2006 Titan, no 4WD, ABS Light on - Nissan Titan Forum
post #1 of 7 (permalink) Old 02-28-2010, 06:45 PM Thread Starter
iTrader Score: 0 reviews
I'm not noticing any issues with the truck, but my ABS light has come on this past week. At first it would only be on every once in awhile when starting the truck, but it's constant now.
What is the common issue with the ABS light coming on, what should I check?
FatherChristmas is offline
Advertisement
post #2 of 7 (permalink) Old 02-28-2010, 08:48 PM
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: 2006 Titan, no 4WD, ABS Light on
I would check to see if any of the ABS sensors are damage
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #3 of 7 (permalink) Old 03-01-2010, 03:36 AM Thread Starter
Ok, how can I go about doing that? Looking for physical damage, or using a tool to test for internal damage or what?
post #4 of 7 (permalink) Old 03-01-2010, 04:23 AM
NBhunter80's Avatar
Look for one that is physically damaged or torn out, and if they all look good, make a trip to the dealers and they will check the sensors. Quite a few members have damaged their sensors and had this exact issue. If it's just the sensor, it should be a cheap and easy fix. Good luck!
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #5 of 7 (permalink) Old 11-03-2010, 11:39 PM
nucleargary's Avatar
Where are the sensors located?
nucleargary is offline
post #6 of 7 (permalink) Old 11-04-2010, 06:31 AM
AZPRO4X's Avatar
iTrader Score: 8 reviews
Next to the brakes on the axles.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline
post #7 of 7 (permalink) Old 11-04-2010, 07:30 AM
NBhunter80's Avatar
The sensor wire for the front brakes is clipped onto the spindle next to the brake caliper mounting bracket.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
SLIP LIGHT> ABS LIGHT> Check Engine Light????? Cricket7 Titan General Discussion 25 05-07-2016 06:44 AM
abs and slip light, no 4wd Kutsuju Titan Problems & Dealer Service 2 01-22-2010 07:24 AM
FS: 2006 Titan SE KC 4WD in PA 1-3-2-4 Buy/Sell 7 07-03-2009 08:26 AM
2006 Titan Crew Cab 4WD - SALE blackberry farm Buy/Sell 7 11-17-2008 06:08 AM
Lowering kit for 2006 nissan titan w/ 4wd?? TiTan23 Titan Suspension 11 03-19-2007 11:51 AM
You may post new threads
You may post replies
