Old 11-19-2008, 08:08 PM   #46 (permalink)
TitanBlue's Avatar
Post Installation Instructions Nissan Mass Air Flow Sensor by JET
It arrived on time. I still plan to have results posted Sunday night. The following information is from the installation Instructions included with the MAF Sensor I received this week. Maybe some will find this helpful...:
Part No. 69138
Fits the following Nissan vehicles
04-06 350Z 3.5L
04-08 Altima 2.5L, 3.5L
04-08 Armada 5.6L
05-06 Frontier 2.5L, 4.0L
04-08 Maxima 3.5L
04-07 Murano 3.5L
04-05 Pathfinder 3.5L
06-08 Pathfinder 4.0L, 5.6L
04-08 Quest 3.5L
07-08 Sentra 2.0L, 2.5L
04-08 Titan 5.6L
07-08 Versa 1.8L
05-08 Xterra 4.0L
1. Locate the factory Mass Air Flow sensor located in the intake tube of the vehicle. Unplug the factory connector from the stock sensor.
2. Remove the two screws that mount the factory Mass Air Flow sensor to the air intake tube and remove the sensor from the vehicle.
3. Install the JET Powr-Flo mass Air Sensor in thte intake tube using the factory screws that you previously removed. Connect the wiring harness to the Jet Mass Air Flow Sensor.
4. Start vehicle and verify that the check engine light is not on.
5. Put your factory sensor away in a safe place for a spare.
JET Perfromance Products
17491 Apex Ciircle
Huntington Beach, CA 92647
Tech:714-848-5515 Fax:714-847-6290
customerservice@powerbyjet.com
JET Performance Products, Import & Domestic Performance, Performance Kits, Fuel Systems, Transmissions
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
The Following User Says Thank You to TitanBlue For This Useful Post:
black08 (04-07-2009)
Old 11-20-2008, 07:46 PM   #47 (permalink)
Brianguy's Avatar
Send a message via AIM to Brianguy
Re: Installation Instructions Nissan Mass Air Flow Sensor by JET
I cant wait to hear your review. I wanted to know if it'll make a difference with the uprev too.
2008 Silver CC XE
Volant intake
JBA exhaust
Smart4cars H.I.D. conversion
Black neoprene seat covers
Hellwig rear anti-sway bar
Black bull bar w/ lights
PRG Shackles
Optima Yellow Top
Jensen VM9223 7" Touch Screen
WeatherTech Floor Mats
Brianguy is offline   Reply With Quote
Old 11-24-2008, 04:04 PM   #48 (permalink)
TitanBlue's Avatar
Re: Jet 69138 Powr-Flo Mass Air Sensor
RESULTS ARE IN!
I screwed up my first logs, so had to rerun. Newbie error, I rarely "Performance Log". Got my brain in gear and results 1, 2, 3 are for the JET. Results 3, 4, 5, 6 are for the OEM.
My conclusion is "neutral". I can not give a "high" recommendation to purchase, until somebody does a better test. Either with Drag Radials to ensure no slippage on a street run, or use a Dyno to measure HP gains, if any.
AVG Gain was .018 seconds, but inconclusive IMHO.
I have a 2WD CC with Highway tread Tires, 2 Tool boxes in rear, and a full tank of gas (93 Octane). I'm running kinda heavy day to day. Temp was 47 degrees, humidity fairly low I think. It was all run on a very flat highway, but different direction. I simply floored it, did not power brake, as I'm on street tires. I really didn't see any slope to the highway though, and I used to be a Geodetic Surveyor. Improvement looked like about a .018 improvement, but includes a best run of 6.70 with the OEM unit, so there goes any proof of real gains.
I did take a close look at the unit, and it is an OEM as has been stated. So, no Aero improvements to this.
JET: 6.76
JET: 6.73
JET: 6.75
JET AVG: 6.747
OEM: 6.79
OEM: 6.81
OEM: 6.76
OEM: 6.70
OEM AVG: 6.765
It is certainly the easiest Mod, besides a Timing Advance. Would be better if the JET Label was showing on top of the Sensor, instead of the bottom!
Could not upload .csv file here, but results are shown.
UPDATE: JET has Dyno results to be posted, showing 5+ HP Gain. That would make sense to me. Reasonable and consistant with a .018 gain on average.
The Following 2 Users Say Thank You to TitanBlue For This Useful Post:
Misfit (11-24-2008), roy365 (11-24-2008)
Old 11-24-2008, 04:19 PM   #49 (permalink)
so basically snake oil? Did you ever do one of these for a throttle body spacer?
2004 LE, 4x4, Big tow, LED's from superbrightleds, HIDs from Phu, Ingen intake, 2* timing advance from titanic, upgraded under front seat sub from James 50 series Flowmaster CB.
Saintwho is offline   Reply With Quote
Old 11-24-2008, 04:27 PM   #50 (permalink)
Banned
roy365's Avatar
Thanks for posting the results!
roy365 is offline   Reply With Quote
Old 11-25-2008, 12:47 AM   #51 (permalink)
firelife25's Avatar
well any horse power is good horse power.......
