Well, I found out we have Cobb Tuning software, but have to call them Monday to see if we can read a truck and send it to them. Otherwise, we'll buy UpRev for the dyno. Either way, it's a done deal guys.
Here is the dyno we did with the Stillen kit, the boost stays steady, just like a turbo, except I am not robbing any power with the turbo.
The Stillen had aux injectors, which is not the best way to add fuel. We are going to change out the injectors and remap for 2 bar. I should have the kits up this week on the site.
Someone point me to an admin as I would like to become a supporting vendor.
Yeah, Stillen's injector set up isn't the best as you have seen. I also heard it's better to rip out that p-back set up, flash with UpRev, and add a walbro fuel pump too.
I'm not sure if your company does this, but have you ever thought of having a trans upgrade as an option as opposed to IPT, Level 10, Transgo?
2006 LE CC 4x4 3.36 Performance: Injen CAI, Custom 3.5" RAM Air Mod, Custom 2.25" MF CATS B-Pipes, 07 Exhaust with MF Swap, Nismo LT Headers, 2007 Intake Manifold, Tuned by DF6_Titan & Me Interior: WeatherTech Floor mats, Kenwood DDX814, 2 12W3v3 JL Subs, Boston Pro 6.5 Comps, Boston Acoustic Rears, RF 1500-BD, PDX 4.100, Scoshe Dash Kit, Monster Cable 200 Series RCA's, Stinger Amp Wiring Kit, QX56 Center Console Lid Exterior: 6000k Fogs, 4300k Lows, Black 1 PC Upper Replacement Billet Grille, Black Headlights, De-chromed, De-Badged, Tinted Tails Suspension: ProComp 6" Lift, MX6 Coilovers, MX6 Rear Shocks, PRG Shackles, 20" American Racing rims, 35" Nitto Mud Grapplers My track vids!
The Following User Says Thank You to Warp09 For This Useful Post:
bestatchess is a mod who can probably help you with becoming an administrator....Hey man, i have been wanting to get a Transgo shift kit, but I would need it installed. Can you guys do this and how much would you charge? Any way you guys could use your resourses and find any upgraded silenoids for my tranny to install with the shift kit? The transgo shift kit is about $260 and the IPT VB mod which already has upgraded solenoids is about $800...So I am seeing is I can get the Transgo kit and upgraded solenoids for cheaper then the IPT VB....I might (probably will) come to you guys to tune me once I get my 90MM TB and probably again with Nitrous...I'm glad you guys are back around
If you supply the Transgo and fluids, I'll get it done for 1 hour labor. I have always have good results with the Transgo kits. Not sure on the solenoids, but I can tell you, when we do the turbo kit, you will need higher line pressure to keep the tranny from burning up.
I did go over the turbo install info by relentless. They had a broken ring land. Once back together, they set it up for 9 psi, and even though I did not see the sheets, claimed 516rw.
Didn't you say you guys ran against it at the track?
I'll definitely have Ross send me some pistons for bigger builds, but for now 5-6 psi and a perfect tune will keep the stock pistons safe.
ya, we raced them at the track... The Bradenton Track. Here is a quick clip... We taught relentless how to launch this suckers... i gave him more than a half a second head start (as you can see in the vid).
Yeah they were running (once they launched a little better) the same as me an Pinoytitan, but I believe they trapped about 8-10 MPH higher than me at one point LOL
The mph looked like 98? Did they start to pull away half track?
after i launch i pulled up to them very quickly... after that, no one pulled... we stayed neck to neck all the way down... they didn't have a posi rear end so it factored in as well... but they should have got me after.
__________________ 2005 Blizzard White Nissan TitanIRC CREW MEMBERInternational Racing Club VK56
You guys need to find me a used Titan below $10,000. I found 3 in the US, one for 8900 in Ga, but the lower the better.
Those guys where making 480-518hp and only trapping 98? My Ram back on motor would trap 103-105. That was before the turbo.
Guys, find me a truck...
That was a FUN DAY!!!
Also interested in a TransGo Kit install.
__________________ 2005 NISSAN TITAN SE KC IRC VK56 TEAM MEMBER performance: UP/REV CUSTOM TUNED
Custom 4" Ram Air / Fujita Intake w/ DEI Heat Shielded Box / AirRaid TBS / TB Screen Removed / TB Coolant Bypass / '08 Intake Manifold / Trans. Cooler / Nismo LT Header's / Banks Monster Exhaust / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding System / Burn-Out Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140 exterior:
Ruff Racing R286 22"x9.5" Chrome's w/ 305/45/R22 Nexen Roadian HP's / Stillen Diff. Cover / ST 2" Drop Shackles / Traction Springs / DDM 8K HID's / Armada Air Dam / SolarGard Tint / Tow Hook's / Debadged 13.91 @ 96.82MPH
