Titan Pictures & Media Post
Post pictures, media, etc. about the Titan that you find in here. Also -- Please see the Nissan Titan Photo Gallery - All users have access:!
Alright, I finally got around to putting some pictures up. I've had the toolbox since October and the PRG kit on since Christmas. I'm very pleased with both. I also took a Yakima bike fork mount and modded it to slide into the utilitrack. Check my album in the photo gallery for more picts and larger ones: Link
Looking good. Question on the bike fork mounts. Can you describe what hardware you used to get them in the utilitrack. I need a way to haul bikes. What do you ride? Mtn or road?
__________________ 2004 Nissan Titan SE KC 4x4
Mods Interior: Husky Floor Liners, Wet Okele Seat Covers (Front and Back) Exterior: Pro Tech Headache Rack, Custom built UWS Toolbox (Dented upon shipment), 15% Tint I.C.E. Clifford RSX Matrix 3.5 Responder 2-way Remote Start and Alarm, Kenwood DDX-7015, Kenwood KHDC710 Music Keg, JL Audio 4/300 amp, JL Audio 500/1 amp, MB Quart PCE216 6.5" components, MB Quart PCE269 6 x 9" Components, Jl Audio 10w6v2, Pac- Swix, Acelevision Flush Mount Camera, New ground wiring w/ battery terminals and D block Suspension: 6" Fabtech Lift Kit Wheels and Tires: 18 x 8.5 Enkei RT6 (Black Centers), 35/12.5/18 Toyo Open Country M/T On Order: Gisbon Split Rear Dual Exhaust, PIAA 510 Driving Lights, PIAA 2100 Fog Lights
Is that a urethane spacer between your PRG spacer and the top plate of the coil? Seems like that would leave too much flex in the mounting hardware and could lead to failure. I posed the same question to Nitrous Enterprises, btu never rec'd a response.
I took the two Utili-track "locks" and removed the bolts from them. The last few threads are rounded to keep you from backing it all the way out, so I locked it in a vice and rotated them out. I then got some bolts from Lowes that were the correct length/thread count/diameter and used some lock and flat washers to secure the bike mount to the utilitrack locks. Then simply slide it on the track and tighten it down. You could do something similiar just by using a square washer that is the right size for the track. A round flat washer would work as well, but it would be more difficult to tighten.
I ride mountain, well at least I used to. It's pretty flat in LA*.
Thoughts, facts, opinions appreciated!
Yes, it's the small spacer from my Skyjacker "Daystar" kit. I got the 2" PRG kit then used that rubber spacer to add some additional height. I talked it over with Greg and he didn't see a problem with it. In hindsight I'd probably install it between the shock mount and PRG spacer, but it shouldn't cause any problems. In either setup there is still going to be a piece of rubber being compressed by bolts between two pieces of metal. Same applies for the normal Daystar install.
*Lower Alabama
Couldn't tell you the exact brand, as it was rebadged by the truck shop I bought it from, then debadge by me. They told me they bought from UWS, and it had the same model number that UWS advertises.
2001 Polaris Sportsman 500.
Yea I noticed your clemson sticker after I posted, origanally I noticed you were from L.A..I was born in Dothan. I miss the boiled peanuts.. AND WAR DAMN EAGLE..... ......
Happiness Is Beating Bama in Anything, Anytime, Anywhere
"The deadliest weapon in the world is a Marine and his rifle"
hey man looks nice can i ask where you got them (a web site or phone number) and how much ? does ur truck still sit level and it gives about .5 in of lift the space not the leveling kit thanks man
