Old 04-01-2008, 07:08 PM   #1 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
Burnout Mod Done
I Did The Burnout Mod Today On My 07 And I Didnt See A Differance At All. I Did A Lot Of Reading On How To Do It, And Everything Seems To Be Correct According To How The Directions Were, But Yes No Difference. I Was Wondering If Anyone Knows Why This Is Or If There Is A Certain Switch To Use? I Splice Into The Red Wire With The White Stripe On It From The Bottom Plug On The Ecm.
"PIT CREW"
mods wanted:
stillen supercharger
uprev ecu flash
125 shot of nx
big brake upgradE
steel braided brake lines
master cylinder stiffner
REMOTE START
RHINO LINER
TRANSMISSION VALVE BODY UPGRADE
TRU-TRAC
MODS DONE!
8000k HID CONVERSION LIGHTS, REMOVED ALL THE DECALS,TINT, CAI, straight pipe exhaust, 6" basic fabtech lift, 38.5x14.00x17 procomp extreme at's, prg uca's, radflo rear shocks, deaver springs, prg's c/o's, 3 IN BODY LIFT, HITCH, KENWOOD IN DASH DVD 7" MP3/WMA/CD/, 1 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT,LED TAIL LIGHTS, CCFL HALO PROJECTOR HEADLIGHTS, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, BLUE LED DOME LIGHT
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 04-01-2008, 07:56 PM   #2 (permalink)
mx6phan's Avatar
Re: Burnout Mod Done
try going out and with the truck running put it in nuetral and unplug the bottom plug on the brake pedal. Then attempt a burnout and ee if it works.
08 Smoke Titan LE KC
CAI/magnaflow true duals/8k hid
93 MX-6 13.4@103
custom turbo with some extras
79 Bronco
many mods sitting on 39's
mx6phan is offline   Reply With Quote
Old 04-01-2008, 08:10 PM   #3 (permalink)
titanss's Avatar
DBolemiss cut the red & black wire on his 07.
2004 XE KC
Old 04-01-2008, 08:33 PM   #4 (permalink)
rtc1184's Avatar
the burnout mod step by step i looked up said red wire with white stripe thru it. not to sound completely dumb but i know it makes it easier to do a burnout, but how? like when the brake is applies does the throttle only open so far and when you flip the switch off it goes to wot?
"PIT CREW"
mods wanted:
uprev ecu flash
125 shot of nx
big brake upgradE
REMOTE START
RHINO LINER
TRU-TRAC
MODS DONE!
Old 04-01-2008, 08:43 PM   #5 (permalink)
titanss's Avatar
Short answer, Yes, the TB goes WOT when the switch is flipped. DB told me the wiring is different on the 07 thats why the red & black wire needs to be cut. I cut the wrong wire the first time i did the BOM on my 04. Hope this helps.
2004 XE KC
Old 04-01-2008, 08:46 PM   #6 (permalink)
sudden urge's Avatar
I have no idea why someone would want to hold the brake and force the rear tire to turn. Add some mods and you'll smokem without adding any brake.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.660@93.14 MPH running BD reg 87 tune +2 timing and DA@1830' in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
sudden urge is online now   Reply With Quote
Old 04-01-2008, 08:47 PM   #7 (permalink)
rtc1184's Avatar
so does it help anything else? like launching it or anything other than just hold the brake and doing a burn out? oh btw thank you for the info i will cut the red and black wire tomorrow then. still in the bottom plug of the ecm?
"PIT CREW"
mods wanted:
uprev ecu flash
125 shot of nx
big brake upgradE
REMOTE START
RHINO LINER
TRU-TRAC
MODS DONE!
Old 04-01-2008, 08:57 PM   #8 (permalink)
dbolemiss's Avatar
Send a message via Yahoo to dbolemiss
I like to heat up my DRs at the track a little more so I know they will hook up a little bit better.
dbolemiss is offline   Reply With Quote
Old 04-01-2008, 10:07 PM   #9 (permalink)
Ok, that makes sense in your situation.
Old 04-02-2008, 04:45 AM   #10 (permalink)
roy365's Avatar
1. Adding mods cost money.
2. This is free.
3. Very fun if you like that sort of thing.
4. Getting the tires warmed up .
5. Preparing a pair of stock tires to run @ the strip by getting them almost slick.
6. Because a "true" performance machine should be able to do it!
Bad Side:
1. Possibility of faulty wiring, causing tail lights not to function or truck go into gear.
2. Tampering with a safety feature.
3. Selling the vehicle later.
0-60MPH@5.82 & 1/4 mile@14.25 Passport GT Timer
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 04-02-2008, 07:55 AM   #11 (permalink)
crash2045's Avatar
so... which wire on the 04?
crash2045 is offline   Reply With Quote
Old 04-02-2008, 07:56 AM   #12 (permalink)
roy365's Avatar
Bottom plug......red with black runner possibly. Thats what it is on my 04. Could be different on your model though. DO a search and see what you come up with if it isnt those colors.
Old 04-02-2008, 07:59 AM   #13 (permalink)
crash2045's Avatar
k i will thanks
Old 04-02-2008, 08:25 AM   #14 (permalink)
crash2045's Avatar
ok I think I got it the R/B wire on the brake pedal is where you splice in the switch
Old 04-02-2008, 08:44 AM   #15 (permalink)
roy365's Avatar
yes....it's on the BOTTOM plug. Just make sure it's the bottom plug.....yo ucant miss it and you cant go wrong if you start there. peel enuff wire loom away to be able to see good and work around.
burnout mod??? 08 4door Titan Performance Modifications 4 03-23-2008 11:05 AM
burnout mod titanswfl Titan Performance Modifications 1 10-06-2007 09:51 PM
burnout mod on a 07 dbolemiss Titan General Discussion 1 06-18-2007 07:49 AM
A must see burnout Chevy4740 Off-Topic Discussion 8 05-27-2007 04:03 PM
