Go Back   Nissan Titan Forum > Titan Discussion > Titan Pictures & Media Post
Titan Pictures & Media Post Post pictures, media, etc. about the Titan that you find in here. Also -- Please see the Nissan Titan Photo Gallery - All users have access:!
Old 11-12-2009, 02:10 PM   #1 (permalink)
$ickTitan's Avatar
Pics after Lift! (CST, SAW, Radflo, etc.)
Here are some pics of my new lift. Specs are as follows:
Front:
CST 4'' Spindles
SAW Extended Length Coilovers set to 3''
7'' Total in front (Looks more like 8''.)
Rear:
Deaver C30 Spring Pack (2.5'')
2.5'' Block
PRG Carrier Bearing Drop Bracket
Radflo Remote Reservoir Shocks
5'' Total in rear
As you can see in the pics, it sits pretty level now. I had a 1.5'' block before with the deavers and the front sat noticeably higher.
Before Install pic:
During Install pic:
After:
Next to WhiteTitanSe's beast:
Thanks to WhiteTitanSe for the install. The truck rides and handles like a dream. I would highly recommend this setup. Next up is headlight mod and 35's. I will get some better pics when I put some 35's on there. The 33's look pretty small now!
2006 Titan Crew Cab LE
Exterior: 20X10 Moto Metal 951's Black, 35X12.50X20 Nitto Trail Grapplers, RBP RX Series 3 Piece Grille, NFAB's, DDM 6000k HID kit, Truxedo Lo Pro Tonneau.
Performance: Superchips Tune, S&B Cold Air Intake, Flo-Pro Max Muffler with Corsa Tip.
Audio/Interior: JVC KW-AVX810 Touchscreen DVD Player, Rockford Fosgate Power Series 6.5'' Components, Tech12Volt Enclosure with 2 10'' Boston G1 subs, Rockford Fosgate P200.2 Amp, Carbon Fiber Interior Kit.
Suspension: CST 4'' Spindles, SAW Coilovers, Deaver C30 (2.5'') mini pack, 2.5'' Block, Radflo remote reservoir rear shocks, PRG CBDB.
$ickTitan is offline   Reply With Quote
The Following User Says Thank You to $ickTitan For This Useful Post:
Nismo4life (11-13-2009)
Old 11-12-2009, 02:17 PM   #2 (permalink)
EDDIE FONZARELI's Avatar
Re: Pics after Lift! (CST, SAW, Radflo, etc.)
man that looks siick bro. when you get the 35's it's gonna give you another 2" in height. body lift will put you around 11-12" lift and you'll be ready for 37's.
GO TOYO's!!
2005 Nissan Titan SE Big Tow Package
52" Front Fender, 48" Rear Fender
Procomp Stage 2 Kit, PRG Upper Arms, 3" Body Lift
20x10 -24 offset XD RockStars Wrapped with 37" Toyos
1 1/2" Wheel Adapters
CST CBDB
PRG Drive Shaft Spacer
AFE Stage 2 Cold Air Intake
BDPP 2 Degree Timing Advance
Custom 2 1/2 to 3" Y-Pipe
3" In/Out Dynomax Bullet Muffler, Dumped
N-Fab Works Heavy Duty Traction Bars
Head Light Mod & Grille Mod
Black Trim Conversion
Bedliner Front & Rear Bumpers
Factory Integration
2 12" Kicker Comps Powered By Rockford Fosgate
EDDIE FONZARELI is offline   Reply With Quote
The Following User Says Thank You to EDDIE FONZARELI For This Useful Post:
$ickTitan (11-12-2009)
Old 11-12-2009, 02:19 PM   #3 (permalink)
my error, a BL will put you at 12" maybe 13.
CST CBDB
Factory Integration
Old 11-12-2009, 02:19 PM   #4 (permalink)
$ickTitan's Avatar
Thanks! Yeah, tire shopping has begun... Just gotta get some more money together first.
Old 11-12-2009, 02:21 PM   #5 (permalink)
also if you do the BL where ever you're at now as far as height...
add 4" from the 37's & add 3" from the BL.
total of 7" on top of where you're at now.
DO IT BRUTHA!
CST CBDB
Factory Integration
Old 11-12-2009, 02:22 PM   #6 (permalink)
$ickTitan's Avatar
Originally Posted by EDDIE FONZARELI View Post
also if you do the BL whereever you're at now as far as height...
DO IT BRUTHA!
haha I may do that in the future but I gotta enjoy it at this height for a while! That would be pretty massive though...
