Brake Pad Help
I am looking for a set of aftermaket pads that will work well with my slotted/cross drilled rotors (street use only). I have the factory spec rotors (12.6") so I am not looking for a caliper upgrade etc. I purchased a set of pads with these rotors when I got them 12 months ago and the pads do not perform well so I switched back to the factory set and the performance got better. I am being told that I need a set of pads that will perform at cooler temps because of the cooling effiencies of these rotors. Given that my factory pads are the most recent brake upgrade by Nissan I am assumming these pads are probably a hard compund to reduce the warping of the factory rotors.
I tried two sets of pads from the supplier and was not happy with iether as I had to step on the brakes a few times ot get them to brake well other wise they felt sluggish. Even with the stock pads I find that after I step on the brakes a few times my braking performance increases.
Any input on what options are out there is appreciated.
Thanks
2004 Titan CC XE 4x4
Off road package
JBA Cat back
Cold air intake
ECU Uprev Tuning
