Old 05-22-2004, 12:26 AM   #31 (permalink)
same here. I had two pieces of plastic fall out of my sunglass holder.
willy is offline   Reply With Quote
Old 05-23-2004, 02:42 AM   #32 (permalink)
byondevl's Avatar
mines crakced also
byondevl is offline   Reply With Quote
Old 05-23-2004, 08:00 AM   #33 (permalink)
Mine is cracked also in the front screw. Took my dealer about a week to get it in. Going in on weds for oil change and replace the console.
nissan3 is offline   Reply With Quote
Old 05-27-2004, 02:38 PM   #34 (permalink)
Overhead Console issue
Thought that I was alone in this issue. I too noticed that my overhead console in the first flip down compartment is cracked and broken at the screw. I brought this issue to my dealer and it is covered under warranty. They have to replace the entire console which according to the service department guys is noted as a map light console in the computers with Nissan. Good to know that Nissan takes care of it's people.
Katdaddy is offline   Reply With Quote
Old 05-27-2004, 04:24 PM   #35 (permalink)
cgoulette's Avatar
I took in my Titan to the dealer for the oil change. I showed them the cracked console, within 4 days the got the part in and replaced it.
They are a pretty good service deparment, what helps is that the Service Manager also purchased a Titan. So he will be experiencing the same problems.
While I was there, I took a look at the pricing for these parts.
The Entire overhead Console, including the map lights (but not the back DVD/Radio Console) is $189.00.
The price for the a Utility Bin (the part that folds down, it's like a box), is about $26.00.
cgoulette is offline   Reply With Quote
Old 06-04-2004, 10:41 PM   #36 (permalink)
JoeyCrack - it might have been me who pointed that out in another thread. My overhead console is going to be replaced when they can get a new unit in.
Good luck all!
dagger is offline   Reply With Quote
Old 06-05-2004, 08:14 PM   #37 (permalink)
NissanTech's Avatar
I noticed mine when I bought it dealer liked to have died. has it ordered.Also small ding in L/S rear door to fix.
NissanTech
07 Titan Crew Cab LE
Majestic Blue 4X2
Big Tow pkg
Nav
NissanTech is offline   Reply With Quote
Old 10-26-2004, 09:46 AM   #38 (permalink)
Masa's Avatar
Replacement Overhead Console Cracked
My cracked overhead console was replaced within the last couple of months. I noticed yesterday that the same spot around the front mounting bolt has many cracks again... I wonder if the plastic material is prone to cracking or the mechanic simply overtightened the bolt again...
'06 White 4x2 CC LE w/ Big Tow & Bench Seat
San Antonio, Texas
Masa is offline   Reply With Quote
Old 10-26-2004, 06:56 PM   #39 (permalink)
rwilso5573's Avatar
Found mine cracked around the front bolt, the very first week. Dealer ordered a new one (took a week to come in). Was replaced the following week.
rwilso5573 is offline   Reply With Quote
Old 10-26-2004, 08:44 PM   #40 (permalink)
Mine was cracked from day one - in the sunglass holder.
Replacement #1 - broken in shipment
#2 - broken during install
#3 - BOYS ! STEP AWAY FROM THE CONSOLE- PUT IT IN THE BACK SEAT! HERE -EAT THESE DOUGHNUTS.
It helps if you put some white grease on the 4 spring tabs,make sure they're in the slots and push up slowly and firmly until they snap in-they need to pop/snap in. Put a dab of clear silicone over the 6 screw holes and finger tight them screws in- that's it - just finger tight.
Born 6/04 Silver LE KC 4x4 Big Tow,Side Air Bags,Mats,SL Extender,SL Divider,Truxedo Low Pro,Nissan XM Sat,Weatherflectors
Stitch is offline   Reply With Quote
Old 09-30-2005, 02:46 PM   #41 (permalink)
Ever had the sunglass console get stuck?
When you push it up, it just clicks and does not come down, so you have to push your finger in and pull it firmly down...so this make it feel like you are certainly going to break something.
I don't believe my sunglasses cause the problem.
bclmread is offline   Reply With Quote
