Four wheel drive - Nissan Titan Forum
post #1 of 13 (permalink) Old 12-13-2009, 08:27 AM Thread Starter
iTrader Score: 0 reviews
Four wheel drive
I select fourwheel drive on the switch and it makes a clicking sound when I slow down it stops but wont go in four wheel I checked the actuator and it seems to cycle in and out. Has anyone had this issue.
907 Titan is offline
Advertisement
post #2 of 13 (permalink) Old 12-13-2009, 08:38 AM
Shane06fl's Avatar
iTrader Score: 1 reviews
Re: Four wheel drive
4hi or 4lo???
2005 Titan KC SE ***Sold 9/6/14***
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
2013 Chevy Silverado LT Z71 CC short bed
5.3L LC9 engine
Heavy duty tow package/cooling
4wd
loaded to the gills
mirrors sucks (for now)
2004 Keystone 24RS
Shane06fl is offline
post #3 of 13 (permalink) Old 12-13-2009, 08:40 AM Thread Starter
When I go from two wheel to four wheel Hi makes a clicking sound
post #4 of 13 (permalink) Old 12-13-2009, 09:26 AM
Yahooligan's Avatar
So you're saying when you engage 4Hi you hear a constant clicking noise as you drive, which stops when you stop the truck and, I assume, the clicking noise slows as you slow the truck?
Does the 4WD light come on? What happens with the 4WD diagram next to the odometer? A few clicks are normal to engage 4Hi, but constant clicks are not normal and the 4WD system should indicate a malfunction on the dash.
The new pup: 2007.5 Dodge Ram 3500 MegaCab SLT 4x4 SRW, Inferno Red
The old dog: 2005 Titan SE CC BT 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, RAS, SnugTop Sport shell, 5000k HIDs - SOLD!
The old fish: 1984 Scarab 21SS - Marine Power 454 - SOLD
The new fish: 1998 Seaswirl 170 BR I/O
Yahooligan is offline
post #5 of 13 (permalink) Old 12-13-2009, 09:50 AM Thread Starter
Light comes on everything seems to work just wont go in four wheel my truck only has 25,000 miles on it and as I slow down so does the clicking sound. Indactor light works just wont go in four wheel
post #6 of 13 (permalink) Old 12-13-2009, 09:55 AM
Yahooligan's Avatar
Which indicator light?
One is a 4WD engaged indicator light and another is a 4WD malfunction light. Try to be as specific as possible when describing the problem as well as relaying how you're determining whether or not 4WD is actually engaged. So far your info is pretty vague.
post #7 of 13 (permalink) Old 12-13-2009, 10:05 AM
Shane06fl's Avatar
sounds like your actuator might not be fully engaging. Low fluid or bad actuator could be you culprit. 25K miles you need to visit Nissan
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
5.3L LC9 engine
4wd
loaded to the gills
2004 Keystone 24RS
post #8 of 13 (permalink) Old 12-13-2009, 10:05 AM Thread Starter
Ok the four wheel light comes on but when I give it gas it spins only the rear tires on the ice in Alaska, when I go back into two wheel drive the light goes to two wheel. When going down the road a speed and select four wheel it makes a clicking sound as I slow down so does the clicking sound when I come to a stop it quits and as I speed up in four wheel the sound is not their but I am still in tow wheel cause when I give it more gas only rear tires spin. I have a ! light that came on and dont know what it means.
post #9 of 13 (permalink) Old 12-13-2009, 10:14 AM
Yahooligan's Avatar
"The four wheel light"?
If it's the "4WD" light then that is the malfunction indicator light, this should NOT come on when using 4WD. I just want to make sure we're all clear on what's happening and that it doesn't indicate that you're in 4WD via the diagram when it actually isn't.
If it's the diagram of the axles that lights up the front tires in the diagram then that is your actual 2WD/4WD indicator light.
If you DON'T get the "4WD" light and the diagram DOES indicate 4WD is engaged then your problem is outside of the transfer-case.
Time to visit your dealer in either case since it's apparent you do have a problem, I was trying to isolate where the problem might be but it was difficult since you weren't being very specific in describing the actual lights that come on as there are multiple lights, not just one, related to 4WD.
post #10 of 13 (permalink) Old 12-13-2009, 10:21 AM Thread Starter
Thank you for your help and time! I think it is the acuator that is not engaging all the way I am going to pull it and check the teeth on the grear.
post #11 of 13 (permalink) Old 12-14-2009, 06:58 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
Check your front axles to make sure they are still fully inserted into the differential.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #12 of 13 (permalink) Old 12-16-2009, 09:39 PM
where is the actuator and how can you check it, my "4WD" light comes on when I turn the truck to 4 hi and it does not engage. The 4 wheel diagram dissapears and my 4WD light comes on.
jbarth636 is offline
post #13 of 13 (permalink) Old 12-17-2009, 09:21 PM
Smoke05's Avatar
Mine did this exact thing when I lost the clip to the axle and it wore the diff housing until it leaked. Turn knob, light illuminated like it was in 4wd, heard clicking from under the truck in the transfer case area and only RWD. No error light but the transfer case would not engage as it would get conflicting responses from the front diff. Dealer replaced frond axle only and problem went away.
Smoke05 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
4 wheel drive issue JoeyCrack Titan Problems & Dealer Service 2 10-01-2009 04:41 PM
Four Wheel Drive Bassin Bob Titan Engine, Transmission & Drivetrain 5 08-30-2007 07:04 AM
new 4 wheel drive??? titanical Titan General Discussion 3 02-20-2007 04:18 PM
4 wheel drive moaning Half Shovel Titan Problems & Dealer Service 11 01-26-2005 09:00 AM
4 wheel drive jimcav Titan General Discussion 5 07-26-2004 02:48 PM
You may post new threads
You may post replies
