Old 01-18-2007, 02:19 PM   #1 (permalink)
dodson914's Avatar
Timing & CAI
I am confused...I've read on several threads that some cai requires a 2degree timing adjustment. I thought you could only do that if you have a distributor cap. I am new at this so please don't make too much fun. Also I have an 07' cc le 2wd and want to put some cai on it. Will K&N be ok. Can't find anything for 07's.
dodson914 is offline   Reply With Quote
Old 01-18-2007, 02:21 PM   #2 (permalink)
AgTitan06's Avatar
Re: Timing & CAI
The timing advance is done through the ECU. You don't need a timing advance to get a CAI. But a 2 degree advance will help get even more power. Go to a Titan meet, and you can likely get it done for free. Some dealers will do it also.
Old 01-18-2007, 02:22 PM   #3 (permalink)
baseballfanz's Avatar
Re: Timing & CAI
No the CAI don't need timing advance. The 2* advance will give you some extra horse down low to mid. If you have CAI and exhaust the timing will probably give a better results than just timing advance alone. The advance is done in the ECU via the ODB2 port using either the Consult 2 or 3 device or software like Cipher.
Also welcome to TT.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 01-18-2007, 02:56 PM   #4 (permalink)
dodson914's Avatar
Re: Timing & CAI
Thanks,
So how do I find out about titan meets and is K&N ok. I'd like to get exhaust but have heard the changed the 07's and can't find anything for them.
Old 01-18-2007, 03:19 PM   #5 (permalink)
Re: Timing & CAI
Meets are usually posted in the Regional sections,
http://www.titantalk.com/forums/texas-forum/
K&N should be fine, some others to keep in mind are Volant, AEM, Injen, NISMO. Contact member LANDMAN, he's in Dallas I believe and has access to Cipher which can advance timing. As for exhaust, any 04-06 cat. back system will still work for the 07. Stillen just released some exhaust for the 07 Titan also.
2* Advance Timing EAC-ISR Titan Performance Modifications 2 12-16-2006 12:37 PM
2 degree timing or Up Rev? Canine Titan General Discussion 15 12-13-2006 07:28 AM
TBS and +2 timing titanteacher Titan Performance Modifications 8 10-20-2006 10:31 PM
timing advance nytitan1 Titan Performance Modifications 6 07-17-2006 12:45 PM
Timing Mod at Altitude gtbaldini Titan Performance Modifications 1 06-24-2006 05:24 AM
