Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 33x15.5 Swamper TSL/Sx on 16.5x14" Weld mountain crushers polished, ventshades, 5% tint all around, n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
if your looking for performance you need to ditch the flowmaster and get a straight thru muffler design like the jba catback or magnaflow, baffles restrict airflow and hinder top end performance
05' Blizzard White 4X2 KC SE
Wheels: Foose Speedster 6 22's /w Hankook Ventus RH ST-06 305-40R-22
Garrett GT4094R Ball bearing turbo, Tial 60mm WG/w 8psi, Tial 50mm BOV, Air to Water Intercooler, etc...
those are sick times.... what is your headers to exhaust setup?
those times are before the built tranny and ipt upgraded stall went in, hopefully will drop nother .4 to .5 in e.t. when i return back to the track..
Ours will be somewhat diffrent cause i have the jim wolf camshafts and have 2.5" b-pipes with dynatech high flow cats, then it goes to the 2.25" jba catback then after the y-pipe it is a single 3" out the back passenger side.. this catback is only 315 bucks and imo the biggest bargain for any performance freak, sad thing is it took me 5 exhaust systems before i found it and wasted probably 2,500 in the process,lol
if you dont want to get the jim wolf cams stick with 2.25" after the headers and you'll be fine
here's some vids of my truck in action in the first vid you can hear the jba exhaust and stillen headers combo roar..
im keeping my flowmaster 40 series bc it sounds so awesome but headers and B pipe wise what do you suggest as a setup to get optimal gains??? start with the headers please! and work your way down!
nismo or stillen long tubes?
i'd get the nismos if i had to do it all over again, you can custom make your own b-pipes for less than stillens, just need to find a exhaust shop to fab them up. total cost to make my b-pipes with highflow cats was like 380 bucks including thier labor of 100..
so i can do headers- b pipe- high flow catilitic- and then my muffler and then straight out the back with tips?
yea but if your pipes are too big after the b-pipes you will lose low end torque, needs to be around 2.25" to the y-pipe then 3" up to the muffler then 2" out the back if you have duals or whatever
thanks for the help how close are the b pipes to the headers and what size connector should be used or do the go directly onto each other??
headers directly connect to the b-pipes and that is where the high flow cats are, then after b-pipes is where a catback would start.. all the flanges should meet up perfectly whatever you decide to do
Yo Toomny, what kind of rims were you running your drag radials on? What size? Are they light? LMK thanks. Might purchase those rims for daily driving for that aggressive look thanks!
Reg
got them out of a jegs catalog, those are 16x8's and would fit the back but not the front.. but i do believe they also make them in a 17" size yea they are really light with slick and rim/tube it still barely weighs 40lbs
