Old 10-16-2009, 12:19 PM   #1 (permalink)
Snakes's Avatar
help! Ticking noise!
I own a 2004 Titan KC, when the truck is cold and i start it up, a real dominent ticking noise occurs, it will last until the truck warms up. I was thinking its a worn out bushing in the exuast somewhere, but it sounds like its coming out of the oil pan, has anyone had this same problem? I dont want to take it into nissan and get charged out of the yingyang for a problem that i can fix myself! any suggestions?
If you ain't FIRST your LAST!
Snakes is offline   Reply With Quote
Old 10-16-2009, 12:28 PM   #2 (permalink)
m1key's Avatar
Re: help! Ticking noise!
manifold leak maybe
http://i612.photobucket.com/albums/tt203/m1key808/pics006-1.jpg
m1key is offline   Reply With Quote
Old 10-16-2009, 12:29 PM   #3 (permalink)
Yahooligan's Avatar
Titans are known to have noisy fuel injectors, mine are definitely pretty noisy when the engine and ambient temps are cold. Quite noticeable inside while idling at a stop light or pulling out of the garage.
I posted up an audio clip a while back of the noise, let me see if I can find it and you can see if it's the same sound you hear.
Could also be a leak in the exhaust manifold, these are also common and get less noisy once warmed up.
The dog: 2005 Titan SE CC 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, Roadmaster Active Suspension, SnugTop Sport shell, 5000k HIDs
The fish: 1984 Scarab 21SS - Marine Power 454 - FOR SALE
Yahooligan is offline   Reply With Quote
Old 10-16-2009, 12:29 PM   #4 (permalink)
TI'TNTUFF's Avatar
Could be exhaust manifold crack, as it quits when warmed up.
Injector tick keeps on ticking after warm up.
2006 Titan 4X2 XE KC Majestic Blue; Built-05/04/2006, Bought-05/29/2006
All weather floor mats, Under seat storage, Receiver hitch, Permatron Filters, Undercover tonneau cover, Rino Spray in liner, Hella Angel Eye driving lamps
TI'TNTUFF is offline   Reply With Quote
Old 10-16-2009, 12:49 PM   #5 (permalink)
Yahooligan's Avatar
FWIW, my injectors quiet down once the engine warms up and they are definitely noisier with a cold engine in "cold" weather. Inside the cab it sounds like a lame PowerStroke diesel common-rail injection without the diesel knock.
Old 10-16-2009, 01:03 PM   #6 (permalink)
Nemesis6978's Avatar
Mine does it to...so annoying.i took mine to the dealer to have them look at it cause i thought it was manifold crack and all they told me was normal injector noise,if ya ask me they dont want to spend the money on replacing the manifolds.
Nemesis6978 is offline   Reply With Quote
Old 10-16-2009, 01:10 PM   #7 (permalink)
I have cracked manifolds and they are way louder than the injector ticking. To me, the injector ticking sounds more precise and defined, whereas the exhaust ticking has a "mushier" ticking sound and is particularly obtrusive if you drive with the window open alongside a concrete barrier or through a tunnel.
Old 10-17-2009, 08:33 PM   #8 (permalink)
soljaslimm's Avatar
you guys find anything that helps quite down the ticking of the injectors? any fuel additives?
soljaslimm is offline   Reply With Quote
Ticking Noise PRJ Titan General Discussion 9 05-16-2008 06:20 PM
Ticking noise? Steelyeyedone Titan Problems & Dealer Service 1 05-02-2008 04:27 PM
ticking noise billaj Titan Engine, Transmission & Drivetrain 3 10-18-2007 01:24 PM
ticking noise cdbformula Titan General Discussion 1 09-01-2007 04:09 PM
Ticking noise..... TitanNorth Titan General Discussion 47 12-22-2004 10:01 AM
