Ok, I have a 4" spindle lift, and wanted to go a lil bit higher by adding two more inches.. I just got my shocks and rear blocks today, so i decided to not waste any time!! They are the Pro Comp MX6 Adjustable Monotube...Still waiting on my front spacers, but I just couldnt let thos shocks just sit in the garage... .. But i have one concern, when i i start driving, i feel a vibration.. then it goes away, Anyone know what this could be? Let me know what u think too.
MODS:
Front : 4" spindle lift front + 2.5" spacers
Rear: 5" blocks & ProComp MX6 adjustable shocks
Diamo 17 Karat Black 20" rims
33" Toyo M/T Tires
Black emblems
Limo Tint
Tinted headlights and tail lights
Futur Mods: Total chaos UCA's... Tru Trac
is the vibration in your drive line ? where is it comming from? i have an 08 as well and have had plenty of vibration problems in the past. maybe i can help.
2008 "over loaded" LE crew cab 4x4 long bed w/ toe, Bed utility package, navigation, dvd, leather, etc. UPREV custom tune, Stillen super charger, Nissmo headers, IPT tranny,Tq converter, valve body, tranny cooler,PVM tranny pan, Gator back belt, Lotec gauge pod, Autometer boost, tranny temp, wide band afr gauges, 8"lift, 20"x10" Monster rims, 35 13.50 20 MT baja claws, PRG upper control arms and end links, Custom drive shafts with 410 joints, reversed slip joint, and relocated carrier bearing,ladder bars, cai, flowmaster 40 series true duel ex , custom front bumper, grills, electric steps, ash wood dash kit, tinted windows, debadged, color matched tailgate, etc. etc.
Like Tattoos? check out wayne at; bodytechtattoo.com or bodytech on myspace
yeah it feels like its in my rear.. I do hav toyo m/t's on, but befor it wouldnt vibrate as bad.. Nowwhe im kus taking off the rear vibrates.. Could i be my drive shaft? Do i need any kind of spacer for it since i droped the rear axel that much lower? After i go over about 10mph i dont feel anyuthing and rides normal..
MODS:
33" Toyo M/T Tires
Black emblems
Limo Tint
You probably need a CBDB if you don't have one on already...I'm assuming you're 2WD...
2008 Titan SE CC, Popular Package, Big Tow, Bed Utility Package, Sliding Bed Extender Click here to see my mods Click here to see my pics
Wife's Ride: 2005 Infiniti QX56 4x4
My Other Ride: 2007 Sea Doo Speedster 200
AKA: Crossdresser Whore™
The Bald Avenger® "Why is the rum always gone?"
question? it looks like you have a short bed do you have one or two drive shafts, does your truck have a carrier bearing or does it go straight in your tranny
If you don't make sure those u-bolts are nice and tight you may get a vibration and make sure to check them every now and then. Mine loosened or settled after I installed them causing a vibration I tightened them up and now I'm good to go.
Yes mine is a short bed.. The drive shaft is two peices.. Im not sure wht or where the carrier bearing is , so im not sure.. Thanks, Your truck looks pretty bad a$$ too!! You coming out to the off road meet?
MODS:
33" Toyo M/T Tires
Black emblems
Limo Tint
How big are the new blocks? They look to be 4-5"...
Not only do you need a carrier bearing drop, but you're probably getting pretty bad axle wrap as well...
the carrier bearing is where the shafts meet, sometimes with lifted trucks it puts a little to much of an angle right there and you have to lower that support to take the bind out of it. like bills 1974 said you can get a bracket for it at PRG. I actually cut the frame right there fabricated a new drop then made it ajustable using shims so i can move it up or down or side to side for some fine tuning. and like bill said i would also look at axle wrap and check the u bolts. your not pushing all that much power yet and your tires are still a good sizes so i don't think it could be axle wrap, and if tightened all the u bolts correctly that should also not be a problem, but all is worth looking into.
