Go Back   Nissan Titan Forums > Titan Discussion > Titan Performance Modifications
User Name
Password
ECUTalk or blaZt Datascan? - being discussed at Nissan Titan Forums in the Titan Performance Modifications section.
Old 05-11-2008, 06:37 AM   #1
fuRyTACO
fuRyTACO's Avatar
Send a message via AIM to fuRyTACO
I would like to be able to run my own 2* timing advance. Does anyone know if either of these programs that are PC compatible will work?
ECUTalk http://www.ecutalk.com/ecutalk.aspx
blaZt Datascan http://www.blazt.biz/index.php
Thanks in advance!
2008.5 Titan XE CrewCab 4x2 "Blizzard White"
PERFORMANCE MODS: Coming Soon!
AESTHETIC MODS: De-badged, 35% tint, AutoPage Alarm/Keyless Entry
Last edited by fuRyTACO : 05-11-2008 at 06:38 AM. Reason: missedspelling on title and didn't want to confuse anyone.
fuRyTACO is offline   Reply With Quote
Old 05-11-2008, 07:29 AM   #2
Blackbeauty
Blackbeauty's Avatar
Re: ECUTalk or blaZt Datascan?
From the write-up, I believe the ECUTalk one is only monitoring:
Features
ECU part number on connect (23710-xxxxx)
Read fault codes
Clear fault codes
Detect available sensors (metric/imperial options, plus many additional derived sensors)
View sensors on gauges in full-screen mode (or working area option to show taskbar for PC)
Automatic adjustment of gauge size to maximise screen use - useful for widescreen displays
Logging to file (very high rate with decent CPU speed)
Automatic connection and gauge setup on program startup, auto reconnection if lost once in gauges mode
Maybe some bugs even
It says NOTHING about being able to change engine or ECU parameters.
And the other one only mentions the Z-cars, not Titans. I am not certain, but the ECU is different on this truck than on the Z-cars, which can be determined through the Uprev FAQ's on their website.
I personally don't think either one is suited for the Titan, but a quick email or phone call to those companies will settle it. Do that and let us know.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 05-11-2008, 08:17 PM   #3
sabbasaun
Thanks in advance!
THese programs will not work on our Trucks. They were designed to work with the older Consult vehicles built pre-2000. Our trucks use a newer Consult version and it is not compatible. The only other software other than Uprev's Cipher software that can do a timing advance is AutoEnginuity with the Nissan Enhanced package.
sabbasaun is offline   Reply With Quote
Old 05-11-2008, 09:15 PM   #4
fuRyTACO
fuRyTACO's Avatar
Thanks for the posts.
Old 05-12-2008, 07:02 PM   #5
NewKleer
even if they did run, the only changes they can make to the ecu are temporary (lost on engine restart of when software is closed).
NewKleer is offline   Reply With Quote
Old 05-13-2008, 06:13 AM   #6
Blackbeauty
Wow! Thank you for that totally inaccurate description. Apparently, you don't really know how ECU's work. That's ok. It's only your first post. Hopefully, you'll read a bit and learn some things.
Old 05-13-2008, 04:11 PM   #7
TitanBlue
TitanBlue's Avatar
Why do you say that?
Are you familiar with the Nissan Consult, UpRev Cipher, or Autoenginuity?
welcom to TT.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 05-13-2008, 04:35 PM   #8
roy365
roy365's Avatar
Wouldnt it be cheaper to find a local dealer or TitanTalk member that has Cipher to do the 2 degree advance? Or you could just go all out and get the real deal Cipher program that is specific for your vehicle.
0-60MPH@5.82 & 1/4 mile@14.25 Passport GT Timer
Cams, Uprev tuned, Headers, Volant CAI & Exhaust, Race cats........etc.
roy365 is offline   Reply With Quote
Old 05-13-2008, 11:18 PM   #9
NewKleer
sorry, i should have qualified what i said better
when i said "the only changes they can make", they was referring to the original applications in first post, not consult2 ones like cipher
consult 1 capabilities, unlike consult 2, are limited to changes to the ecu only whilst running and are lost when the car is turned off.
those with consult 2 cars can have adjustments made that arent lost (like the timing advance).
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
