Titan rear end exploded view - Nissan Titan Forum
Old 10-29-2008, 04:29 PM   #1 (permalink)
MilenkoGT's Avatar
iTrader Score: 5 reviews
Send a message via AIM to MilenkoGT
Ok well here is a pic that i found of the 2007 nissan titan complete exploded view of the rear end, every piece you can see how its put together.
Now...other than larger axles can anyone point out exactly what was changed in 2008, because nissan is telling me nothing changed from year to year and that RINGPINION.com today told me (after asking him 3 times) if the part number TT 913A582 (trueTrac) would fit in an 08 and later, and he said ''yes''.
If this is still untrue, i'm calling nissan tomorrow and having them cross reference part numbers for the 2007 rear end and the 2008.5 and see what exactly was changed, hopefully nothing at all and this was all BS so us 08 and later guys can use a TT or swap out to 07 axles/carrier bearings, races...etc..
enjoy!
2008.5 Titan SE CC FFV
'Smoke'
Uprev/Danblp Tune**Custom 4in CAI w/ ram air & TB Bypass Mod,**RP-PERF Stg.2 E-FANs**170 T-Stat**DTLT's-No Cats-CAJUN 2.5in B-pipes, Apexi resonators, Flowmaster Y-pipe 2.5in to 3in to (Japan made) APEXi N1**PML Trans Pan**Transgo shift kit**Long SR4588 Trans Cooler**TruTrac w/ 3.36 gears**NFABWORKS Traction Bars**20x10 KMC XD Rockstars**305/50/20 Cooper Zeon LTZ**R1 Concepts Slotted Rotors w/ Fleet Perf. Pads**Legit Acc. HIDs 5000k with LED Reverse Package**Custom Mesh Grill Mod
Coming Soon FT90 Kit w/ LS7 TB! One of the Last!
MilenkoGT is offline   Reply With Quote
Advertisement
Old 10-29-2008, 04:53 PM   #2 (permalink)
twistedfreedom's Avatar
iTrader Score: 9 reviews
Send a message via AIM to twistedfreedom
Re: Titan rear end exploded view
Have any 08 owners swapped axles to an earlier model? (08 to 04-07) It may be time to go to the junk yard and get one and ditch the one wheel peel.
2008 Toyota Tacoma The Incredibuild
Farewell titan you will be missed, your MPG will not
PINKBARBIEWHORE™
Removed due to complaint
twistedfreedom is offline   Reply With Quote
Old 10-29-2008, 04:55 PM   #3 (permalink)
iTrader Score: 4 reviews
The inner splined ends of the axles slip fit into splines of the TrueTrac side gears. If the 2008+ have larger diameter rear axle shafts, it seems to me that the TT would not fit, unless the splined inner ends of the axle shafts are necked down to the same dimensions as the 2004 - 2007.
Old 10-29-2008, 04:58 PM   #4 (permalink)
Then would it be possible to also have the gears on the TT machined to accept the larger 08 axles with out losing structural integrity?
PINKBARBIEWHORE™
Old 10-29-2008, 05:14 PM   #5 (permalink)
Interesting question. I have never seen anything posted regarding the difference in the dimensions between 2004-2007 and 2008+ axle shafts.
Maybe these guys would know whether the TT side gears or the inner ends of the axle shafts could be resplined:
Moser Engineering
Old 10-29-2008, 06:23 PM   #6 (permalink)
Banned
Mychael101's Avatar
iTrader Score: 0 reviews
There is nothing listed for the different years for the rear end other than small parts. The housing and internals are marked not for sale. I can only assume that any warranty claims for the damaged rears are covered by Nissan but Nissan sends the parts back to Dana for reimbursement. Strange that you can't buy anything for the rear. Maybe I'm just looking at an older parts guide.
Another strange thing is that there are different injectors for the 05-06 and 07+ FFV trucks.
Mychael101 is offline   Reply With Quote
Old 10-29-2008, 07:03 PM   #7 (permalink)
Milenko gt i want to be your love child...... i wil get in touch with the nissan master techs that i worked with tomarrow and get the correct information, and remember i can always find you, you cant hide from me, whohahahahahahahahahahaha!!!!!!....
and for those wondering i worked for nissan for over 2 years and have worked and am still in contact with two of the best master tech nissan has to offer, not just for titains but for turbo apps also, i am nissan certified on the service advisor end, but i do know what muffler bearrings are!
blueovelwookie is offline   Reply With Quote
Old 10-30-2008, 11:46 AM   #8 (permalink)
MilenkoGT's Avatar
well i need all the tree huggin hippies i can get, thanks chewbacca/wookie, if all works well then us 08later guys can get a True Trac installed, no more one wheeled wonders.
oh and ask the two master techs about turboing the titan. Including info on what size fuel injectors we have and if they were changed.
i should be this for halloween
'Smoke'
Old 10-30-2008, 06:26 PM   #9 (permalink)
anmut's Avatar
iTrader Score: 1 reviews
If this ends up being true I will kiss both of ya'll....
