degrees Thermostat, Custom CAI, Nismo Headers, Custom B-Pipe NO Cats in line and NO Simulator without CODES (LOL), Custom MagnaFlow Exhaust, Custom Tune, Flex-a-Lite 27 Electric Puller Fan #295, Jim Wolf Technologies Camshafts, Detroit TruTrac LSD.
Thrust how many HP do you think our stock injectors would be good for? Just wondering how much boost a centrifugal could put down before the stock injectors were maxed out. Make sense?
What do you think about the self contained ATI D1SC w/air-to-air intercooler? Think UpRev could do something with that?
Very interesting spreadsheet...I have a few questions.
I notice in the chart "0-60" that the mass air flow dips hard right off of idle, and again it softens around 2500 rpm, and finally falls off at 5000 rpm. With the rpm on the rise, and I assume the accel pedal is WOT, the only thing that I can think of that would cause those air flow dips would be actual throttle being pulled back. Could you (or have you) rans those same runs while logging both accel pedal position and throttle opening?
It's easy to see how much ign timing is pulled back off of idle and during the shifts..
Thanks!
PRG Performance Kit w/SAW's
Born 9/2004
I just took another look at your data and found both throttle columns, but no data in the Accel pedal position one, and I now realize the throttle position I was looking at was the actual throttle opening...my above posted theory now has a fatal flow!
So...maybe the retarded ign timeing is reducing the volumetric eff. thereby reducing the airflow at those points?
What do you think?
Born 9/2004
Any s/c will need bigger injectors and recalibrate MAF, UpRev should be able to tune it.
loufish
There are a lot of questions and now by comparing data logs and posting it, maybe all the great minds on the site can discuss it. All the runs are WOT unless posted. MAF (VE) will have a curve but it shouldn’t drop dead at 5000 rpms. In the old days timing would peek around 3500 rpm’s and I don’t know why these new ECU’s don’t have a timing curve. In the V2.6 data the chart for the (turbine, rpm’s and speed) if the speed has a smooth and steady climb that means that there was no wheel spin, the turbine will have a smooth and steady climb as well, the rpm’s will arch away from the turbine that is the engine rpm’s running faster than the turbine. This is torque converter slip i.e.: engine management (loss of power to the wheels!)
“Please” any and all Supercharged Titan we could use some data. If you are in Florida PM me. Texas PM RB’s Titan. Cajun Country PM markislive78
Born 9/2004
If you look at the Volumetric Efficiency Data Sheet the projected gm/sec is in column J and that is 100% VE, column K will show the real time gm/sec (MAF), column L will show the difference between J and K and that is the "OFF SET", a good VE is 85-90%. Some of the data has hit over 100%.
ps on the Volumetric Efficiency Data Sheet column E row 6 change that to any number like (85) then hit enter, look at the chart 0 to 60 the blue line will show the VE at the number you entered ie(85%). when the pink line goes above the blue line that is more than the number you set ie(85%). When the yellow (off set) goes above 0 that is a positive VE number above the number you have set ie(85%). It is the same for the 1/4 mile (25 mile).
Thanks FFM that is good news when itis your turn go to the website and download the latest version today it is v2.6. I am working on more info like Aero-Drag, cal. power ect.
mailto:THRUST-TITAN@TAMPABAY.RR.COM
Tommy
we need a aftermarket manufacturer to make our trucks a upgraded intake manifold optimized for more high rpm hp.. this falling on it's face at 80mph is getting old
05' Blizzard White 4X2 KC SE
Foose Speedster 6 22's /w Nitto 420-S 305-40R-22, Hoosier Pro 28x11.50x16 Slicks, McGaughy 2/3" drop kit, Jim wolf Technologies Camshafts, IPT 3400 RPM TQ converter, IPT Valvebody, IPT Built Tranny, AEM Bruteforce CAI, NX Express Import WET kit 125 shot, Stillen Longtube headers, Dynatech 2.5" Powercats, JBA Evol catback, Detroit TruTrac LSD, Flex-A-Lite electric fan conversion kit #295, AirRaid Throttle body spacer, TB Coolant By-pass mod, Line-x spray in bedliner, Trenz 3 Piece framed perimeter billet grille /w matching bumper billet insert, Chrome tailgate cover /w handle, MCulloch HID 6K lows and fogs, Altezza Chrome taillights
BEST 1/4 Times
12.929 @ 103.28 NA FMP 7/18/08
12.8591 @ 106.74 (125 shot) 3/2/08 FMP Before IPT tranny
Can always port the existing manifold a little. But don't get your hopes up on that. Extremely expensive for anyone to cast aluminum intakes...even with a large aftermarket they are slow to develope. SBF, SBC, and a few others have a choice...particularly 87-95 Mustangs. Best bet is to go to someone like Hogan and have an intake custom fabricated...$3,000 - $5,000.
2000 F-150 XLT SuperCab
370+hp/450+tq SAE and not on the meth...yet...
if i had that much money i would say screw that and just go to menards and tell them to build me one of the engines they slapped into the C.O.R.R racing titan thing puts out almost 800hp NA imagine that beast at the dragstrip,lol
sorry for getting offtopic tommy, but i cant datalog :/
we need a fund to help me get a laptop, haha
BEST 1/4 Times
