Utility bed storage door loose
I noticed yesterday, while getting something out of my "Driver's Side Lockbox," that three of the four bolts holding the door to the hinge were loose. Any of you guys/gals with the Utility bed pack should check for this "minor problem" before the bolts come out and you drag the door down the road.  Not really, the lock mechanism will hold it until you open it and it falls to the ground.
Bryan  In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab 280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004 Red Brawn--Graphite/Titanium Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs, Tech12Volt Enclosure, TechTubes Polished SS Step Rails, OEM Fog Lights, OEM Bug Deflector, ARE LSII Hard Tonneau Cover, Black Stubby Antenna, Volant CAI, AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's, 265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1" Rear Blocks, LED's Front, Eagle Eyes LED Tails, JDM 6000K HID Lows & Fogs, SilverStar Halogen High-beams, LED Third Brake Light, Red Billet Aluminum Oil Cap, Red Active Tuning Grounding Kit, Body Colored Front Spoiler, 2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
