LinkBack Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Old 08-14-2008, 12:45 PM   #16 (permalink)
chargedTitan's Avatar
Re: stillen supercharger
2 weeks after my S/C install, whenever I would get on it the truck would just fall on it's face, unable to drive over 50 mph, rpms would not go above something like 1,500. Threw no codes. Finally was able to get it to repeat the problem with the mechanic in the truck and hooked up to the consult. The MAFS readings were all over the place!!! New sensor installed and ran great. Just throwing out ideas.
06 CC LE -offroad, tow, nav, dvd, sunroof, srs
K + N 77/Stillen hybrid CAI
Borla dual cat back
295 70r17 toyo mud terrains
Sway A Way Coilovers/Radflo rears
Stillen grounding kit
Stillen sway bar-removed(bent)
Stillen headers-removed(leaky)
Stillen superchargers(5 blowers, 5 different intercoolers, removed for the 10th and final time)
chargedTitan is offline   Reply With Quote
The Following User Says Thank You to chargedTitan For This Useful Post:
bodytech (08-14-2008)
Old 08-14-2008, 02:05 PM   #17 (permalink)
silverstar's Avatar
consult is the scanner that the dealerships use to check for codes and all the readings of the engine. I live in ocala and go to gainesville every now and then, i'd love to see that monster sometime. i'll actually be heading up that way in a few weeks to go to the raceway and try out my new hypertech. if you have the beast running good by then you should come along. even with that lift and 36's you should still be hauling some a$$ in the 1/4. wouldn't that be cool to see a HUGE titan slaying mustangs in the 1/4!!
08 Titan SE 4x4 KC. Magnaflow X-pipe muffler with dual 2.25" tailpipes, Hypertech Max energy. 14.85@91.8 best time(9.49@74 in the 1/8th). 6000k H.I.D. low beams. 302.8rwhp before the hypertech.
silverstar is offline   Reply With Quote
The Following User Says Thank You to silverstar For This Useful Post:
Old 08-14-2008, 03:42 PM   #18 (permalink)
bodytech's Avatar
well another day is at its end the shop guys have absolutely no idea what is wrong with the truck except they think its getting worse and stillen has nothing to say except the old poo they have been feeding us for the last 2 months i guess at this point i have about a $60,000 paper weight. any one have paper they need held down?
2008 "over loaded" LE crew cab 4x4 long bed w/ toe, Bed utility package, navigation, dvd, leather, etc. UPREV custom tune, Stillen super charger, Nissmo headers, IPT tranny,Tq converter, valve body, tranny cooler,PVM tranny pan, Gator back belt, Lotec gauge pod, Autometer boost, tranny temp, wide band afr gauges, 8"lift, 20"x10" Monster rims, 35 13.50 20 MT baja claws, PRG upper control arms and end links, Custom drive shafts with 410 joints, reversed slip joint, and relocated carrier bearing,ladder bars, cai, flowmaster 40 series true duel ex , custom front bumper, grills, electric steps, ash wood dash kit, tinted windows, debadged, color matched tailgate, etc. etc.
Like Tattoos? check out wayne at; bodytechtattoo.com or bodytech on myspace
bodytech is offline   Reply With Quote
Old 08-14-2008, 03:46 PM   #19 (permalink)
bodytech's Avatar
that would be cool but no one has any idea what is wrong with my truck except it might be getting worse
Old 08-14-2008, 03:47 PM   #20 (permalink)
bodytech's Avatar
do you knowwich sensor was replaced we have already tried a but load
Old 08-14-2008, 03:48 PM   #21 (permalink)
bodytech's Avatar
oh just noticed MAFS my bad
Old 08-14-2008, 04:05 PM   #22 (permalink)
ablexus's Avatar
Send a message via AIM to ablexus
The MAF would be a good idea to check. Find another one from a Titan buddy, swap them out, see if they work. I know that that was the problem with my initial turbo install, I had a bad MAF. 120 bucks at Autozone and I was good.
