LinkBack Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Old 08-15-2008, 12:21 PM   #31 (permalink)
QShip's Avatar
Re: stillen supercharger
The wiring harness for the injectors could be on backwards.
You need to have the dealership plug in the Consult and look at the fuel pressure while in boost.
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
Old 08-15-2008, 12:48 PM   #32 (permalink)
RyuTan's Avatar
Originally Posted by bodytech View Post
are you saying the rails could be on opposit sides of motor or the conection could be backwards? i really appretiate you helping with suggestions
If I remember correctly, you need to make the wiring harness that attaches to the injectors runs around the backside of the motor, and is not running around the front. That seems to be a common grief point. Definately get your fuel pressure checked as Q recommended, while under boost. Worst part of the install for me was the fuel pump, and while you may trust your installer, if that was done poorly, or deemed "Unnecessary", you may be starving for fuel. If you ran good for awhile, check all your wiring. I had part if my injector harness rub against my jack shaft, and start wearing the outer jacket. Caught it before trouble, and wire wrapped it out of the way.
Bought on May 1, 2004
2004 Galaxy Black 4x4 LE loaded: Nav, DVD, Big Tow
In 05: Fender Flares, Banks, K&N 77 Series
In 06: Stillen SC, TrueTrac, Stillen Diff Cover
In 07: Stillen BBK & Rear Discs, Stillen Sway Bar
In 08: No mods, just gas expense
In 09: She's out of there, will miss the Titan
RyuTan is offline   Reply With Quote
The Following User Says Thank You to RyuTan For This Useful Post:
bodytech (08-15-2008)
Old 08-15-2008, 01:40 PM   #33 (permalink)
QShip's Avatar
That can cause intermittent lean conditions and the truck will hopefully go into Safe Mode. It happened for me when I floored it.
The truck would not go over 2500 rpm. I would have to pull over and shut it down in order for it to get out of Safe mode.
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
The Following User Says Thank You to QShip For This Useful Post:
Old 08-15-2008, 04:47 PM   #34 (permalink)
bodytech's Avatar
well lets see, today we ruled out the MAFS put in a new one and no diff. we checked the injector harnesses they are correct. the fuel pump was upgraded during first install we checked that pressure it was at 50 psi, we also took the tank down took it apart and checked pump again while we were at it we drained the fuel and put $200 worth of race fuel did nothong. we also checked all wires for damage and made sure everything was located correctly. one good thing that happened today is after two months of screwing with this thing we actually got some codes out of it they are as follows TO300 B code ( random misfire ) also T2 138 code ( throtle position sensor / switch) and IDI-IEI voltage conect sensor And the engine light came on for the first time. ya hoo!!!! we are going to try to get it to nissan this weekend or first thing monday to see if they can run under boost while on the consult the only probem is it has gotten worse and we get barely get it over 2500 rpms we have to trailer it everywhere
2008 "over loaded" LE crew cab 4x4 long bed w/ toe, Bed utility package, navigation, dvd, leather, etc. UPREV custom tune, Stillen super charger, Nissmo headers, IPT tranny,Tq converter, valve body, tranny cooler,PVM tranny pan, Gator back belt, Lotec gauge pod, Autometer boost, tranny temp, wide band afr gauges, 8"lift, 20"x10" Monster rims, 35 13.50 20 MT baja claws, PRG upper control arms and end links, Custom drive shafts with 410 joints, reversed slip joint, and relocated carrier bearing,ladder bars, cai, flowmaster 40 series true duel ex , custom front bumper, grills, electric steps, ash wood dash kit, tinted windows, debadged, color matched tailgate, etc. etc.
Like Tattoos? check out wayne at; bodytechtattoo.com or bodytech on myspace
bodytech is offline   Reply With Quote
Old 08-16-2008, 06:33 PM   #35 (permalink)
Hey, I don't know if RbsTitan has posted here, but you may want to try and contact him. I am sure he could help out with some ideas.
Hopefully everything goes well.
