were is the map sensor i remember back during the the install we had an issue with that and stillen said there was not one. does not make sense to me but i would like to check into that it could be our main malfunction
On mine, I do believe it ended up being mounted to the firewall with a couple of self tapping screws. It had a line running down to the intake to get PSI readings, and had a wiring harness attached into the piggy ECU. Not sure if the new style harness taps into the factory MAP, thus bypassing the need for an external MAP. I would have to download the new instructions to verify.
Bought on May 1, 2004
2004 Galaxy Black 4x4 LE loaded: Nav, DVD, Big Tow
In 05: Fender Flares, Banks, K&N 77 Series
In 06: Stillen SC, TrueTrac, Stillen Diff Cover
In 07: Stillen BBK & Rear Discs, Stillen Sway Bar
In 08: No mods, just gas expense
In 09: She's out of there, will miss the Titan
Reason: Added in URL
The Following User Says Thank You to RyuTan For This Useful Post:
funny thing about this map sensor thing it seems my mechanic does not believe there is a map sensor i believe there is stillen says there is not and nissan refusses to help us because of all the mods whats a man to do does anyone know were the he?! it is on the 2008 because i don't also at this point we are throwing more codes but still unable to solve the problem i also think my dude is about to give up on me time to cry
2008 "over loaded" LE crew cab 4x4 long bed w/ toe, Bed utility package, navigation, dvd, leather, etc. UPREV custom tune, Stillen super charger, Nissmo headers, IPT tranny,Tq converter, valve body, tranny cooler,PVM tranny pan, Gator back belt, Lotec gauge pod, Autometer boost, tranny temp, wide band afr gauges, 8"lift, 20"x10" Monster rims, 35 13.50 20 MT baja claws, PRG upper control arms and end links, Custom drive shafts with 410 joints, reversed slip joint, and relocated carrier bearing,ladder bars, cai, flowmaster 40 series true duel ex , custom front bumper, grills, electric steps, ash wood dash kit, tinted windows, debadged, color matched tailgate, etc. etc.
Like Tattoos? check out wayne at; bodytechtattoo.com or bodytech on myspace
dangerous it is reading like a bad book but i can not say all s/c are bad there are plenty of people that have them tha have had very little issues i for one am just having some crap luck it is probably some stupid sensor that is screwing up everything we have rulled out all mech. 90% of feul and now fighting electr. but with nissan not willing to help it is hard also stillen only has to things to say, poop or its the install so are no help at all besides i don't think they know any way the part that sucks is my truck has been up for 2 months now with no end in sight arrrrrrrrrrrrrrrrrr!!!!!!!!!!
You sir, have much more patience then I do. Sorry for your troubles, and hope this gets sorted quickly.
The only custom tuned turbo truck that didn't blow!
"If its impossible, I can do it"
444hp and 512ft lbs at the wheels on 91 octane My complete turbo system build list
Never gonna let you down.....
The Following User Says Thank You to Mychael101 For This Useful Post:
here is a little tid bit of info i just found out it seems that the new 08 do not have a map sensor it was replaced with what they call a boost sensor and it is located on the evap canister it does the same function as a map or so nissan says how bout it
so another day goes by still no answer we are however getting better codes out of it, it almost seems like it is limp mode. when the truck is running and not in gear it is fine i can even get higher rpms with no problem as soon as i put it on the road i can't get it over 2000 rpms also if i attemped something like a power brake it will not go over 2000 rpms another thing we tried today was to disconnect the vacume line from the back of the plenum to the piggy ecu to see if it would make a diff it did not, checked the boost sensor no problems. we also checked the valet switch whatever no matter how simple we never did get it to nissan but we have a guy from there coming tomorrow with scanner and a factory replacement computor to try and cancel out that also we just srew around trying different things to truble shoot whatever we can hopefully tomorrow will bring good news peace!
Maybe your ECU thinks the Brakes are ON which limits throttle to 10%. Hey, I'm looking at removing this feature with the Burnout Mod.
So, maybe there is a Short somewhere or the switches at the pedal are bad.
Just my $.02
2008.5 Titan 4x4 LE CC,Moonroof, Tow Package, Nav/7"LCD wGPS &DVD, Step Rails, Sliding Bed Extender
ya baby.....it's got it all..
I had it worse than you my friend. Just hang in there. Check out my thread on CT under 'Never Again Stillen'.
The good thing is your mechanic is trying to help. You need to gather as much data from the Consult and send it to Stillen. If you are not sure of what data they need, ask them.
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
The Following User Says Thank You to QShip For This Useful Post:
You did not read the threads on CT about my experience and F-16's ordeal with the Stillen supercharger.
I am a member over there, but don't frequent much. I will have to look and read there. I'm really hoping bodytech figures this out sooner than later. .
Got my supercharger the other day and I'm hoping to get it installed soon.
Would the ScanGuage II be a helpful diagnostic tool or is there any other recommendations?
I would definately buy Cipher from UpRev. It's a data logging tool, and can check codes/clear them. That is a must. I would also get a boost gauge, wideband sensor, and some other stuff I can't think of!
Good luck man!
Member of IRC VK56
2006 LE CC 4x4 3.36 - Weight: 5478 60': 2.083, 1/8th: 9.336 @ 73.97 Performance: Volant CAI, Custom 3.5" RAM Air Mod, Custom 2.25" MF CATS B-Pipes, 07 Exhaust with MF Swap, Nismo LT Headers, 2007 Intake Manifold, Tuned by DF6_Titan & Me Interior: WeatherTech Floor mats, Kenwood DDX814, 2 12W3v3 JL Subs, MB Quarts Mids/Highs, RF 1500-BD, RF- 4.100-BD, Scoshe Dash Kit, Monster Cable 200 Series RCA's, Stinger Amp Wiring Kit, QX56 Center Console Lid Exterior: 6000k Fogs, 4300k Lows, Black 1 PC Upper Replacement Billet Grille, Black Headlights, De-chromed, De-Badged, Tinted Tails, Black LE Rims
Like Warp09 said, getting the Cipher software is not an option. It is mandatory. You must log the data and post it online so that the experts can look at it.
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