Old 11-12-2009, 02:23 PM   #7 (permalink)
Pops's Avatar
SWEEET!!!!
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 11-12-2009, 02:25 PM   #8 (permalink)
you'll be sittin even with whitetitanse.
here's somethin else to think about. if you do buy 35's and end up doin the BL, the 35's will now look too small. then you'll have to fork out more money for 37's.
it does look siick the way it is though. i dig it bro!!!
CST CBDB
Factory Integration
Old 11-12-2009, 02:25 PM   #9 (permalink)
Well done Sir. Yeah the move to 35s should give you an inch and fill up the wheel wells. Hey I noticed you are rolling without a roll bar. How do you like it?
How much does it cost to have Greg mail the ish to you?
rsh46 is offline   Reply With Quote
The Following User Says Thank You to rsh46 For This Useful Post:
Old 11-12-2009, 03:02 PM   #10 (permalink)
gearhart4's Avatar
Send a message via AIM to gearhart4
jealous
2006 SE CC Radiant Silver
Superchips Cortex 93 Perf
2 degree timing advance
20% tint sides, 5 over 20% tint back
2 Kenwood 10's, Profile 1200 watt amp
Custom exhaust
Painted calipers
Silverstar Ultra bulbs
Color matched front bumper and grille
DIY mesh grille
OEM step rails
Debadged
DIY air box mod
PA CREW
gearhart4 is offline   Reply With Quote
The Following User Says Thank You to gearhart4 For This Useful Post:
Old 11-12-2009, 03:03 PM   #11 (permalink)
techdude01's Avatar
Thats fricking awesome!
techdude01 is offline   Reply With Quote
The Following User Says Thank You to techdude01 For This Useful Post:
Old 11-12-2009, 04:30 PM   #12 (permalink)
wvmoney's Avatar
if you dont mind me asking, how much did all that run you?
09titan SE
BUSTED
wvmoney is offline   Reply With Quote
The Following User Says Thank You to wvmoney For This Useful Post:
Old 11-12-2009, 05:14 PM   #13 (permalink)
USN HM 350Z's Avatar
looks great man.
2008.5 Nissan Titan -JBA exhaust piping with Bullet muffler, CST, Bilstein, 3inch PA Body Lift, Toyo AT's, PRG traction bars, CDT Audio, Sundown Audio, RE Audio, ipod (Thanks Tech12Volt).
2009 Subaru WRX - SPT Cat Back Exhaust, Cobb Access Port, SPT Heat Shield, SPT Front Strut Brace, Alpine W205 with full ipod control
USN HM 350Z is offline   Reply With Quote
The Following User Says Thank You to USN HM 350Z For This Useful Post:
Old 11-12-2009, 05:21 PM   #14 (permalink)
bills1974's Avatar
Send a message via AIM to bills1974
Looks really nice man, love the red and black...only thing I'd do is debadge.
2008 Titan SE CC, Popular Package, Big Tow, Bed Utility Package, Sliding Bed Extender
Click here to see my mods
Click here to see my pics
Wife's Ride: 2009 Infiniti G37 Coupe
My Other Ride: 2007 Sea Doo Speedster 200
AKA: Crossdresser Whore™
The Bald Avenger®
"Why is the rum always gone?"
bills1974 is offline   Reply With Quote
The Following User Says Thank You to bills1974 For This Useful Post:
Old 11-12-2009, 05:21 PM   #15 (permalink)
PureMoto193's Avatar
Looks good man.
08 XE CC 4X4, Debadged, Fabtech 6in Lift, 20" Kmc Hoss's, Terra Grapplers, Colormatched Rear Bumper, Painted calipers(red), Tinted tails, 8k HIDs, Mesh grill, Wicked Flow exhaust Dumped ,Aem CAI, 2* Advance, Kenwood Double Din
PureMoto193 is offline   Reply With Quote
The Following User Says Thank You to PureMoto193 For This Useful Post:
CST Spindle Lift Installed w/PICS AgTitan06 Titan Suspension 37 04-20-2007 04:45 PM
Pics of CST lift NCOREY Titan Suspension 1 03-09-2007 03:06 PM
Cst Spindle Lift Pics? LpLove Titan Suspension 1 02-04-2007 11:06 PM
4" CST lift pics? or any 4" inch lift TheTanMan Titan Suspension 15 01-30-2007 09:28 AM
radflo pics Howie Kaluha Titan Suspension 6 12-04-2006 11:13 AM
