Old 09-29-2008, 09:51 AM   #1 (permalink)
changing a truck from 2wd to 4wd
does anyone know how much it would cost and how hard it would be to change an 08 titan from 2 wheel drive to 4 wheel drive? if its even possible. wonder if it would be cost effective to do that compared to buying a used 05ish 4x4 to play with.
twisneski86 is offline   Reply With Quote
Old 09-29-2008, 09:55 AM   #2 (permalink)
walleeme's Avatar
Re: changing a truck from 2wd to 4wd
Buy a 4x4 unless you want to go to hell and stay there for a spell.
My has almost nothing compared to some of you guys, but I still like it.
Red meat is not bad for you.
Fuzzy green meat is bad for you.
You know you had a great night last night when you make it home the next day missing at least half your clothes.
Let him that hath understanding count the number of the beast: for it is the number of a man; and his number is Six hundred threescore and six.
Iron Maiden
Integrity is someting you cannot buy. You either have it, or you don't. You do not want to not have it.
http://s3.bite-fight.us/c.php?uid=181043
walleeme is offline   Reply With Quote
Old 09-29-2008, 10:12 AM   #3 (permalink)
hemislayer1's Avatar
just buy an old 4x4 Yota to beat on
I miss my Titan
hemislayer1 is offline   Reply With Quote
Old 09-29-2008, 10:16 AM   #4 (permalink)
TAFOYA'STITAN's Avatar
4x4 hold there value way better. get a 08 4x4 xe
TAFOYA'STITAN is offline   Reply With Quote
Old 09-29-2008, 10:31 AM   #5 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
from what i've read... it's not worth it at all...
it would be easier to buy a 4x4 if cost effective for you
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
Old 09-29-2008, 10:38 AM   #6 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
for what you will pay to buy a used yota or 05ish 4wd you will spend a lot let doing a 2wd to 4wd swap. you can get all the things you need pretty cheap from a salvage yard. tcu, ecu, t-case, front differential, cv axles. your hubs already have the splines in them for a 4wd, your dash has the light for the 4wd. i asked this question awhile back on here and not too many pos responses so i did my homework. i have yet to change mine yet cause i dont know if i want to straight axle it or not. you could probably install everything in a good weekend at worst case. the only thing i have yet to find out about is if there are any different cross members on the frame for a 4wd than there is for a 2wd. it would be easier for you to buy the ft 6" lift kit cause it has the mounts to mount your 4wd diff to as you dont have those now since you are only 2wd
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 09-29-2008, 10:46 AM   #7 (permalink)
Megw3788's Avatar
Buy an old truck to play with. Then you have your nice reliable DD that hasn't been trashed and beat on, and you don't have to hold anything back when you're out wheeling because you'll be in your play toy and not the vehicle you have to drive everyday. Plus it's way easier and cheaper to find spare parts for an older vehicle when you break something, not to mention you can build another truck up to be way stronger than you could build your Titan.
Megw3788 is offline   Reply With Quote
Old 09-29-2008, 10:56 AM   #8 (permalink)
rtc1184's Avatar
if you are wanting to just make yours 4wd for daily things like snow or going up in the mountains or something, you will pay way less to put 4wd on your titan! if you want a mud buggy, buy an late model chevy or ford. like late 70's early 80's
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
Old 09-29-2008, 01:53 PM   #9 (permalink)
Banned
Buy a 4x4 and push the button. It's the easiest way to switch from 4x2 to 4x4.
UpRev is offline   Reply With Quote
Old 09-29-2008, 06:50 PM   #10 (permalink)
bagellord's Avatar
It would probably be a lot easier to just buy a 4x4 something rather than convert a 2WD to 4WD. Probably safer too.
gaycamellovingwhore
2008 Nissan Titan LE Crew Cab
Black/Black Leather
Tow Package
Black Hunter Truck Accessories Brush Guard
Black Undercover Hard Tonneau Cover
iPod adapter
Magnaflow 22" dual in single out muffler
BullyDog Power Pup
5000k HID low beams
Pending:
2 12" RF subs + amp
Wish List:
Cold Air Intake (AEM or Injen or K&N)
bagellord is offline   Reply With Quote
Old 09-29-2008, 07:48 PM   #11 (permalink)
FuzzyLogic's Avatar
It would cost more than a nasty divorce. Oh...if you're married...it might cost that plus the direct cost associated with the mods.
I would go buy a used 4x4 Jeep Cherokee with the 4.0L motor. Awesome little vehicle to play with...and it has some utility.
It's not rocket surgery.
'06 CC 4X4 SE Born Oct. 05
Big Tow
Eclipse GPS Navigation/DVD/CD (Dealer Option)
Smoke
World's fastest beer cooler (see photo gallery for explanation)
FuzzyLogic is offline   Reply With Quote
Old 09-30-2008, 06:15 AM   #12 (permalink)
rtc1184's Avatar
you wouldnt spend more than 3500-5k to convert a 2wd to a 4wd.
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
Old 10-04-2008, 06:54 PM   #13 (permalink)
andrew2011's Avatar
Find a SAS kit or just do it yourself. its not worth it. it could cost you easily as much to do a 4wd conversion as it would to buy a new four wheeler or an old toyota. you'd have to buy new output shafts for your tranny, a new transfer case, front driveshaft, front cvs, front diff, all the switches, and you would be in hell for a couple of weeks. the shop cost to install would pprobably be more than the parts.
andrew2011 is offline   Reply With Quote
Old 10-05-2008, 06:03 AM   #14 (permalink)
rtc1184's Avatar
you can pick everything up from a auto salvage yard for around 1500-2k. if he is mechanically inclined he can do it himself in 3-4 days max
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
Old 10-05-2008, 09:47 AM   #15 (permalink)
HudsonValleyTitan's Avatar
These guys seem to know more about it than me but there's probably a lot more to it than you know. The ECUs may be different, suspensions differ, frame may differ where the transfer case sits etc. I guess if you like doing that sorta stuff, have the $$$ and don't mind hacking up a new 08, go for it. Otherwise, trading it for an 08 or 09 4X4 Titan would probably be close costwise.
- Joe
2wd to 4wd Rabbit Titan Engine, Transmission & Drivetrain 8 08-28-2008 04:56 PM
2wd vs 4wd thebab Titan General Discussion 21 12-21-2007 10:01 PM
2WD vs 4WD drfcom Titan Suspension 9 06-03-2007 11:30 PM
Traded the 2WD for 4WD... jserman Titan General Discussion 19 02-01-2006 10:31 AM
2wd To 4wd Then 4wd To 2wd ErikArrow Titan General Discussion 7 03-14-2005 07:11 PM
