Old 05-14-2007, 07:51 AM   #1 (permalink)
Justintoxicated's Avatar
Stillen Exhaust Issue
So I had a stillen exhaust installed @ Stillenday.
But while under my truck the other day I noticed this wire going to my brakes had melted on the new exhaust pipe...
What should I do and how much will this cost to fix? I would assume this wire controlls the ABLS and Anti Lock Brake?
stillen-exhaust-issue-stillenprob1.jpg  stillen-exhaust-issue-stillenprob2.jpg
Old 05-14-2007, 08:05 AM   #2 (permalink)
tazstitan's Avatar
Re: Stillen Exhaust Issue
Depends on how the Dealer is on where you take it..
Can maybe slide under Warranty.
You need to to let Stillen know about this - esp. they installed it for you..
** I have a extra set of Rear ABS/Speedsensor wires if needed. **
tazstitan is offline   Reply With Quote
Old 05-14-2007, 08:06 AM   #3 (permalink)
Kronos1965's Avatar
1. Contact Stillen. They will surely want to see this.
2. Any parts store or on summitracing.com has all sorts of insulation for this thing from tape to wraps...
Good pictures!
Kronos1965 is offline   Reply With Quote
Old 05-14-2007, 08:18 AM   #4 (permalink)
baseballfanz's Avatar
I've seen report form other peoples, not just Stillen exhaust but other exhaust also. Did you get the ABS light on or anything?
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 05-14-2007, 08:22 AM   #5 (permalink)
Supporting Vendor
P's Titan's Avatar
Contact Kyle and link him to this thread. Maybe a odd thing, mine is all good and have had my exhaust on for a year and a half.
Old 05-14-2007, 10:11 AM   #6 (permalink)
Nope not yet, I think the wires might still be ok, just a little concerned that they might not be since it's melted about 40% through, and they involve brakes! I could not see them through the melted goo. I'll link Kyle and see what he says.
I have some Header Wrap, I guess I could wrap the exhaust in,would that work? I know my dealer will not warranty this since it was cuased by an aftermarket exhaust.
Hell I'm having a hard time even getting them to install a non-warped window! Just had them order another one (will be the 4th one) Wasted this weekend taking it in for window, seat squeek and some chatter from the outside, got the car back washed, armoralled and looking good, but not a single issue was fixed!
Old 05-16-2007, 05:40 PM   #7 (permalink)
rynomx785's Avatar
Sounds like a zip tie got cut or broke. Im sure stillen is aware of that wire and would not leave it in harms way like that. Like said before contact Kyle. They will probably cover the cost especially considering they installed it.
Old 05-16-2007, 06:54 PM   #8 (permalink)
Crazypete's Avatar
If anything break the insulation on the wire if you think it maybe a problem, and make sure it isn't cooked all the way through. Use about four zip ties like I did when I installed mine and keep it from harms way until you decide what to do with it.
Might be just a electrical tape job with some zip ties to fix it.
07 CC LE 4x4, Galaxy with Steel Leather, Offroad, DVD, Nav + GPS pack, Sunroof, Side and Roof Airbags, Unitrack bed Ext. XMS Radio, Bigtow, Driv Blackmooshine 22" with 305/45/R22 Proxes ST tires.Stock Exhaust pipes with Flowmaster 70, 2.25" dual in 2.25" dual out, swept side with stainless tips. Hellwig rear sway bar. OEM Bug shield. S&B CAI, Active Tuning grounding kit
_______________________________________________
We be Jammin
Crazypete is offline   Reply With Quote
Old 05-17-2007, 12:15 PM   #9 (permalink)
Zip Tie Broke? I don't remember any Zip-Ties being there... Not really sure what you mean about using zipties to keep in out of harms way either.
Theres no solution for this?
Should I just see if still will re-install my stock exhaust?
Old 05-17-2007, 12:17 PM   #10 (permalink)
Supporting Vendor
P's Titan's Avatar
what did Kyle say ?
Old 05-18-2007, 10:23 AM   #11 (permalink)
They would like me to come in so they can replace the wire, I have no idea how they plan to solve the problem to preventing it from happening again. Trouble is I can only bring my truck in on the weekend, and they only work on Sat every 3 weeks, so it is going to be hard to schedule an appointment.
Old 05-18-2007, 11:35 AM   #12 (permalink)
Supporting Vendor
P's Titan's Avatar
theres the answer to your problem
Old 05-18-2007, 04:21 PM   #13 (permalink)
Zip Tie...just Zip tie it away from your exhaust till you can get it fixed...
04 Titan
Custom 19"lift
40" Toyos
onelowmini is offline   Reply With Quote
Old 05-22-2007, 10:39 AM   #14 (permalink)
from a quick look theres not really much to zip tie it too, other than well, the shock.... So yea it appears one of the gromits was out of place a bit which directed the line closer to the exhuast than it should have been (the one in the picture that appears t be all the way in is not). I'm not too trusting of those gromits anymore.
Old 05-22-2007, 11:28 AM   #15 (permalink)
Supporting Vendor
P's Titan's Avatar
I looked at that on mine and it was a good distance away. I was going to take a pic but camera is jacked up.
I had a feeling it was the gromet based on how it looked.
Stillen Exhaust ? G.T. Bradford Titan Performance Modifications 1 03-15-2006 11:16 AM
Stillen Exhaust gary748 Titan Performance Modifications 9 03-14-2006 08:26 PM
Stillen Exhaust P's Titan STILLEN 0 11-13-2005 02:53 PM
Stillen Exhaust.. CaliforniaTitan Titan Performance Modifications 5 01-22-2005 06:44 AM
Stillen Exhaust? MO Titan Titan Performance Modifications 14 12-07-2004 05:42 AM
