Hey everybody, Im going to start a little thread that will keep track of my truck and how it has come along to where its at/will be at.
So ill start with what ive already done:
Here was my first project on my truck, the prerunner bumper, i built it when i was 16.
Then was the rear bumper as i was tired of getting high centered on the hitch and bumper, so i made one for a little more clearance, its made out of 1/4" thick plates, with a 2 1/2" .250" wall DOM tube through the center for bracing.
Ive just started putting in my new 10" SAWS with stock a-arms, and a shock hoop. So far here is what Ive got:
Truck goes in the backyard, where it will stay for about a week. Yes, I have my tow strap wrapped around my bumper. Leave me alone. I only get like 3 hours each day to work on it after school, so this weekend i should be able to knock it all out! (hopefully)
I will continually update this thread with my progess!
2005 Titan XE KC 2WD w/ Dirt King Mid Travel Kit: Weighing in at 4200lbs
Truck Build:
Location: DirtKing's fab shop,Sant Maria,and Woodlan Hills Ca.
iTrader Score: 12 reviews
Re: 2005 TITAN Prerunner Build
subscribed
__________________ www.DirtKingFabrication.com http://legitaccessories.com/ Recognizing that I volunteered as a Ranger, fully knowing the hazards of my chosen profession, I will always endeavor to uphold the prestige, honor, and high esprit de corps of the Rangers.
B!tchin! cant wait to see this build progress. you gonna be reinforcing the frame and shock hoops right? i'm sure you been talkin to nick about it lol.
__________________ 2011 White CC pro4x
Flowmaster Y
Banks Muffler
Airaid MXP 4" Intake
PRG UCA's
Extended travel Sway-Away 2.5 coilovers
PRG Camber Bolts
Homemade Traction Bars
Fuel Boost 18x9
Nitto Terra Grapplers 295/70 18
Front BORA 1.25 Wheel Adapters/ Pinch Weld Mod
6K HID's
10" Sub/Kenwood Amp
Oh nick has been helping me for the past 3 or 4 months lol. Nick is a VERY nice guy, and very helpful! I would always recommend him! As for the build right now, yes, the frame is getting plated with 1/4" Steel (I like overkill ) then a lot of reinfocing with the tubing!
Im as anxious as you are guys!
Truck Build:
Remember when you mount your shocks that you will have more drop travel with a long travel kit that your stock arms so be sure to mount your shock low enough so you arent limited by you shock when you throw on some new arms. Although with some 10" shocks I doubt you could mount them high enough to have to worry about that. lol
Cant wait to see pictures of the install.
I want to do a shock tower and grind off the stock coil bucket just so I can mount my reservoirs on them!
2006 Nissan Titan CC LE 4x4 Offroad Package.
Mods.
Stillen Supercharger, Stiegemeier blower porting, intake manifold porting, 90mm snout, FT90, 550cc injectors, Walbro 255, Uprev tuned w/line pressure, Airaid MXP 4" Intake, Banks Exhaust, Stillen long tube headers with Cajun 2.5" catless b-pipes, vibrant UQ, Stillen CSF 2 core radiator, Bully Dog BDGT to monitor.
Pro-Comp 6" lift, Radflo 2.5" External Reservoir Coilovers, PRG Custom billet spacer, PRG Upper Control arms, C-30 Deaver, Prg Shackles, Prg Drive Shaft Spacer, Prg Offroad Traction Bars, Toyo Open Country A/T 325-65/18 on XD Monster 18"
Stillen Cross drilled and Slotted Sport rotors in front and rear with Stillen Metal Matrix brake pads.
Billet Upper and Lower Grill, 55 w. 6000K HID's in low-beams, 35w. 6000K HID's in fog lights, Glo-Shift Trans temp, Water temp, and Oil Pressure gauges in A-Piller, 5% Tint on all rear windows and 15% on front windows.
459.4hp and 447.3 lbs.
Saving $ to install
AEM water meth injection, 2.5" pulley, Uprev Maf, retune, smoked trans on the way
you should put your sway bar back on after installing the c/o's ha
I removed my sway bar after I installed my Radflos and the ride is great but on high speed corners like on ramps and you hit a bump my truck gets alot of sway and you really have to concentrate around corners. The body roll is so much fun around corners though feels like a built truck lol. After I install my traction bars I am going to try and remove the bar again but until then the drive up I 17 up and down the mountain needs the sway bar for those corners or I just go too fast to hear my truck echo off the mountain.
Mods.
Saving $ to install
The Following User Says Thank You to yamahatitan For This Useful Post:
Ill tell you, cutting off the coilbucket/bump stop took the longest, i was using a grinder with a cut off wheel and it was working great, very fast, just couldn't get to certain parts, so we broke out the torch!
Truck Build:
Ya i have thought about doing it just need someone that can weld it up.
My stock coil bucket is all trimmed up to make room for the droop and my external reservoir hose wanted to rub on the drivers side so I ground out a knotch so it wouldn't rub.
Mods.
Saving $ to install
and ya bro, i miss the drives up the 17 to flagstaff in my old truck with the banks catback. haulin *** around the slow drivers and scaring them with the banks.
Flowmaster Y
Banks Muffler
PRG UCA's
PRG Camber Bolts
Fuel Boost 18x9
6K HID's
10" Sub/Kenwood Amp
