Old 07-18-2009, 07:53 PM   #1 (permalink)
New JBA exhaust install
Nice!! Replaced stock exhaust on 2008.5 LE crew. If anyone is on the fence about getting this exhaust, just get it. You won't be disappointed.
coolhub is offline   Reply With Quote
Old 07-18-2009, 08:02 PM   #2 (permalink)
BuckeyeTitan's Avatar
Re: New JBA exhaust install
Good to hear!! It's been a month and a half since I ordered mine but it's going on Monday
IRC VK56 Member
2005 Nissan Titan King Cab Se
Mods: Extang Fulltilt tonneau, AEM Brute Force CAI, Superchips Cortex 87 octane tune, Toyo A/T's, Next generation JBA exhaust
Fastest time ever at a track on ice in a 2wd Titan as far as I know: 60 ft 4.86 1/4 ET 22.17
Times on 5/9/09 - R/T .064, 1/4 14.849, 1/4 mph 91.62
Voted 2009 High School Nationals Best Import Truck
College beater:
2004 Dodge Dakota 4x4 extended cab
Mods: line-x, 10% tint rears 35% tint front, Extang Fulltilt tonneau, Sony head unit, alpine speakers all around, Rancho RSX shocks
Times on 6/3/09 - 1/4 17.275, 1/4 mph 79.29
BuckeyeTitan is offline   Reply With Quote
Old 07-18-2009, 08:29 PM   #3 (permalink)
OneQuick06's Avatar
Did you install it? If so, how difficult was it?
2006 Galaxy KC BT SE
Mods: Click here Pics: Click here
MonkeyPumperWhore™
OneQuick06 is online now   Reply With Quote
Old 07-18-2009, 09:30 PM   #4 (permalink)
O-FiveCC's Avatar
Nice!! It's definately a winning exhaust system
Titanowners.com
http://videos.streetfire.net/video/0...-It_691843.htm
IRC VK56 Pit Crew Chief
13.735 @ 99.1 (Slicks)
2005 XE Crew Cab
Performance: Nismo CAI, Nismo Longtubes/NO Cats, Uprev, JBA w/ Magnaflow 22", Tru-track, 07 intake, Hellwig Traction Springs
Interior: Nismo SS gauges, 2 Sundown 9" Monitors
Exterior: painted Armada air-dam, 6 piece Billet grille, chrome handles, SE Mirrors, DDM 8000k HIDS, Bilstein 5100's, Springtech 2" shackles, OEM 20's, tinted tails/3rd brake light
Nitrous, and shift kit in garage...patiently waiting
O-FiveCC is online now   Reply With Quote
Old 07-19-2009, 01:31 PM   #5 (permalink)
Hawaiianbasshead's Avatar
removing the stock exhaust is really the only pita. a sawzall can fix that any catback on a titan should be pretty straight forward as it's pretty open under there. some smaller or more cramped cars can be a different story, but the titan eh, few bolts and clamps and u should be good. I'd personally weld the pieces solid
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 33x15.5 Swamper TSL/Sx on 16.5x14" Weld mountain crushers polished, ventshades, 5% tint all around, n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
The Following User Says Thank You to Hawaiianbasshead For This Useful Post:
OneQuick06 (07-19-2009)
Old 07-19-2009, 06:23 PM   #6 (permalink)
I did have a problem on the stock exhaust. I get to the last nut on the cat and it dosen't won't to budge. I had sprayed pb blaster the night before, but it still wouldn't move. Sprayed it again and again. I ended up stripping the nut on the bolt. Went to Sears and bought a damaged bolt/nut remover set for $20. Finally it came off.
Also, on one end of the muffler it was bent a little where it connected to the next to last pipe. Did not know this untill I was trying to make the connection under the truck. So had to take the muffler back off and bend out the pipe with a pair of channel lock plyers. I guess it got bent during shipping.
Other than those two issues, everything went fine. It was worth the trouble. It's a nice sounding exhaust, not to loud, just enough. You can definitely tell the difference between it and stock. After you get it installed and crank it up for the first time, you are going to have a smile on your face.
