Old 06-27-2009, 02:07 PM   #1 (permalink)
Qx_Indulgences's Avatar
Need Advice on improving mid range and top end
I have some extra $$ laying around now that its summer and i'm free to work wayyy more hours. I wanna improve the mid-range top end on this beast. WHat would be the best exhaust and intake combo for this? I'm currently running the 07+ pipes and thought about running dual spin tech super pro streets. Any advice would be appreciated. Thanks guys!
Stock Intake Ram Air Mod, Coolant Bypass & Screen Delete,Spintech Super Pro Street Dumped, K&N Drop in, Gutted Rear Cats, 325/60/18 Toyo Open Country A/T, Black Qx56 Grill , Black BT Mirrors, Tinted Tails
Qx_Indulgences is offline   Reply With Quote
Old 06-27-2009, 02:53 PM   #2 (permalink)
Re: Need Advice on improving mid range and top end
I believe JBA shorties will increase your mid/top end (don't jump on me if I'm wrong), after I had mine put on it made a difference in the mid and top end. Also maybe running a little bit bigger pipes like 2.50 inches.
2005 Nissan Titan SE 4x2 non big tow FFV
Performance: S&B CAI, Airaid TBS, JBA Headers, Magnaflow HF cats, Dynomax Bullet, Uprev Tuner Edition, PRG 2'' Leveling Kit
Audio: Tech12volts enclosure with 2 10'' Boston Acoustics subs with a Sony Xplod 800w amp
x32825 is offline   Reply With Quote
Old 06-27-2009, 03:03 PM   #3 (permalink)
Hawaiianbasshead's Avatar
I own/have both the volant and aFe and I kinda think the aFe has more low end but the volant I think may have upper end really trivial. on exhaust larger diameter or duals would be better for mid/upper one pretty common misconception I see thrown around alot is midrange and topend power meaning speedwise. exhaust will control rpm power but not so much speed which is more a side effect of where u make your peak power. so you plan on running your motor into higher revs or get more pull from 40+mph? this is a huge difference imo, more pull overall is on thing that would make a huge impact on pull @ 40+mph. intake exhaust and any handheld will get you quite a bit more pull imo.
so if you want a catback for high rpm I'd say probably the nismo dual setup is a good one. if you want to keep your pipes and just swap mufflers I'd say something that's a flow thru design not a baffled muffler like the spintech. the bullets would be flow thru I think. as well as other glasspacks and the powersticks ( I just ordered me a powerstick ) and as little bending/bends as possible would also be good for either. a JBA catback I'd recommend for more all around pull. this is going by piping diameters and judging from other peoples titans. I understand airflow and can somewhat apply it to exhaust setups so I'm comfortable with those two recommendations. they are also the most popular for a reason. I think the JBA will leave you more cash for an intake and programmer. I'd recommend getting both used so u can get all three instead of just intake and exhaust I've seen intakes for around $100 and programmers for about $240...
and the JBA can be had for around $400 so for about $700 you should be able to get all 3 or just the nismo catback really depends on your plans and what you mean by mid/high end power speedwise or rpm high reving power...
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 35x12.5 toyo MTs on 20x9" +18mm offset ultrawheels titan 6 black, ventshades, headlight covers, 5% tint all around and n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
Old 06-27-2009, 08:47 PM   #4 (permalink)
O-FiveCC's Avatar
Any set of headers, also us 04-06 VK56's can put on an 07+ Intake manifold and with a proper tune can gain top-end...also look into 2.25 b-pipes...I would suggest a flow-through muffler for top-end such as a Magnaflow, Bullet, Borla or the like...HF cats will help...Any intake will pretty much do the same, but I will say, when I got my AEM, the only place I REALLY felt it was on the top-end
http://videos.streetfire.net/video/0...-It_691843.htm
IRC VK56 Pit Crew Chief
13.842 at 96.98--8.78 at 77.75 1/8th 1.92 60' NA FST (pre-PGM)
2005 XE Crew Cab
Performance: Nismo CAI, Nismo Longtubes/NO Cats, Uprev, JBA cat-back, Tru-track, 07 intake, Hellwig Traction Springs
Interior: Nismo SS gauges, 2 Sundown 9" Monitors
Exterior: painted Armada air-dam, 6 piece Billet grille, chrome handles, SE Mirrors, DDM 8000k HIDS, Bilstein 5100's, Springtech 2" shackles, OEM 20's
NY-Trex wet kit, TransGo shift kit
O-FiveCC is offline   Reply With Quote
Old 06-28-2009, 12:07 AM   #5 (permalink)
SMOKEDYA2's Avatar
you can also do cams if your a 04-06. very sone you will be able to do it for the 07+ also
04 xe 4x4 smoke
-uprev tuned, doug thorley lt headers, 07 intake mani, k&n cai, gibson catback, cats deleted, tb bypass, tb screen removed, and active tuning ground kit
-prg mini lift 2.5" front and 1.5" rear, hankook 33" mt's, and aluminum diff cover.
-20% window tint, ddm tuning 8000k hid's, bug deflector, rain gaurds, mcgrille 4pcs grille, and painted rear bumper
-sony 1100watt amp, 2 polk audio 10's, and 1.5 farad capacitor.
SMOKEDYA2 is offline   Reply With Quote
Old 07-02-2009, 12:58 PM   #6 (permalink)
Alrighty for this month im gonna get an intake and exhaust so idecided on an S&B CAI and Two Maggy 14's Dumped before the rear axle. hows that sound?
Old 07-02-2009, 01:31 PM   #7 (permalink)
EDDIE FONZARELI's Avatar
i had a couple of different setups. i had stock pipes with muffler swap, true duals with 2.25 pipes & last is 2.50 y-pipe to 3" pipe to muffler and i can tell the most difference by far with the 2.50 fm y-pipe. i'm runnin a 3" in/out bullet muffler and afe stage 2 intake. this combo is the best of all 3 i had. decent low end, good mid, and excellent top, for me anyway.
it's hard to say what is the best combo because everyone likes different setups. but this here works perfect for me.
eDDie FonZareli
2005 SE 2wd
6" Procomp Stage 2 Suspension with a 4" Rear Block
3" Body Lift
CST CBDB
AFE Stage 2 CAI with BD 2* Timing Advance
3.00 in/out Bullet Muffler, Dumped
Custom 2.50 to 3.00 Exhaust Piping
37" Toyo Open Country M/T's
20x10 XD Rockstars
Smoked tails, Headlight Mod & Grille
2 10" Kickers, Kenwood Excelon Double Din
Powered by Fosgate
WHATS NEXT
PRG UCA'S
Coil Bucket Spacer
Deaver C10 Leaf Pack
Traction Bars
EDDIE FONZARELI is offline   Reply With Quote
Top end terminal speed? MotoJack Titan Performance Modifications 9 06-26-2009 04:04 PM
Front End Lowering Advice 2BIT Titan Suspension 4 10-27-2006 06:26 PM
Camper Top Advice yucaton_tom Titan General Discussion 12 07-15-2005 07:02 PM
ANY noise at ALL from engine's top end? stevnmd Titan General Discussion 16 02-07-2005 06:18 PM
Can't Find a High-End Shell/Top????? honeykeeper Titan General Discussion 4 10-18-2004 05:45 AM
