How To: Fix annoying clicking heater/ac actuator under dash (w/pics) - Page 10 - Nissan Titan Forum
Old 10-30-2012, 05:18 AM   #136 (permalink)
titanss's Avatar
iTrader Score: 4 reviews
Re: How To: Fix annoying clicking heater/ac actuator under dash (w/pics)
Where is the noise coming from? Above the radio or down by your feet?
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
N/A Tuned Non Cammed: 13.180@102.31mph
TG, S & Box Drop: 13.414@101.74mph
04 XE Mod List
07 Pipes w/ 22" M/F Sound Clip
Advertisement
Old 11-07-2012, 10:19 AM   #137 (permalink)
afdude2018's Avatar
iTrader Score: 3 reviews
Thanks for this thread. Only problem is all of the part number floating around make it very confusing as to which part number is the correct one.
27743-ZS00A is no longer available from Nissan NA according to Courtesy Parts. This seems to be a new development as I saw post from people from as recently as a month or two ago that were able to get this part.
27743-ZP00A is the replacement for this part.
Both of those are for the upper actuator.
27743-ZH00A is for the lower actuator that is right behind the kick panel.
I know this info is posted somewhere in the middle of this thread, but it was in multiple posts with people posting conflicting info which made it confusing as to which part people were talking about. Figured I'd post this info so people don't have to go digging through the thread to find it.
2010 Red Alert Pro-4x CC
afdude2018 is offline   Reply With Quote
Old 11-08-2012, 12:23 PM   #138 (permalink)
titanss's Avatar
The 27743-ZP00A is the correct actuator for the Air Mix. Yes the whole dash has to be removed to access it. It took me about 4 hours to complete the R&R. Cost about $25 at the dealer.
2004 XE KC
04 XE Mod List
Old 11-11-2012, 03:14 AM   #139 (permalink)
DestroyedIndustries's Avatar
Originally Posted by EseLoco918 View Post
If by "one click" you mean clicking six thousand times, sometimes for no reason, then yes.
Bwahahahhahaa...nice.
(phasing signals >= 10 seconds) ZCZC FE01
(transmission received - location: otherside of nowhere)NNNN
Sig Pic size violation
DestroyedIndustries is offline   Reply With Quote
Old 11-11-2012, 04:08 AM   #140 (permalink)
iTrader Score: 0 reviews
Nice
Sent from my iPhone using Autoguide.com Free App
jpizzle856 is offline   Reply With Quote
Old 12-06-2012, 01:03 PM   #141 (permalink)
afdude2018's Avatar
I've got my new actuator. Just need to find the motivation to tear into my truck to fix this. Going to be fun since I have the Rockford Fosgate system.
Old 12-06-2012, 01:27 PM   #142 (permalink)
iTrader Score: 1 reviews
I read this thread, researched online, and found the following. The below is true for my '06 CC 4x4:
Part 27743-ZH10A -- This actuator is for the fresh air/recirc air actuator. It is also referred to as the "Intake Door Motor". It is high inside the dash (near the middle) on the passenger side. The manual says to remove the heating and cooling unit assembly to replace ($$$). I also see part 27743-5Z010 listed for some applications.
Part 27743-ZP00A -- There are two of these on my truck. One is the "Defroster Door Motor", which opens/shuts that door. It is located high inside the dash (near the middle) on the drivers side. You can get to this one using the write-up on page 1. The other actuator is referred to as "Air Mix Door Motor". This one controls the temperature of the air. It is located on top of the heating and cooling unit behind the glove box. The manual says to remove the heating and cooling unit assembly to replace ($$$).
Part 27743-ZH00A-- This actuator is for the floor vent. It is also referred to it as the "Mode Door Motor". It is located on the lower drivers side of the heating and cooling unit assembly. This one is the easiest to change.
I am going to attempt to pull the dash and replace all of them. Although the manual says to pull the dash AND the heater and cooling assembly, I bet I can snake my hands in there to get to them (based on a flashlight inspection last night -- will look again today).
My Air Mix Door Motor is not working correctly and only gives me heat. It pops and clicks when I get too close to the cold mark on the dial. My Intake Door Motor doesn't do anything. My Defroster Door Motor works, but clicks like a son of a B. My Mode Door Motor actually works without a problem, but it's getting swapped out too (of course the one that is ok is the easiest to get to!).
Nissan changed some of these parts (and numbers), so thought I would update with a little info based on what I have found so far. I hope it helps others with similar issues. I will post a write-up if I decide to rip it apart.
GT3 Tim is offline   Reply With Quote
The Following User Says Thank You to GT3 Tim For This Useful Post:
george3111987 (01-14-2013)
Old 12-07-2012, 09:10 AM   #143 (permalink)
titanss's Avatar
My 04 called for the 27743-ZP00A for the Air Mix, Hot to Cold, accuator. The heater box does not need to be removed to change it, but the whole dash has to be removed to get to it.
