Titan Pictures & Media Post
Post pictures, media, etc. about the Titan that you find in here. Also -- Please see the Nissan Titan Photo Gallery - All users have access:!
PRG Performance Kit w/SAW's
Born 9/2004
Bottle opener from some bar supply on the net' but I did the mounting with alum plate and fabed the cap catcher below...
Class 40, bike 406x Kent Perkins/Mike Langer.
Actually 2 teams under PSP Racing, the other was a 30 team Mike Mann. Each had their own chase crew, but all worked togather.
The 30 team did fair, pulled a sixth spot, the 40 team was in third just before Erendira beach. Rider got pitched off the bike into a bunch of barb-wire, gut himself open enough he was out of the race, got another rider to replace him, but many hours down...
Dented the bed? It's tied down real tight, so no slaming the bed, but just the weight?
Born 9/2004
Tied down real tight gets loose in the whoops, so it was banging up and down.
Now I put it vertical in the left front corner, no issues in the rough.
I can see that...With my present setup I can get a bike loaded in on the rt side. Most of the time I haul a complete bike to strip parts off if needed.
I'll keep a close eye on the straps in the future, thanks
Born 9/2004
And I don't see how much movement the wheel would have if belted down firmly... but experience tells where theory fails. I'd trust kartman's word on this one.
Andrew
__________________ A.K.A. Whore Without A Cool Whore Name
Here's my truck and an angry little force-fed 4-banger:
What are those things attached to the uni-trak above the bottle opener? are they modified stop cleats? or is that what the newer Titans are coming with?
__________________ - 2004 Galaxy Black KC OR 4x4 -
Towing Mods: B&W gooseneck hitch, Nissan aluminum finned diff cover, Amsoil 75w-140 synth gear lube, 7-way plug where the 12v bed outlet used to be.
