Old 06-17-2009, 10:39 AM   #1 (permalink)
Nismo header install sucks!!
Well I started yesterday afternoon at 4:45 in the blistering heat and humidity of south mississippi. BIG MISTAKE!!
Well everything went so-so for the first 2.5 hours until I was ready to start unbolting the head bolts. I had to acquire the assistance of my dad to shock the nuts loose by hitting the end of the ratchet with a 5lb. beater. I'm positive I would have destroyed the nuts and my knuckles if I would have kept trying to break them loose by hand. I had quite a bit of trouble tightening up the nuts once I installed the nismo LT's. It was difficult to reach the nuts with the stock manifold in place, but once I installed the LT's it got even more difficult due to the individual header tubes making it impossible to use a ratchet.
Once I got the headers installed it was pretty easy to get everything bolted back up and into place for final tightening. All in all the entire passenger side took me from 4:45 to 9:53 to complete. I would have never thought it would take me just over 5hrs to complete one side.
This morning I got up at 8:00 and started working on the drivers side at 8:30. I got the steering shaft out of the way, the AFR sensor out, the motor mount bolts loosened, the engine raised, the heat sheild removed, and the b-pipe out. I did all of that in just over 1:15. I decided to stop there until my dad is home from work so he can come over this evening and help me get the head nuts off again. I hope to have and should have everything done this evening.
Wish me luck.
Oh yea, for anyone about to attempt a task such as this, I recommend you use a metal rasp or file to and file down the sarp edges on the top of the upper A-arms. They are very sharp, and my left forearm has some pretty bad and painful scratches. Especially when they get covered in grease and grim.
2008 NISSAN TITAN
Crew Cab, FFV, Big Tow
Intake: S&B
Headers: Ceramic Coated Nismo LT's
Exhaust: Nismo Cat-Back
Tuning: Uprev
pigzsnout is offline   Reply With Quote
Old 06-17-2009, 11:03 AM   #2 (permalink)
Re: Nismo header install sucks!!
man that sucks to here this mine should be here this weekend. and was looking at doning them myself. mm maybe I will call around and see what it will cost me
05 cc black bt 4x4 black topper,uprev dyno tuned, volant cai, flowmaster 315/70/17 bfg tko
dksfowler is offline   Reply With Quote
Old 06-17-2009, 11:06 AM   #3 (permalink)
pinoytitan's Avatar
installing headers on this truck sucks!!! NO space whats o ever. Nismos aren't as hard as the DT headers.
Good luck!!!
2005 Blizzard White Nissan Titan IRC CREW MEMBER International Racing Club VK56
http://www.cardomain.com/ride/2052036
pinoytitan is offline   Reply With Quote
Old 06-17-2009, 11:09 AM   #4 (permalink)
layer1's Avatar
No one said it was going to be easy. Buddy and I did my long tubes in 5.5 hours and I have a 4x4. You just need the right tools and mind set. Yes, some bolts are going to be tough to get off and difficult to get to but thats the nature of the beast.
1/4 Mile in 14.89sec | 90.43mph @ 5900pnds
AKA: ScotchWhore
layer1 is offline   Reply With Quote
Old 06-17-2009, 11:44 AM   #5 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
sometimes i underestimate how long a particular task will take and feel demoralized.
then i think back to when i was in my teens working in my dad's shop and experiencing the same set back i experience when tackling projects on the titan.
the difference is that back then i was getting paid by the hour, and now it's just my free time. funny how that changes your perspective on things.
like the other day i was changing my oil, a very simple, quick job. you know what became the most time consuming part? CLEANING! I let the stealership change the oil last time and the mechanic was not to tidy about things... if you've changed your oil you'll know what i mean. the inside of the skid plate was coated with oil as was the cross member, sway bar, oil lines adjacent to the filter, etc.
hang in there, it's a tough job!
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
Old 06-17-2009, 11:51 AM   #6 (permalink)
chieflikalotapus's Avatar
Where did you get the nismo LT from and how much if you don't mind me asking
MODS: fiji blue pearl paint,33x12.50 toyo mt,20x10 eagle alloys, 3 inch body lift, 2.5 level kit,1" block rear,BullyDog Tuned,k&n air intake,Banks exhaust,Detroit trutrac,10k hid kit,Rear bilstein 5100,
chieflikalotapus is offline   Reply With Quote
Old 06-17-2009, 12:03 PM   #7 (permalink)
twistedfreedom's Avatar
Send a message via AIM to twistedfreedom
I wonder how you did that in 5.5 hours!!!!! you must have had a helping hand
overview
08 KC XE Galaxy Black, Color matched front and rear bumpers, De-Badged, Charcoal interior, "Carbon fiber" inserts
Sound
4 Infinity 6x9's, pioneer head unit, Kenwood 900w amp, Kicker L7 10" sub
Performance
K&N w/ airbox mod, Bully Dog GT tuner, flowmaster 50 series Dual 2.25" in single 3" out,2*, PRG 2" leveling kit.