2004 XE KC
04 XE Mod List
Old 12-27-2012, 12:56 PM   #144 (permalink)
Anyone know why my truck wouldn't be getting heat I read the threads and checked the water valve at the firewall and its not hot from either side which doesn't make since. I checked coolant level and its good and I know one of the actuator's are bad on my truck since I hear clicking noise but all the modes and defrost work so I assume its the air mix door that requires tearing out the dash. But why is there no heat going into the heater core or at the hoses on either side. Can anyone help me. I bought used and never check the heater and its never worked. 2006 Titan 4WD Crew Cab. Thanks for any suggestions.
trivo is offline   Reply With Quote
Old 12-29-2012, 10:39 AM   #145 (permalink)
you guys must be midgets or something cause I cant find a way to place myself so that I can get to that lower box.
303Titanstatus is online now   Reply With Quote
Old 12-29-2012, 08:04 PM   #146 (permalink)
So which one do I need? lol (or maybe two at this point)
My truck has had this problem since I bought it. When you first cut anything on.. it clicks.. About 2 minutes after you cut it off it clicks again.
Playing with it tonight.. (And I just leave it on vents most of the time so I haven't noticed this) Vents only... turns a bit then clicks.. feet only.. no clicks.. Mix between the two clicks.. Feet and defrost.. no clicks.
Please tell me its only 1.. and its the easy to get to one. lol please?
10' SE Smoke Metallic CC SWB 4x4
MississippiT is offline   Reply With Quote
Old 12-31-2012, 02:17 PM   #147 (permalink)
Taz
Iv'e seen several posts about the actuators but what I haven't seen are clear understandings of what each one controls. I assume each one has a specific control function and would really appreciate it if someone could post them. My issue is I don't get air flow to my feet. When I look at the actuator located above the gas pedal and turn on the key the lower flap closes then opens then the upper closes and stays closed. Any feedback would be much appreciated.
Taz is offline   Reply With Quote
Old 01-01-2013, 07:16 PM   #148 (permalink)
I checked the valve in the engine bay. Both tubes are hot past the valve. It was the actuator that was bad which controls the temperature door and the actuator that controls the air flow from vent to defrost. The heater actuator still has problems after installing the new one. It works, but it turns to far. I can get heat though. The other actuator that is above the driver side right foot had a broken gear inside. It was not the lower of the two, but the upper one. I replaced with a new one. That did not fix the problem the doors would not move. I pulled it out, plugged it in. Immediately it started rotating 360 degrees and would not stop. I unplugged it and then plugged it back in. It rotated the opposite direction going 360 degrees. After unplugging and plugging in it finally stopped. It reacted to the controls when I changed the control. It was 180 degrees out though. Mind you both of the actuators were purchased new at the DS on Dec 31st. I am not sure were to go from here now. Is there a way to calibrate the actuators?
Thatsgr8 is offline   Reply With Quote
Old 01-12-2013, 04:56 PM   #149 (permalink)
Thought it wise to post my experience with my 2005 Titan. I have been having the annoying clicking for quite some time now. Finally, the clicking stopped (yeah!), but in return, I lost air to the defrost vents. To answer everyone's questions, THERE ARE 3 HVAC ACTUATORS (at least on the 2005 model).
One is the BLEND ACTUATOR that opens and closes the door to control cold and hot. You will know that this one needs to be replaced when you have either hot or cold, but the door is stuck so that you can not have both. For this one, you need to remove the entire dash. It is found to the upper right of the center consul. I read in a post that you can access this actuator by only removing the glove box. While it may be possible, you would have to have a 2" dia arm that is 18-24" long. On top of that, you would need to do the replacement blind as you cannot see it. Point is, you need to remove the entire dash.
Another one is the LOWER MODE ACTUATOR that opens and closes the door to control the dash vents and the floor vents. You will know that this one needs to be replaced when you can use the defrost vent and either the dash or the floor vents. You will not be able to use both the dash and the floor, as the door will be stuck keeping one or the other closed. It is found just to the right of the gas pedal. You access it by removing the small left cover of the center consul (snaps right off). It is easy to access and easy to replace.