Member of IRC VK56
2006 LE CC 4x4 3.36 - Weight: 5478
60': 2.083, 1/8th: 9.336 @ 73.97
Performance: Volant CAI, Custom 3.5" RAM Air Mod, Custom 2.25" MF CATS B-Pipes, 07 Exhaust with MF Swap, Nismo LT Headers, 2007 Intake Manifold, Tuned by DF6_Titan & Me
Interior: WeatherTech Floor mats, Kenwood DDX814, 2 12W3v3 JL Subs, MB Quarts Mids/Highs, RF 1500-BD, RF- 4.100-BD, Scoshe Dash Kit, Monster Cable 200 Series RCA's, Stinger Amp Wiring Kit, QX56 Center Console Lid
Exterior: 6000k Fogs, 4300k Lows, Black 1 PC Upper Replacement Billet Grille, Black Headlights, De-chromed, De-Badged, Tinted Tails, Black LE Rims
Warp09 is offline   Reply With Quote
The Following User Says Thank You to Warp09 For This Useful Post:
bodytech (08-17-2008)
Old 08-16-2008, 09:23 PM   #36 (permalink)
RyuTan's Avatar
Did your SC Kit come with the new plug and play wiring harness (same as from the VKPro, Pro II), or the fun do it yourself splice a headache wiring? I have not heard of many issues with the plug and play, except someone had the connectors corrode on them. It seems that alot of the functions in the the piggy back ECU are just to monitor voltage from a few sensors in the stock harness, intercept the crank position sensor to trick the factory ECU to adjust timing, and to read the the MAP sensor included in the kit to control the extra flow of fuel from the second set of injectors. Sounds like you have been very thorough in your troubleshooting, but it may be worth it to detach, and re-attach the harness intercept and check the voltage coming out of the MAP sensor. Also, I don't recall if your truck will start and idle without any issue. If it won't, I would pull the piggy harness, and direct attach again to help verify where the issue is. If Stillen has verified the piggy, perhaps a harness issue? Now I am just rambling on.
Old 08-16-2008, 09:31 PM   #37 (permalink)
RyuTan's Avatar
Heh, seems like we have had many of the same little issues. Did ya have any problems with your belt rubbing on the upper radiator hose? Would swear I had that done properly, but had it eat a little of it. Wire tied that too. I love them wire ties, almost as good as bailing wore for fixing issues. I now see in the newest version of the SC kit, there is a metal tube for connecting two parts of radiator hose together. Maybe someone else ran into same issue. At least Stillen is staying on top of stuff, and modifying the kit and instructions as issues are identified.
Old 08-17-2008, 06:15 PM   #38 (permalink)
bodytech's Avatar
yes with the kit i got it had a better set up for the radiator hose and so far out of all the problems i am having that is not one of them
Old 08-17-2008, 06:18 PM   #39 (permalink)
bodytech's Avatar
were is the map sensor i remember back during the the install we had an issue with that and stillen said there was not one. does not make sense to me but i would like to check into that it could be our main malfunction
Old 08-17-2008, 06:22 PM   #40 (permalink)
QShip's Avatar
I have a MAP sensor from Stillen...
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
Old 08-17-2008, 07:44 PM   #41 (permalink)
Kronos1965's Avatar
Originally Posted by TAFOYA'STITAN View Post
damn you have the most expensive truck on here.
No he doesn't-Galen does...
HippieWhore™
Kronos1965 is offline   Reply With Quote
Old 08-18-2008, 10:33 AM   #42 (permalink)
dangerous's Avatar
bodytech, this is like a Good Novel. I'm really looking forward to the end of it. I feel bad that you are having so much problems. I don't have a SC, but have thought about it, your problems are an "eye opener" in that hey, if it can go wrong it will. Do keep us informed as to your progress, and I'm hoping the Resolution will be a Lost cost "ah, sh$t" find.
2008.5 Titan 4x4 LE CC,Moonroof, Tow Package, Nav/7"LCD wGPS &DVD, Step Rails, Sliding Bed Extender
ya baby.....it's got it all..
MODs
AFE Cold Air Intake Stage 2 (4/30/08)
BullyDog PowerPup 8/19/08
dangerous is offline   Reply With Quote
Old 08-18-2008, 10:57 AM   #43 (permalink)
QShip's Avatar
That's one of the many things that I DID NOT have issues with. I did have to ziptie a wire that was being worn by the jack shaft.
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
Old 08-18-2008, 10:58 AM   #44 (permalink)
QShip's Avatar
You must be new around here.
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
Old 08-18-2008, 11:09 AM   #45 (permalink)
dangerous's Avatar
Yes, why do you say that?
MODs
Tags
kyle is a liar
does anyone got the stillen supercharger? got_sixth Titan Performance Modifications 9 02-29-2008 11:26 PM
Stillen Supercharger?? mgstroker95 Titan Performance Modifications 7 02-29-2008 01:13 PM
Stillen Supercharger ???? Modern Ken Titan Parts & Accessories 2 06-21-2006 10:55 PM
Fs:new Stillen Supercharger BLDRZ Buy/Sell 29 05-08-2006 10:03 AM
NISMO Supercharger ... OR ... STILLEN Supercharger ????? SHOTGUN Titan Performance Modifications 6 04-11-2005 11:27 AM
