peytons, your 08 right? i removed my secondary cats and left the 02 sensors where they are. the sensors are before the secondary cats, so it shouldnt affect them. unless for some reason your sensors are after the cats?
Do NOT run one out the side and one dumped. It will sound like ***. The one out the side will sound like half a v8. The one dumped will give you the same sound inside. Either dump them both or run both out the side.
2008 Titan KC LWB XE
Titan Tough with the right stuff!!
Cherrybomb c/b 300621 (tailpipes) Hooker Aerochambers with custom equal length X-pipe, Free airbox mod, Drop in K&N, 2+ Timing, Silverstar Ultra bulbs (very bright).
14.57@94mph FST/14.427@95.052 MPH Corrected 986' DA
Next: LT headers, BDGT or Uprev, Brute Force CAI, IPT valvebody, JWT cams, 3.73 gears, Eliminate one wheel peel!!!!
"If 'yer spinnin' you ain't winnin'!!"
The Following User Says Thank You to Toughtitan08 For This Useful Post:
are the stock pipes 2 1/4 and then when they hit the y-pipe go to 2.5? I have to measure the diameter and find out. typically, you want the volume to increase as you combine the 2 pipes. I would not do true duals unless you install a balancer somewhere.
what if each muffler isn't at the same location, one is farther back on the pipes than the other. Would that effect sound?
if the mufflers are close, then no. If there is a lot of seperation (say more than a foot of pipe length) then there could be some sound difference, but if they are both run straight out the back, I doubt anyone would notice.
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
