Old 10-23-2008, 03:09 PM   #16 (permalink)
yamatitan's Avatar
Re: CAN I REALLY FIR 35's WITH A 6 INCH LIFT ??
18x10 4.75bs
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 10-23-2008, 03:21 PM   #17 (permalink)
Fox Delta's Avatar
Originally Posted by yamatitan View Post
18x10 4.75bs
How much room do you have left when turned full left or right?
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
Old 10-23-2008, 03:31 PM   #18 (permalink)
rynomx785's Avatar
I have a 7" CST lift and 35/12.5/18 Toyo MT's on XD Diesels (Not sure what the offset or backspacing is). My tires rubbed when turning all the way and hitting even a small bump. If you get your offset a little too wide you will have to do the PWM (Not that big of a deal) or go my route and put fiberglass fenders on which completely takes care of your problem even if you run 37's. Also if you get a Sway-A-Way or Radflo coilover from PRG you can crank the preload up and gain up to 2" of clearance.
Old 10-23-2008, 04:30 PM   #19 (permalink)
yamatitan's Avatar
Not much at all its very close, and would rub very little before i got my coilovers. At full lock i have maybe an 1" between my pinch weld and tire. This measurement was true for my stage 1 lift and is still the same with my sway aways. the only differance is the sway aways are stiffer keeping it from rubbing at full lock offroad unlike my stock coilovers. But the only time it would rub is offroad, i didnt have a problem over speed bumps are anything like that even when trying to make it rub.
The Following User Says Thank You to yamatitan For This Useful Post:
Fox Delta (10-24-2008)
Old 10-23-2008, 09:43 PM   #20 (permalink)
Hawaiianbasshead's Avatar
oh, what's that? guys with 6" lifts and rubbing 35"s... If you see my join date I have been here a while... my post count means I read more than post incorrect assumptions
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 35x12.5 toyo MTs on 20x9" +18mm offset ultrawheels titan 6 black, ventshades, headlight covers, 5% tint all around and n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
Old 10-23-2008, 09:46 PM   #21 (permalink)
would rub before i got my coilovers.
ur contradicting yourself buddy... won't rub. now will rub without coilovers... intersting your titanic agrument is just like the boat bub
05 xe 4x4
Old 10-23-2008, 09:58 PM   #22 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
[quote=Hawaiianbasshead;1429838]ur contradicting yourself buddy... won't rub. now will rub without coilovers... intersting your titanic agrument is just like the boat bub[/QUOTE
U can fit 35s withtbs right bs and wheel! Too many people have do e it including. Myself. 4.5bs 0mm u will be fine on a 17x8 wheel
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 10-24-2008, 02:59 AM   #23 (permalink)
Fox Delta's Avatar
I have been thinking about new wheels as I am still on the factory off-road wheels and feel they aren't quite wide enough for a 12.5 tire.... I don't want to run into the rubbing issue as I want to go taller than 35"
2004 XE 4x4 CC OR
Old 10-24-2008, 05:36 AM   #24 (permalink)
rtc1184's Avatar
Your factory rims are actually the best bet for you. they are plenty wide enough for 12.5 tires. all you need is an 8" rim. your factory rims have more bs to keep the tire tucked in the fender well.
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
Old 10-24-2008, 06:34 AM   #25 (permalink)
54warrior's Avatar
Originally Posted by jasonmotox View Post
All you guys telling him he will get no rub with 35x12.5 tires really need to give him your rim and tire specs. Otherwise he'll be rubbing.
Originally Posted by 54warrior View Post
You'll want to purchase a wheel that is as close to the stock wheel size as possible. My wheel/tires do not stick out too far, yet I cannot run the stock mudflap and do occasionally get some MINOR rubbing on the inner fender liner at full turn, when the suspension compresses. I think my wheel specs are: -6mm offset, 4.75" backspacing.
17x9" wheels with 35x12.50-17" tires:
I think running the the stock mudflap and having ZERO rubbing with 35's is next to impossible.
Just m opinion though.
2005 Nissan Titan CC SE 4x4
Old 10-24-2008, 12:32 PM   #26 (permalink)
yamatitan's Avatar
If you re read my post it says i only rubbed at full lock offraod. This means no rubbing at all onroad. And when i mean offraod i mean front tires coming completely off the ground and landing on the full weight of the truck. Hardly a need to do the PWM
This is coming from someone who doesnt even have a 6" lift. Oh and if you re read my post i never once said that it was impossible to rub buddy. I said you dont need a PWM to fit 35" tires on a 6" lift.
The Following 2 Users Say Thank You to yamatitan For This Useful Post:
54warrior (10-24-2008), rtc1184 (10-24-2008)
Old 10-30-2008, 02:42 PM   #27 (permalink)
Fox Delta's Avatar
I thought the Off-Road wheels were 7.5" wide? Almost every tire maker recommends 8.5-11.0" wheels..... I've feathered the edges on my 12.50's pretty good....
2004 XE 4x4 CC OR
Old 10-30-2008, 03:46 PM   #28 (permalink)
Send a message via AIM to smacked1
damn how big of a tire can i go with just the stock suspension and stock se 18" wheels
'06 SE King Cab White
Nismo Intake, Nismo Cat-Back Exhaust (True Dual)
smacked1 is offline   Reply With Quote
Old 10-30-2008, 06:16 PM   #29 (permalink)
yamatitan's Avatar
33's you might need a levling kit depending the how wide the tire is.
Old 10-30-2008, 07:42 PM   #30 (permalink)
oh ok thanks alot i think i want a 8" lift, if i go 8" lift what size tire would the biggest be for the stock 18s, i know i ask alot of questions but thats the only was to get an idea
9 inch lift clear 37 inch tires? markieeeg Titan Suspension 23 12-27-2008 07:29 AM
WILL 35's fit after my lift vanilla gorilla 13 Titan Wheels, Tires & Brakes 8 07-08-2008 12:01 PM
3 inch body lift w/6 inch PC Lift Big-K Titan Suspension 3 06-03-2008 01:50 AM
Sindle Lift with 35's themaildude Titan Wheels, Tires & Brakes 1 01-03-2008 12:07 PM
6 Inch lift with 33 or 35's? TitanZX Titan Wheels, Tires & Brakes 13 10-12-2006 03:00 PM