I don't want to say it, but there is also a danger of engine damage if too much coolant got into the engine. Just like water, the engine can not compress coolant and although it does not appear your engine was fully hydrolocked, if there is enough coolant in the system when you turned the engine over it could definitely have damaged internal parts.
As a side note, excessive oil can also cause hydrolocking, although this is more common on radial airplane engines due to the engine design and not common at all on automobiles.
A.K.A. Whore Without A Cool Whore Name
Here's my truck and an angry little force-fed 4-banger:
12 cylinders, 650 hp, 700 tq. Lamborghini, eat your heart out.
ablexus is offline   Reply With Quote
The Following User Says Thank You to ablexus For This Useful Post:
Old 08-14-2008, 04:38 PM   #23 (permalink)
bodytech's Avatar
i don't think we have internal damage yet. we have performed compression tests all were at 100% the one thing we did notice is coolant will shoot from radiator hot or cold. nissan says its normal, but we ran tests for that to for head gaskets by forcing air in from cylinders to radiator and pressure test on radiator it all checked out
Old 08-14-2008, 04:41 PM   #24 (permalink)
bodytech's Avatar
also the engine runs great till you kick in the s/c or running at higher rpms
Old 08-15-2008, 01:34 AM   #25 (permalink)
silverstar's Avatar
that definitely sounds like a problem caused by the boost. i wonder if the engine/ecu is pulling enough timing to make it run right or if it's adding the right amount of fuel? i don't know much about the stillen chargers on the titans but i know a little about boost on import and mustang engines. and i know for those they sell the ignition boxes that pull what ever amount of timing you set them at for each lb. of boost. they also make the fuel computers that add extra fuel as the boost comes on too. does your mechanic have the ability to scan the engine while it's running and check the timing at all rpms and boost and the fuel pressure/quantity while you drive it and get into the boost???? if so i'll bet you could come on here and tell these titan gurus what the numbers are and they could tell you if they're right ot wrong. also do have a way to check the air/fuel ratio? that could also tell alot. but it definitely seems to have something to do with the boost coming on.
bodytech (08-15-2008)
Old 08-15-2008, 04:58 AM   #26 (permalink)
QShip's Avatar
Where the extra injectors installed correctly?
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
The Following User Says Thank You to QShip For This Useful Post:
Old 08-15-2008, 07:32 AM   #27 (permalink)
bodytech's Avatar
i'll ask and if he can't there is a shop with a dyno right down the road maybe he can tell me something thanks for the suggestions anything at this point can help
Old 08-15-2008, 07:34 AM   #28 (permalink)
bodytech's Avatar
i am pretty sure the injectors are right only because the come plug and play. there set up on long fuel rails with a solid harness that can only be pluged in one place in one direction but i will def. ask to make sure
Old 08-15-2008, 10:09 AM   #29 (permalink)
QShip's Avatar
The have been installed backwards on three different trucks.
Also, make sure the wiring was shrink wrapped where applicable.
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
Old 08-15-2008, 11:38 AM   #30 (permalink)
bodytech's Avatar
are you saying the rails could be on opposit sides of motor or the conection could be backwards? i really appretiate you helping with suggestions
Tags
kyle is a liar
does anyone got the stillen supercharger? got_sixth Titan Performance Modifications 9 02-29-2008 11:26 PM
Stillen Supercharger?? mgstroker95 Titan Performance Modifications 7 02-29-2008 01:13 PM
Stillen Supercharger ???? Modern Ken Titan Parts & Accessories 2 06-21-2006 10:55 PM
Fs:new Stillen Supercharger BLDRZ Buy/Sell 29 05-08-2006 10:03 AM
NISMO Supercharger ... OR ... STILLEN Supercharger ????? SHOTGUN Titan Performance Modifications 6 04-11-2005 11:27 AM
