Old 01-22-2007, 09:57 AM   #1 (permalink)
MikeB's Avatar
I think I'm missing too much low end.
I haven't been in any other Titans, so I'm not sure if it's just me or not. It just seems like below 3K RPM's I don't have the torque I should. I can't even spin the tires much at all, but I haven't been able to spin them since I put on the helper springs. I started out with my homemade intake and TBS. That gave me more pull over 4K RPM and didn't seem to pull any low end. Next I put a SuperTurbo muffler on the stock exhaust and again, my top end pull was better but nothing gained in the low end. Revently I added a Helix TBS and JBA Evol exhaust. I was expecting some better low end grunt, but I don't think I gained anything. I have to say when the tach hits 3K RPM's the truck feels like I just hit a small nitrous shot and pulls like a freight train all the way to 5K.
My only thought is that my homemade intake is inhibiting me. What I have right now is a stock intake connected to a stock MAF tube that was cut right at the air box. I then slipped on an AEM dryflow filter. It's the same one that comes with their CAI. I haven't built a baffle yet, but it has been in the 40;s to 50's outside and I don't think that intake temps are going to be a problem right now. Let me know what you all think.
2006 CC Titan SE 2WD BT. Injen Powerflow, TB Coolant bypass, JBA Evol Exhaust with Maglaflow 24" muffler, Bully Dog Power Pup, Leveling kit, $22 helper springs.
MikeB is offline   Reply With Quote
Old 01-22-2007, 09:59 AM   #2 (permalink)
BKW
Re: I think I'm missing too much low end.
3 RPM's? Three? Or 3,000 RPM's...
Even a industrial engine turns more than 3 RPM's.
BKW is offline   Reply With Quote
Old 01-22-2007, 10:20 AM   #3 (permalink)
MikeB's Avatar
LOL, I meant 3K RPM's.
Old 01-22-2007, 10:40 AM   #4 (permalink)
markislive78's Avatar
Hey Mike....how many miles do you have, are u broke in? Did you reset the ecu after each mod? If you drive your truck like a granny it will perform like a granny! A few WOT runs will wake a Titan up.
markislive78 is offline   Reply With Quote
Old 01-22-2007, 11:45 AM   #5 (permalink)
MikeB's Avatar
I have 6800 miles on the truck now. I have never reset the ECU.
I went by the school of thought that I should let it learn the mods over time. Maybe I should try that. Anyone have a link to the procedure?
I'd have to say that my truck is not driven like a granny. My wife drives it mostly and even though she is not light footed, she never goes WOT. When I drive it I mash the pedal at least twice per trip.
Old 01-22-2007, 12:19 PM   #6 (permalink)
Quartz's Avatar
You can just unhook the battery for a few hours or you can try this:
How to:ECU Reset,Throttle & Accelerator Position Learning
Old 01-22-2007, 09:03 PM   #7 (permalink)
MikeB's Avatar
Well, I performed the ECU reset and all other learning procedures in the link. We'll see how that goes. I noticed that right off the bat I can now spin the tires enough to get the spin light going. I still feel that instant kick at 3K RPM's.
Old 01-23-2007, 08:33 AM   #8 (permalink)
EVO8's Avatar
Most performance parts will lose low end. The gain is in the mid and high range. That is where performance lies. That is why most big turbo's lose a sh*t load of low end but 5krpm and above, it runs like you just got hit from behind with a Semi truck. Most shift points drop to 5krpm and that's where you want your next gear to be at. Gotta give up one for the other.
2006 Titan XE 4x4 (PRG 4" Performance package)
2003 Evolution VIII (358awhp/354awtq) that's on 91octane,stock boost, stock turbo.
2007 GSXR1000 (not enough road to touch redline)
"Dream as if you'll live forever, live as if you'll die tommorow" : James Dean.
EVO8 is offline   Reply With Quote
Old 01-25-2007, 07:22 PM   #9 (permalink)
Mikey your homemade intake is definately inhibiting you, change your intake to a volant or injen and you should be good to go----Have fun
SPEEDDMON is offline   Reply With Quote
Old 01-26-2007, 04:19 AM   #10 (permalink)
NICEAWN's Avatar
Location: Several twisties and a hop skip and jump through the forest,TX
The Titan has a major and very obvious flat spot in the fuel curve between 2 and 3 grand. My truck feels flatter than my bike does at 5 grand which is where its flat spot is. These flat spots increase fuel mileage and help on EPA testing and ratings. I am not an expert, but I can tell something has been tampered with when accelerating WOT and I feel the blatant slowing of the tach needle.
2001 Aprilia Falco 0 to 60 3.4 secs and 10.7 1/4 mile as tested when bone stock.....
2006 CC SE TEXAS ED 18 inch chromies with TOYO PROXES ST 305/60-18, 2 degree advance, stainless dual tip muffler
exhaust clips...http://media.putfile.com/ebaycanwindowsdown
http://media.putfile.com/Ebaycanwindowsup
NICEAWN is offline   Reply With Quote
Old 01-26-2007, 06:01 AM   #11 (permalink)
jessefrank's Avatar
Do the timing advance.
I kind of went backwards on the mod list from what you have, but to me the advance was the best mod, especially for the low end torque.
As far as performance mods I went S&B CAI, timing advance then JBA EVOL.
For me the intake + advance = lots of low end torque. I lost a little with the JBA, but it smoothed out the power below 3k rpms and added to it in the 3k + rpms. Before the JBA my truck would launch or burn rubber easily till it hit around 2500 rpms where it seemed to die out.
My exerience my be a little skewed though due to living in CO where the air is a little thin.
jessefrank is offline   Reply With Quote
Old 01-26-2007, 08:20 AM   #12 (permalink)
MikeB's Avatar
I'm working on getting a timing advance done, so I'll see if that helps before going out to buy an intake. I still have to build a baffle for my intake and that may help.
Am I missing a cover or something? Misfit Titan General Discussion 7 11-10-2006 09:05 AM
Am i missing something here? titanmike Titan General Discussion 4 09-27-2006 12:52 PM
what am i missing out on? 4x4 texas edition what options am i missing? d0va Titan General Discussion 16 04-05-2006 08:51 AM
Starting - missing on the first try... Spranger Titan Problems & Dealer Service 1 01-26-2005 08:20 AM
missing part jhromy Titan General Discussion 4 01-22-2005 09:35 PM