Trutrac will be my next mod.
Mods: Bully Dog Tuner · 2* Timing Advance · AEM Brute Force · Burn-out Mod @ ECU · 18" Magnaflow
Nissan OEM Brush Guard · Hellwig Traction Springs · 4 Hella 500FF OR Lights
Line-X Bed Liner · Jason Topper · Nasta Nerf Bars
Wish List: Nitto Mud Grapplers · Rims
Waiting For Support On: TruTrac / PowerTrax
anmut is offline   Reply With Quote
Old 10-30-2008, 06:48 PM   #10 (permalink)
kisses are on the second date, sent email to master tec should know something soon, i will try and get the nissan soft ware for diag and a pass code to get in, and yes i am good like that, as far as turbo- 5-7 psi max before piston failure. bottem end good pistons light. it is good to have worked for nissan for so long. will get answers as soon as i can, be patient the tech is doing some mods to the 240 converted to skyline and 700+ single turbo 300z
Old 10-30-2008, 09:48 PM   #11 (permalink)
loufish's Avatar
iTrader Score: 11 reviews
You should try to contact the guys at Eaton, they're the ones who have tried to fit one of their TruTrac units into a 2008...
PRG Performance Kit w/SAW's
Rear Bumpy-Bumps
35" General Red Letter Grabbers on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
Old 10-30-2008, 10:09 PM   #12 (permalink)
Sftail1990's Avatar
Pure heresay on my end but I have heard the difference is that the axle shafts are larger, I know of no other change and I doubt many will be able to find out specifics of the carrier. If the spacing is the same then I would think you could respline the shafts smaller diameter and use the 06 or 07 TT.
2006 Titan SE CC Granite, ,Uprev Tuned , JWT S7/S2 cams, 07 manifold, FT90mm, 170 Thermostat, AirRaid MXP 4", Long TruCool Trans Cooler, Big Tow, Stillen BBK w/stainless lines all around, 20" KMC Brodie 671 wheels, Active Tuning Kit, Axle Vent Mod, Mag-Hytec rear diff cover ,True Trac, Armada front spoiler,and Cowl painted. Nismo stripe kit. Katzkins leather interior. Nismo Headers (temporarily removed), PRT 304 SS High Flow catless B-pipes, PRT all 304 SS Custom Y 2.5" to 3" w/Borla and dual 2.5" side exits w/Resonated tips, Stillen front sway bar w/PRG end links, StillTime 35mm bushings w/billet mounts, PRG mini lift, Bilstein 5100's, PML trans pan w/guage set in Lo-tek pod. All Amsoil fluids, of course, I am a dealer.
1/4 Best 14.318 @94.53 in 1408 DA FST
Previous 14.485 @ 93.17 in 2497 DA in FST
1/8 Best 9.138 @75.28 in 1004 DA in FST.
Previous 9.157 @74.60 in 1886 DA in FST.
60 ft Best 2.039 in 1886 DA in FST.
Previous 2.054 in 2497 DA FST
Great parts list by BBF, had to post it also.
https://spreadsheets.google.com/pub?...FJrLAteCAHEBFA
Sftail1990 is offline   Reply With Quote
Old 10-31-2008, 06:15 AM   #13 (permalink)
anmut's Avatar
Are we sure they actually tried? I've contacted them regarding 08 support a half dozen times and all they've ever said is "not yet, the rear end is different on that year."
It's totally possible that they got the spec sheets for the newest model and didn't even try because they assumed there was a difference. I mean, if the documents say it won't work why would you take the trouble to go find an 08 rear end and see for yourself...
Old 10-31-2008, 07:15 PM   #14 (permalink)
patience young grasshoppers, the truth is comming!
Old 10-31-2008, 08:04 PM   #15 (permalink)
Banned
rtc1184's Avatar
iTrader Score: 2 reviews
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
mychael are you serious? you are building a turbo, but yet you didnt know the injectors were different? hmmm 07 isnt a ffv motor, it is vvt. that is the reason the injectors are different and why they dont make cams for 07,08,09 models, but they do for the pre o7
rtc1184 is offline   Reply With Quote
Advertisement
rear view mirror for XE cali-titan Titan General Discussion 4 12-27-2008 09:44 AM
rear view camera danny2623 Titan Visual & Audio Discussion 0 05-03-2008 04:07 AM
Request for Front Differential Exploded View bestatchess Titan Engine, Transmission & Drivetrain 4 12-27-2006 12:23 PM
exploded view of dash stlblues Titan Interior Discussion 8 03-02-2005 12:56 PM
LE rear view mirror MikeZ Titan General Discussion 4 01-08-2005 02:18 PM
SEO by vBSEO 3.3.2
