Old 05-10-2008, 05:08 PM   #1 (permalink)
Options for removing WOT
What options do I have to be able to remove the wide open throttle (WOT) from my 08 titan.
json_35010 is offline   Reply With Quote
Old 05-10-2008, 05:51 PM   #2 (permalink)
sligsta's Avatar
Re: Options for removing WOT
None yet, I'm assuming you have a 2WD.
08 SE KC 4X4 SMOKE
sligsta is offline   Reply With Quote
Old 05-10-2008, 08:27 PM   #3 (permalink)
kartman's Avatar
Stop depressing the gas pedal all the way.
Rebar Wrangler
Old 05-10-2008, 08:31 PM   #4 (permalink)
Good advice. WOT is known to cause high speeds, and if hegot into a high speed crash he might...die in a fire.
2005 CC 4x4 SE
AKA
Chunky Ass Whore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is offline   Reply With Quote
Old 05-10-2008, 08:44 PM   #5 (permalink)
Does the '08 Armada have WOT from 0mph? If so, maybe you can find a seedy dealer tech willing to swap ECU files from one truck to the other and see if it'll work. However, I'm not sure if it could actually work. On the '04-'05's, there's a way using the Consult to swap in the Armada program to eliminate the 40mph WOT restriction on 2wd models, but no one here admits to having it done it. I guess everyone likes giving UpRev $800.
'05 Titan XE
K11 Smoke
18" LE wheels-Leer 700 tonneau cover-Ram air hood scoop-SRT-10 rear spoiler-PRG leveling kit-OEM bodyside moldings-OEM foglights-Dunder upper/lower grill-Painted brake calipers-Stainless exhaust tip-Hellwig rear swaybar-Armada front airdam-Rear storage bin-All weather mats-Microfilters-Alarm with power door locks-Hood decals-Fram airhog-Tint.
Coming soon: Painted rear bumper-Bullydog-OEM bed extender....
miketan is offline   Reply With Quote
Old 05-11-2008, 08:34 AM   #6 (permalink)
baseballfanz's Avatar
No, the Armada and QX does not have this limitation. The Titan has it (torque management) since the rear end is lighter. Yes you can flash the Armada MAP to the Titan but would have to know exactly what you're doing. I believe one person have done this (he swap his Titan ECU for an Armada ECU).
You have to remember UpRev is NOT just removing the WOT limitation. There's more to it than that. If you can find a dealer willing to do the ECU MAP switch, it would probably cost you almost as much as doing UpREv, keep in mind also you need to get the NATS re-program (transponder chip in the key)
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Need options Rwest386 Titan Performance Modifications 10 02-05-2008 07:18 PM
GPS options Hatch Titan General Discussion 63 01-08-2007 09:41 PM
Options blacknwhite71 Titan General Discussion 2 11-04-2006 06:02 PM
What are my options SKEET Titan General Discussion 19 03-17-2006 10:30 AM
Options superhawk Titan Suspension 6 09-19-2005 07:41 PM
