Old 10-28-2009, 05:52 PM   #1 (permalink)
[T.J.]'s Avatar
T won't start, no spark!!
drove it the nite before, ran fine. got up to go to work on the first cold morning of the season and it wouldn't start. turned over and over but wouldn't crank. battery was strong, not the problem.
had the flickering lights consistent with the IPDM failure a couple months ago, alot of ppl are having that problem and mine would have went soon anyway so i just went ahead and replaced it. didn't fix the problem.
pulled one of the plugs and hit the key. no spark.
anyone have any suggestions that would cause my truck to just die right out of the blue other than the IPDM and battery because both are brand new. it doesn't run AT ALL, just turns over and over. so think of something that would prevent spark not just run ruff, something that would keep it from running at all.
2004 CC Black on 26's
Mods: 26" Lexani LX7, Pioneer AVIC f900bt, headrest screens, sun visor screens, and rear flipdown, Crunch 1500.1 powering, 2 Kicker Comp 12's (rear), & 2 Kicker CVR 10's (front), all in Tech12volt boxes, SPL 1000.2 powering, 2 selenium supertweets, & 2 selenium horns, PRG leveling kit, leather buckets, Volant CIA, VHT nightshade on taillights, Flowmaster exhaust
Future and final mods: Superchips Cortez or Flashpaq, tinted windshield, TB spacer, Armada airdam, and maybe a set of headers.
[T.J.] is offline   Reply With Quote
Old 10-28-2009, 05:53 PM   #2 (permalink)
[T.J.]'s Avatar
Re: T won't start, no spark!!
couple things that crossed my mind was.... chipped key bad, ecu/comp
Old 10-28-2009, 06:02 PM   #3 (permalink)
walleeme's Avatar
Swap the relays in the IPDM and see if it starts.
My has almost nothing compared to some of you guys, but I still like it.
Red meat is not bad for you.
Fuzzy green meat is bad for you.
You know you had a great night last night when you make it home the next day missing at least half your clothes.
Let him that hath understanding count the number of the beast: for it is the number of a man; and his number is Six hundred threescore and six.
Iron Maiden
Integrity is someting you cannot buy. You either have it, or you don't. You do not want to not have it.
http://s3.bite-fight.us/c.php?uid=181043
walleeme is offline   Reply With Quote
Old 10-28-2009, 06:06 PM   #4 (permalink)
Yahooligan's Avatar
Also, was the spark plug grounded when you checked for spark? If you just held it in the air you wouldn't see a spark even if it was working.
The dog: 2005 Titan SE CC 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, Roadmaster Active Suspension, SnugTop Sport shell, 5000k HIDs
The fish: 1984 Scarab 21SS - Marine Power 454 - FOR SALE
Yahooligan is offline   Reply With Quote
Old 10-28-2009, 06:13 PM   #5 (permalink)
TitanBlue's Avatar
Cam Shaft Sensor & Crank Shaft Sensor. No Signal would possibly cause No Spark. Common items to go, that prevent an engine from starting. They fail, and don't always give a code.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 10-29-2009, 04:04 AM   #6 (permalink)
[T.J.]'s Avatar
did that. remember i said i put a brand new IPDM in it.
yes the spark plug was grounded.
thank you very much for a decent answer. i had a family member suggest the same thing so i'm gonna price and try these.
also you hit the nail on the head with NO CODE. i didn't mention that but ur right it didn't throw one. would have been nice if it did.
Old 11-01-2009, 05:57 PM   #7 (permalink)
[T.J.]'s Avatar
broke down and had it towed to the dealer before i wasted any more money. turned out to be the key. needed to be reflashed.
04 Won't Start/Crank-Then will Start Later-Happens Occasionally Day-Day Titan Problems & Dealer Service 15 01-27-2009 10:44 PM
Spark Plugs Allybabe_18 Titan Engine, Transmission & Drivetrain 3 11-27-2008 03:13 PM
E 3 spark plug Nissan_Kid Titan General Discussion 5 06-14-2008 07:05 PM
Spark plug INSSAN04 Titan Engine, Transmission & Drivetrain 17 07-12-2007 06:45 PM
