2005 titan will crank but not start - Nissan Titan Forum
Old 03-15-2010, 11:54 AM   #1 (permalink)
iTrader Score: 0 reviews
hi,
my truck had been running ok w/ the exception of the o2 sensors spitting out a code.
after parking the truck, it won't start back up. it cranks and cranks but will not start. It has a new battery so that is not it.
there are no codes to be read (keeps spitting 0000).
There is gas in the tank (7 gallons).
how can you know if it is a failed fuel filter or fuel pump? how can you know if it is a failed computer?
will using a starter spray (spray fule through the air filter opening) can help in troubleshooting?
Please advise?
thanks in advance,
jvaldez_32@hotmail.com
jvmagic is offline   Reply With Quote
Advertisement
Old 03-15-2010, 01:34 PM   #2 (permalink)
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: 2005 titan will crank but not start
Sound like ipdm problem. Try swapping relay with the fog light relay.
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
Old 03-16-2010, 05:56 AM   #3 (permalink)
It could be a fuel filter but it sounds like an IPDM failure. My 04 did the same thing. I switched relays with the fog lights and have never had another problem. My dealer was no help; found the solution on Titantalk.
Abi24 is offline   Reply With Quote
Old 03-16-2010, 05:22 PM   #4 (permalink)
Hi,
I have ran a quick IPDM test (according to this website) and the truck's horn goes off as well as the wipers coming on. Supposedly this means it is running normal right?
Should I switch the IPDM anyway?
thanks again,
Old 03-16-2010, 08:21 PM   #5 (permalink)
iTrader Score: 4 reviews
Not sure what the horn & wipers have to do with a failed ECU relay.
Old 03-19-2010, 04:44 PM   #6 (permalink)
Just got my titans from the nissans deal with the same problem. The IPDM was going bad. I has the extended warranty on my truck and they change it under the warranty.
goldwings is offline   Reply With Quote
Old 03-22-2010, 11:37 AM   #7 (permalink)
hi goldwings,
my truck will start on say Monday but not Tuesday and then start right up on Wednesday. Is this the same thing you were experiencing?
how can I confirm if it is the IPDM?
thanks again,
~jv
Old 03-22-2010, 11:46 AM   #8 (permalink)
NBhunter80's Avatar
Swap the ecm relay with the fog lamp relay. If your truck fires right up, then replace the IPDM. Here's a diagram so you know which relays to swap. Good luck!
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, 33x12.50r17LT Hercules Trail Digger tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, Hawk LTS brake pads, MOOG lower ball joints, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline   Reply With Quote
Old 12-19-2012, 10:21 AM   #9 (permalink)
Hello all, I have the same problem. It started happening when it got cold. Would crank fine but no start in the morning after cold night. Then would start fine in the afternoon. Well now it won't start at all. I switched the relays in the ipdm but no change. It's an 08, any suggestions?
mountainsp is offline   Reply With Quote
Advertisement
04 Won't Start/Crank-Then will Start Later-Happens Occasionally Day-Day Titan Problems & Dealer Service 22 11-18-2011 06:28 AM
no crank no start outsyderz1987 Titan Engine, Transmission & Drivetrain 0 10-26-2009 05:04 PM
crank pulley 08 4door Titan Performance Modifications 6 07-20-2008 05:12 PM
FS: UD Crank Pulley SmokedTiresITAN Buy/Sell 12 06-15-2008 10:23 PM
Crank Pulley dawgs77 Titan General Discussion 6 12-19-2007 05:50 PM
SEO by vBSEO 3.3.2