The Following User Says Thank You to coolhub For This Useful Post:
Old 07-19-2009, 07:16 PM   #7 (permalink)
O-FiveCC's Avatar
Good write up, I agree, the JBA is arguably one of the best performing exhausts for this truck, and just like you said, not too quiet not to loud. Of course, I've forgotten exactly what it sounded like normal, now I run the headers and no cats, so its a bit louder
Titanowners.com
2005 XE Crew Cab
Old 07-20-2009, 02:12 AM   #8 (permalink)
SaintsTheMetal's Avatar
Send a message via AIM to SaintsTheMetal
I have the JBA also, definitely not a difficult install. Just follow the instructions and it shouldn't take more than a couple hours. I didn't use PB-Blaster or anything, I just had to use 2 crescent wrenches one torque'ing the other one to get the stock crossover pipe and other pipe off of the midpipes. I TIG welded everything together from the crossover pipe back to the tip. Unfortunately one of my hangers developed a squeak that I have been having a real big problem fixing ever since...
Performance wise, definitely worth the money, as it is a cheap exhaust! I gained ~15HP and ~9ft*lb over just my Injen Intake from my JBA. Intake and JBA together I put down 287 HP and 342 ft*lb, without VVT.
2006 Nissan Titan SE KC 4x2 Metallic Black
286.90 RWHP and 341.99 ft/lbs Torque
Adopted September 22, 2007 , And Love It!
Mods:
Injen Powerflow Intake
JBA Catback Exhaust
Retrax Bedcover
Chrome Mirror Swap
SaintsTheMetal is offline   Reply With Quote
Old 07-20-2009, 03:48 PM   #9 (permalink)
Book0825's Avatar
Do you have any annoying exhaust drone? I'm looking into getting an exhaust and have it narrowed down to either a JBA or Gibson.
ADD ONS: BANKS RAM AIR, NASTA TUBE STEPS
Book0825 is online now   Reply With Quote
Old 07-20-2009, 03:54 PM   #10 (permalink)
sudden urge's Avatar
The JBA does droan. I'm very picky about that, so I cut off 14" of the tailpipe and eliminated most of the droan. I have a thread on it here somewhere.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
sudden urge is online now   Reply With Quote
The Following User Says Thank You to sudden urge For This Useful Post:
Book0825 (07-22-2009)
Old 07-20-2009, 04:23 PM   #11 (permalink)
O-FiveCC's Avatar
It drones but not bad IMO, but of course, I am not picky about it. If you wanted, you could add another resonator, or add the Zoomers Cannon resonator exhaust tip if you did happy to be very picky. Its not nearly as bad as some other exhausts, but it is there. The Gibson is a very quiet exhaust, so maybe thats what you want? I was very close to getting a Gibson before I got my JBA
Titanowners.com
2005 XE Crew Cab
Old 07-20-2009, 07:35 PM   #12 (permalink)
If there is some drone, it's minor because it dosen't bother me. I'm very happy with the sound, alot better than stock. Definitley worth the money. I got the JBA for $334 shipped from Autoanything and had it in a week.
I had narrowed it down to the JBA and the Banks. The Banks is louder and it's around $200 more. Two things I didn't want. Get the JBA.
Old 07-20-2009, 07:39 PM   #13 (permalink)
Buckeye, did you get your exhaust installed today?
Old 07-20-2009, 08:46 PM   #14 (permalink)
The JBA droned for me a bit that it annoyed me around 1900 RPMs or so, but now a couple months later I don't notice it at all
Mods:
JBA Catback Exhaust
Retrax Bedcover
Chrome Mirror Swap
Old 07-20-2009, 10:11 PM   #15 (permalink)
Yeah it's still at the shop. I talked to them at 4 and they were taking apart the rear axle to fix the rear axle seals. I should be getting it later. My guess is around 2 or 3 o'clock cause they're only open 1-8.
and I have a question for some of the heavy racing modders what should my next mod be?? My goal is to hit 14.5's. And to not take away from coolhub post any advice/opinions in this thread. Thanks
Trucks in the Shop...
IRC VK56 Member
College beater:
JBA exhaust install Kitts Titan General Discussion 11 02-17-2009 06:21 AM
JBA or Magnaflow Install David_Severson Titan Performance Modifications 2 04-10-2008 07:26 AM
JBA Install question jettitan73 Titan Performance Modifications 5 02-07-2008 01:58 AM
New Exhaust project...are there Diff JBA Exhaust? markislive78 Titan Performance Modifications 3 08-19-2006 12:48 PM