SOCAL VK56 RACING CREW CHIEF[/b]
IRC VK56 PIT CREW CHIEF
8.89 1/8 @ 77.12 mph
2007 XE CC
Exhaust......
firelife25 is offline   Reply With Quote
Old 11-25-2008, 05:54 AM   #52 (permalink)
Banned
roy365's Avatar
How can one part for so many applications be expected to produce the advertised numbers? Thats crazy.
Old 11-25-2008, 06:44 AM   #53 (permalink)
TitanBlue's Avatar
May I introduce you to the phrase they love? "Up to". lol.
They rarely show the one application that did achieve that max gain, but constantly use its numbers to advertise the entire product line. Exageration sells. They take us for fools, don't they? Anyone golf or fish?
Yep firelife25, any Horsepower is good Horsepower. It's an endless quest...
Old 11-25-2008, 06:53 AM   #54 (permalink)
Banned
roy365's Avatar
So the same performance part for the Titan and 350Z will fit on a Versa?
Old 11-25-2008, 07:03 AM   #55 (permalink)
TitanBlue's Avatar
Yep, it fits the Versa!
It just measures volume of air passing by. (I think it measures the Temp too, as an Intake Temp is in Cipher readings. Lots of pins inside of the Sensor.)
We use the same Flow meter in an 8" Water Pipe, that we use in a 42" Water Pipe (Sewer system rehab work). The basic mechanism is same, just adapted for application. It keeps the technical parts standardized, cheaper to produce.
Now, should I open up my OEM unit to see what is inside, such as just diodes and resistors, or a IC? I wonder what they have done to make a change in "programming" as they put it. Reflash an EEPROM, or an Engineering Change (EC) to the Diodes/Resistor network? I am inclined to believe a simple resistor added to one location, changes the curve of the output, much like the Ebay items. But, this one being done correctly, since it is application (Nissan Part Number) specific, not generic, and it is from JET.
Yes, I trust JET to have done something, as they are a reputable and well established company. And No, I won't be opening the JET unit to directly compare. I just want to see what is inside the OEM little doohickey.
Old 11-25-2008, 11:08 PM   #56 (permalink)
Leadsled124's Avatar
Apparently my comments where overlooked when this first came up. This will not gain your hp by itself. all it does is meter airflow. If you are force inducted or making over 100hp over stock then your stock AFS will "max out". Im sure this one is made like uprevs high reading AFS. It wont peg out and will be able to read higher readings to generate more power by giving the motor the fuel it needs to run perfect AFR's. The part is good your just not making enough power yet to use it. It wont hurt anything to run it but you may need to change the settings in uprev tuning roms to accomidate
'06-Uprev/Stillen Longtubes/JBA Kat-bak/Injen/highflows/PGM/Trutrac...
Leadsled124 is offline   Reply With Quote
Old 11-26-2008, 05:26 AM   #57 (permalink)
Banned
roy365's Avatar
I remember a few people saying that these weren't for N/A guys.
Old 11-26-2008, 06:44 AM   #58 (permalink)
TitanBlue's Avatar
UpRev has responded to our thoughts on this. UpRevs HiFlow Sensor has a radically different output, that MUST be tuned immediately. Consequently, the JET Sensor is nothing like the UpRev unit, as it is advertised (and tested by myself) to operate without tuning. So, the JET may or may not have any change from an OEM unit.
Here is what I posted on another site, (where a chart is posted), in response to UpRevs offer test my JET Sensor and report on it...
UpRev has volunteered to test the actual JET MAF Sensor, to see if there is any difference in its output verses the OEM Sensor. They claim (and understandably so) that there should not be, unless it was a radical change for which immediate tuning would have been required. I am shipping my JET Sensor to them, they should have it by Dec 3rd, and will test it quickly, and give us detailed results. Their concern is that if only a mildly modified (Remember, advertised as no tuning required) Sensor, it would cause the engine to run lean, which can be a dangerous thing. I will update with the data as soon as it is made available. Current graph above, indicates little if any change. We should get very fine detail from their report. Big Thanks go to UpRev.
Old 11-28-2008, 08:40 AM   #59 (permalink)
QShip's Avatar
This will not work for boosted trucks. It will max out like the stock MAF.
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
Old 11-28-2008, 05:01 PM   #60 (permalink)
TitanBlue's Avatar
QShip is correct. No surprise there ...
JET advertises it as a drop in replacement, not needing any tuning. That is exactly what makes it controversial. If no tuning, then what is different? The higher flow unit UpRev sells, needs immediate tuning. OEM is about 4.5 Volt, where the Hi Flow is 2.3 or 2.6 something Volt for same near max flow...
Mine shipped to UpRev today, they will have it Tuesday, EOB.
We will have all the facts as soon as they report them. An OEM vs JET output curve. Nothing more to say until then...
Tags
jet 69138, mass air, performance
Mass Air Flow Sensor jsnbrd Titan Problems & Dealer Service 23 09-26-2009 10:08 AM
K&N Filter and Mass Air Flow Sensor TitanNorth Titan General Discussion 26 11-24-2008 09:24 AM
mass air meter downndirty Titan Performance Modifications 10 12-12-2007 11:02 PM
Dealer - Mass Air Flow MAF sensor - BOTH Air Flow Sensors AquaDios Titan General Discussion 11 01-25-2007 08:42 PM
Air Temperature Sensor gary748 Titan General Discussion 1 03-13-2005 07:33 PM