The final one is the UPPER MODE ACTUATOR that opens and closes the door to control the dash vents and the defrost vents. You will know that this one needs to be replaced when you either cannot get air through the defrost vents or the dash vents continue to blow when you have your knob turned to floor/defrost only. This one can be accessed by removing the dash panel just under the steering wheel. The actuator is located just above the gas pedal. It is difficult to get to, but with patience, a small 9/32" combination wrench, a 1/4" ratchet with a 7/32" and a 9/32" socket, you can get it out and back in. There are 3 screws. For some reason, on my truck, the two bottom screws were 9/32" and the top screw was 7/32". Chances are, after removing the actuator, the white half-circle cam plate may fall loose. You will need to realign it. When you get your new actuator ($32), you will find that the grooves may not line up. If this is the case, before you put the actuator up to the cam plate, plug in the actuator, turn on the key, and turn on the air. You will find that the actuator will begin to turn. When it does, turn off the air, but do not turn off the key. If the grooves line up, screw in the actuator. If it does not line up, turn the air back on and off until it rotates so the grooves line up. I was able to get it to line up on the first try.
Good luck, and please let me know if you have any questions.
Joshua is offline   Reply With Quote
The Following User Says Thank You to Joshua For This Useful Post:
Old 01-19-2013, 12:38 PM   #150 (permalink)
iTrader Score: 2 reviews
I've now done this twice, so I figured I should post up some pictures that might help someone else out. It's kind of a pain, but not all that bad once you figure out what you are doing. Getting the factory amp out of the way makes replacing the actuator much easier. I couldn't figure it out the first time I did this. I also purchased the wrong actuator, so I just took the old one out and left it that way. My defrost didn't work all that well, so I decided to get back under there and finally replace the actuator.
Here's how I replaced the actuator. My truck is a 2006 LE with NAV and the rockford fosgate system
1. Remove the front seat by removing the trim pieces and the four 14mm bolts. Mine also had 3 harnesses connected underneath.
2. Remove factory sub
3. Unbolt gas pedal by removing three 12mm nuts.
I threw a pillow down there the driver's seat was and did the rest of this with my head under the dash and my feet hanging out the driver's side door. I had a decent sized work light laying in the floor beside me to get some light under there.
4. Remove the two 10mm bolts holding the black box in, then disconnect the three wiring harnesses and set the black box off to the side.
5. Remove the three or four 10mm bolts holding the amp in place then disconnect the two wiring harness on the amp.
6. Getting the amp out is the trickiest part. You need to push it up and towards the driver's side of the truck to get it off the rails. It's a really tight fit, but it will go. This is how it will look off the rails. Sorry for the blurry pic.
7. Remove the amp. You may have to disconnect a few more wiring harnesses that are in the way and slide the gas pedal around. Here's what that thing looks like when you finally get it out.
8. You should have easy access to the actuator now. There are two 9/32 screws and one 7/32. The wiring harness is on the top of the actuator. I had to use an open ended wrench on one of the screws because the amp rail was in the way.
9. I ran my truck for several months with no actuator in place. In that time, the white piece that the actuator gears go into had come out of place. I removed the two 7/32 screws that are just below the actuator for better access. You can see one of them in the bottom left of the above pic. I also unplugged the lower actuator because its wires are attached to the piece I needed to move. Here's what it looks like.
10. It took me a while to figure out how to get the white piece lined up because it actually controls two levers. After getting the greasy white piece back in place and the two levers on track, replace the black piece that covers it and insert the two 7/32 screws.
11. Now you need to get the gears on the actuator turned the right way, so that it will line up with the gears on the white piece. Look at the gears on the white piece and figure out where the keyed piece needs to be on the actuator to get it in there. I had to plug in the black box from step 4 to get the truck to turn on. I then plugged in the actuator and turned the key. When the actuator got where I wanted it, I disconnected the actuator wiring harness and turned the truck off. If you just turn the truck off, the actuator will sometimes keep spinning. I then mounted the actuator by replacing the 3 screws, then plugged its wiring harness back in.
12. Replace the amp, black box, gas pedal, and any other wiring harnesses you had to disconnect.
13. Replace the sub then the front seat.
14. Your airbag light will probably be on, so you will need to go through the procedure outlined here to get it off.
Air bag light?
This took me about 2 hours this time. I think I could get it done in an hour and a half or so if I had to do it again. Getting that amp out of the way makes it much, much easier to get to the actuator.
JRW160 is offline   Reply With Quote
The Following 2 Users Say Thank You to JRW160 For This Useful Post:
AcidJake75 (04-02-2013), chadp82 (01-19-2013)
Advertisement
ac/heater vent clicking noise mudfinder Titan Problems & Dealer Service 21 12-06-2012 01:04 PM
Clicking in heater ductwork Ralfus Titan Interior Discussion 5 02-01-2010 06:23 AM
heater just died - actuator questions core2 Titan Problems & Dealer Service 1 01-20-2010 04:21 PM
I've got a Fix for the annoying Door Chime 04TexasTitan Titan Interior Discussion 4 02-15-2005 07:13 PM
SEO by vBSEO 3.3.2
