Old 11-05-2009, 10:11 PM   #1 (permalink)
Exclamation Flooded Engine. Need Help!
Ok guys so last Monday I drove my Titan for about 15 miles with the fuel light on to work. When I went to leave for the day it would not start anymore. So I though I had run out of gas. So I put 4 gallons into it and it still would not stats. While trying to turn it on, I kept pumping the gas. Well finally my battery died, Well it seemed like it was low from the beginig. Then I tried to jump start it and that didnt work either. I could hear the fuel pump si that ruled that out. Finally I pulled my spark plugs out and they were soaked in gas. I herar this term is called FLOODED ENGINE. The guy at Auto Zone told me that the only way to get rid of the gas is by putting new plugs in it and keep trying to start it. But that once that happens the plugs will be ruin again. Well it did worj and after a few tries my truck turned on so I drove it home. Then a few hours later I tried to start it again and it would not. This time making a weird noise like it was misfireing. Could this be true?? Do I really need to get plugs for it again or do i have a diffrent problem??? Sorry about the long story but Im just tryin to get good info... Thanks Guys!
diego's titan is offline   Reply With Quote
Old 11-06-2009, 11:11 AM   #2 (permalink)
bagellord's Avatar
Re: Flooded Engine. Need Help!
I would think that the ECU wouldn't let the engine flood. Odd. Are you getting any lights on the dash or codes?
gaycamellovingwhore
2008 Nissan Titan LE Crew Cab
Black/Black Leather
Tow Package
Black Hunter Truck Accessories Brush Guard
Black Undercover Hard Tonneau Cover
iPod adapter
Magnaflow 22" dual in single out muffler
BullyDog Power Pup
5000k HID low beams
Pending:
2 12" RF subs + amp
Wish List:
Cold Air Intake (AEM or Injen or K&N)
bagellord is offline   Reply With Quote
Old 11-06-2009, 04:27 PM   #3 (permalink)
negative. no codes!
Old 11-06-2009, 05:11 PM   #4 (permalink)
adkl1's Avatar
x2 there is no way the computer will keep sending gas to the motor. i would say there is something wrong ... what year is it ? If its under warrenty have it towed to the dealer and dont say anything about it being low on gas...
08 Pro-4x moonroof,Tow,DVD,SWB, Airbox mod, 3" RC Kit,35/12.50 Kumho KL71's ..melting in Chandler, Az
Installed 5100 Bilsteins in the rear & waiting for the fronts to come in !!
adkl1 is offline   Reply With Quote
Old 11-07-2009, 02:20 AM   #5 (permalink)
Unhappy Re: Flooded Engine. Need Help!
its an 06. No warranty!!!!
Old 11-07-2009, 09:13 AM   #6 (permalink)
albonismo's Avatar
06? he should still be covered under the 5yr/60k powertrain warranty shouldn't he?
'06 Smoke XE CC FFV
Mods: AEM Bruteforce Intake, Stillen Dual Rear Exhaust, 2° Timing Advance, 8k HIDs, ReadyLift 2" Leveling, Deaver C-30 pack, Rear Bilsteins, PRG DCBB, LE rims, BFG AT KO 305/65r18, StreetScene One Piece Custom Grill powder-coated black, Color-Matched rear bumper, VHT NightShade painted tail lights, Debadged
Future Mods: UpRev, Nismo headers, Detroit TruTrac, SAWs in front I need new pictures
albonismo is offline   Reply With Quote
Old 11-07-2009, 01:31 PM   #7 (permalink)
flewbyu's Avatar
Something else may be wrong. But if you do have spark, fuel etc.. you can try to start the truck while someone pulls out the fuel pump fuse and wait for it to try and start then put the fuse back in. This worked on an RX8 I was working on. Just make sure the battery has a good charge.
Marcus
2005 Titan LE CC
Air intake mod, Fog light mod, DIY ground wire kit, DDM 8000k lows/fogs, Armada air dam, 34R optima, Black LE wheels, 2* advance
1995 Continental Sold
1988 Mustang 5.0 Turbocharged Sold
flewbyu is offline   Reply With Quote
Old 11-09-2009, 01:36 PM   #8 (permalink)
Red face Re: Flooded Engine. Need Help!
it has been a couple of days now and since then I pulled the plugs out again and they seemed fine. My truck turns on randomly now. Like I can go up to it and turn it on with no problem and go back to it an hour or so later and it fails to start. Another thing that happens now is, it shuts off after a while. It does this while driving it or just ****ing there running. I saw that when I turned the switch to on the check the engine light flashed 5 times. Im thinking thats a code right?? Does anyone know what that would be???
Tags
fuel flooded engine
Flooded!!!!! take a look motorvisions Off-Topic Discussion 13 05-22-2009 10:43 PM
engine flooded and clear flood mode 1roddy Titan Engine, Transmission & Drivetrain 19 01-26-2009 08:02 PM
Flooded? trucksr4gurls Titan Engine, Transmission & Drivetrain 9 06-19-2008 04:20 PM
Flooded Roads = Happy Titan Owner ZeroPt99 Titan General Discussion 22 10-06-2007 03:51 PM
Flooded Titan Hutch Titan Problems & Dealer Service 9 05-08-2005 10:47 PM