Coming soon
UpRev, Nismo headers, JWT cams, IPT trans, Nismo cat back and My tail lights in your face
15.032 @ 92.48MPH
hp295.64 tq330.33
PINKBARBIEWHORE™
twistedfreedom is offline   Reply With Quote
Old 06-17-2009, 12:15 PM   #8 (permalink)
DeadRiver's Avatar
some tool with some tools helped him
The Urinator™
Old 06-17-2009, 12:18 PM   #9 (permalink)
Sounds about right.
overview
Sound
Performance
Coming soon
15.032 @ 92.48MPH
hp295.64 tq330.33
PINKBARBIEWHORE™
The Following User Says Thank You to twistedfreedom For This Useful Post:
DeadRiver (06-17-2009)
Old 06-17-2009, 04:27 PM   #10 (permalink)
I was gonna order them from leeparts.com but when I called to order them I was told the production has been cancelled. I was given a list of dealerships that have the headers in stock per the nissan parts database. I called the first dealership in West Virginia and was told $885 plus shipping. HA!!! I called the second dealership on my lst which is in Oak Ridge, TN. They had a set that they sold to me for $600 shipped. The set was installed and removed from a '05 titan. The CEL light was on due to the O2 sensor and the owner wouldn't sign acceptance of the vehicle like that. The dealership honored it, and removed them and refunded the owner. I got them as a 'open box' item. They were on the truck a total of six days, and looked brand new with hardly any exhaust suit in the pipes.
2008 NISSAN TITAN
Intake: S&B
Tuning: Uprev
Old 06-17-2009, 05:48 PM   #11 (permalink)
layer1's Avatar
You must have missed the part about Buddy and I..
AKA: ScotchWhore
Old 06-17-2009, 06:50 PM   #12 (permalink)
O-FiveCC's Avatar
Yeah its no fun install!! At least it is the easiest of the header install. It took me an 2 Titan friends about 4 hours to do mine. It helps having a couple extra people, cause someone can always take a break! LOL
Titanowners.com
http://videos.streetfire.net/video/0...-It_691843.htm
IRC VK56 Pit Crew Chief
13.735 @ 99.1 (Slicks)
2005 XE Crew Cab
Performance: Nismo CAI, Nismo Longtubes/NO Cats, Uprev, JBA w/ Magnaflow 22", Tru-track, 07 intake, Hellwig Traction Springs
Interior: Nismo SS gauges, 2 Sundown 9" Monitors
Exterior: painted Armada air-dam, 6 piece Billet grille, chrome handles, SE Mirrors, DDM 8000k HIDS, Bilstein 5100's, Springtech 2" shackles, OEM 20's, tinted tails/3rd brake light
Nitrous, and shift kit in garage...patiently waiting
O-FiveCC is offline   Reply With Quote
Old 06-17-2009, 07:22 PM   #13 (permalink)
pinoytitan's Avatar
took us about 6 hrs to install the DT headers on a 4x4 WITH a rounded nut...
Old 06-17-2009, 08:38 PM   #14 (permalink)
titanss's Avatar
It may suck, got my mechanic friend to install my Stillen's, but the first drive will make you forget all the time, aggravation and pain.
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
07 Pipes w/ 22" M/F Sound Clip
Old 06-17-2009, 08:58 PM   #15 (permalink)
Hawaiianbasshead's Avatar
I just got a quote from the local 4x4 shop owner (they did my buddies T JBA's, which he said was a mutherfuker) and they're doin mine tuesday quoted me $300 can't wait, I'm gonna keep on the PB blaster every day until then so as to insure no head studs break off I told him I'd keep on it too since he was quoting me such a low price... he asked me what I thought would be fair and I told him I wasn't sure, I was gonna tell him $400 anyway glad I kept quiet LOL he did my buddies for like 4 or $500 iirc JBA's w/welding the stock cat back on and crap.. I had him come out and see mine were LT/bolt on. IF he comes in for $300 I'll pay cash, and give him a case of beer as a tip, gonna ask him what he drinks. I didn't tell him about the cash or beer parts but I did tell him I'm gonna be needing new tires soon 35 12.5" 20 so he knows I'm gonna be a repeat customer
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 33x15.5 Swamper TSL/Sx on 16.5x14" Weld mountain crushers polished, ventshades, 5% tint all around, n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
Nismo Header, Magnafow Cat Install Order themaildude Titan Performance Modifications 1 04-24-2009 03:01 PM
Header Install - Who can do it? Warp09 South Western Forum 5 05-25-2008 09:31 PM
Header Install ... Warp09 South Western Forum 15 11-12-2007 10:21 PM
Reformed NISMO poser with header questions. Papa_D Titan Performance Modifications 2 07-01-2007 12:00 AM
Nismo Header Update Montoya Titan Performance Modifications 59 12-03-2005 08:10 PM
