Old 06-25-2007, 02:12 PM   #1 (permalink)
sudden urge's Avatar
Is this the new style S&B tube? pics attached
I just received my new S&B intake 20 minutes ago. I want to make sure S&B sent me the updated tube and gaskets with it before I put it on. Thanks in advance, I'm anxiously waiting to install it if I have the correct tube and gasket.
new-style-s-b-tube-pics-attached-p6250003.jpg  new-style-s-b-tube-pics-attached-p6250004.jpg  new-style-s-b-tube-pics-attached-p6250002.jpg
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.660@93.14 MPH running BD reg 87 tune +2 timing and DA@1830' in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 06-25-2007, 07:09 PM   #2 (permalink)
DawgBone's Avatar
Re: Is this the new style S&B tube? pics attached
They sent me a replacement, and that looks like it! Install away, you're going to love it!
Old: '04 SE Crew 4x2
New: '08 SE Crew 4x2
Nov 16, 1996, UGA at Auburn, 1st quarter: UGA V almost takes Auburn wide receiver Rober Baker's manhood off for catching a touchdown pass to put Auburn up 7-0. Stupid leash.
DawgBone is offline   Reply With Quote
Old 06-25-2007, 07:16 PM   #3 (permalink)
Chevy4740's Avatar
Looks the same as mine to. No problems.
[IMG][/IMG]
My old Ride. My new ride : Big Red Chevy
Chevy4740 is offline   Reply With Quote
Old 06-25-2007, 10:47 PM   #4 (permalink)
Thanks for the replies! Ok, got it on and took a test drive. OMG, I was actually startled when I gave it 1/2-3/4 throttle. I had the airbox mod on and thought that was loud, but this is like holy shyt loud...lol. I'm an old guy, I don't know if I can handle this. I just can't imagine the Volant being louder than the S&B.
When you nail it, it sounds like a reverberation up front. I thought that was because the one corner lightly touched the fender corner, so I took a hammer and screwdriver and bent down that corner. Nope, that didn't change the reverb sound. I guess that's just the way it sounds.
The big test will come at the 1/4 mile. The sound it makes feels like 50 HP...lol.
Old 06-26-2007, 02:17 AM   #5 (permalink)
DawgBone's Avatar
Speaking from experience, the Volant is SLIGHTLY louder. I think the overall sound of the S&B is better, and the velocity stack on the filter gives it a little extra punch.
Give it some time and you'll get used to it!
Old 06-26-2007, 03:47 AM   #6 (permalink)
redneckpapa1996's Avatar
Looks pretty much just like the Volant III, except for smaller box.....Mine sounds like a monster is coming outta the engine compartment and the 4" tips !!!!!!! I LOVE IT !!!!!!!
...................................BEERWHORE™.....................................
"THIS TRUCK IS AWESOME" !!!!!!!!
2004-LE-CC-BT-OR-4X4-w/VDC-Utilitrac-Pearl White (THE BEAST)!!!!
2* advance, Volant CAI, TBS, Flowmaster 40 series w/4" duel tips, Bilsteins, Weathertech floormats, Okole seat covers, Westin Bullbar w/KC Lights
redneckpapa1996 is offline   Reply With Quote
Old 06-26-2007, 05:23 PM   #7 (permalink)
Chevy4740's Avatar
Take some weatherstrip and put it between the S&B and the truck, this will help with the vibration. Then take it for a test drive. Then take some window A/C foam and close in the sides and top. Then go take it for another test drive. You should be able to see an increase in power.
[IMG][/IMG]
Old 06-28-2007, 11:27 AM   #8 (permalink)
During the box install, I used a square piece of linoleum, cut to the size of the base, to act as a pad. Previously, I remembered reading about a few that vibrated, so this worked ok so far. I'm looking into putting some foam between the box and fenderwall, but that gap is pretty narrow and most of the incoming air should be the cooler air from the wheelwell. I recorded a couple of short clips, but they don't quite capture the lions roar...lol.
http://www.vimeo.com/223420
http://www.vimeo.com/223380
Old 06-28-2007, 01:38 PM   #9 (permalink)
I had some foam 1" pipe insulation on hand, so I used it to insulate the top and two sides. The insulation is fire retardant, water resistant, and had a nice slit on the side that made it very easy to roll and wrap around edges. My only concern is if it eventually starts crumbling and those crumbs get sucked into the filter. Anyone have any comments on that?
Old 06-28-2007, 09:21 PM   #10 (permalink)
Chevy4740's Avatar
Did you do any test runs. And as for the pipe insulation getting old, just replace it every other oil change.
[IMG][/IMG]
Old 06-29-2007, 12:25 AM   #11 (permalink)
I pulled out the insulation, just didn't look right. You're right, four 3' tubes are like $4, so that is not a problem. I have software to measure performance runs, but I did not do any comparisons yet. I'm still working on the reverberation sound at a certain acceleration rpm, you know what I mean. I'm pretty sure it's the fender vibratiing, acting like a drum, and that might not be curable.
Old 06-29-2007, 09:32 AM   #12 (permalink)
I'm done with adjustments now. I have taken the intake on and off five times now trying to reduce that reverberation. I ran without the lid, with the lid, tight filter, loose filter, insulation as a shock absorber, different angle with the tube, pad under the box, no pad, and all that changed nothing...lol. I'm absolutely convinced now that the momentary reverberation is just a huge sucking noise that is amplified by the fender opening. Hmmmmm, maybe I can try running without the fender, nah it wouldn't look right...lol.
Old 06-29-2007, 11:50 AM   #13 (permalink)
chet2575's Avatar
I have the Volant and mine hits right around 2800-2900 rpms. Loud vibration also. I was hoping the S&B wasn't was bad. Let me know when you figure it out
2006 SE, Volant CAI, Airaid TBS, JBA Evol Catback Exhaust,
Laserlite Color Matched Tonneau Cover, Soon to be Upreved
chet2575 is offline   Reply With Quote
Old 06-29-2007, 12:23 PM   #14 (permalink)
I'm done trying to eliminate it...lol. It is just the nature of the beast. For all I know, it might be the filter itself, acting like a reversed saxophone. Don't get me wrong, it's not that terrible, and only lasts for a second when you romp the throttle. Will I go back to the stock intake? That's out of the question, the S&B stays on.
Old 06-29-2007, 02:33 PM   #15 (permalink)
Derwud's Avatar
I hope you don't tow anything... I had a Volant on my '04 and when pulling a hill it would drive you out of the truck it was so loud. Now I run an AEM on my '05, much better, it's loud but doesn't have the Reverb and BOOM of the Volant.
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Derwud is online now   Reply With Quote
Anyone else have a bull bar with your skid plate still attached? Headstyle Titan Parts & Accessories 6 06-02-2007 06:09 PM
Leaks-should I be concerned? See attached whiteLE Titan General Discussion 4 12-13-2006 10:35 PM
ABS Line attached w/ slack after lift. blachow Titan Wheels, Tires & Brakes 0 02-26-2006 07:08 PM
Changed the front diff oil today (pics attached) cttitan Titan Engine, Transmission & Drivetrain 5 04-06-2005 07:13 PM
A couple pics of my Tech Tube sidesteps JoeyCrack Titan Pictures & Media Post 5 05-11-2004 06:05 AM
