WHERE EXACTLY is the blower motor resistor?! - Nissan Titan Forum
Old 03-24-2010, 09:51 PM   #1 (permalink)
iTrader Score: 0 reviews
Exclamation WHERE EXACTLY is the blower motor resistor?!
Can someone please tell me where the blower motor resistor is located on a 2005 Nissan Titan? I have taken apart the right side of the dash and can't find it to save my life.
I've located what I think is the VBC, but can't find the resistor. The dealer says that the problem is most likely the resistor, but I can't find it! Does the 2005 Titan even have a resistor - or is everything contained in the VBC?!
The part on the left is what I can locate on my Titan. The part on the right is what the dealer insisted I buy.
Thanks,
Kevin
kevink619 is offline   Reply With Quote
Advertisement
Old 03-27-2010, 02:11 PM   #2 (permalink)
titanmike's Avatar
Re: WHERE EXACTLY is the blower motor resistor?!
I was about to go look for mine as well. I need to order the part so i can get my fan back to working normal. I didn't know there were two different parts. I thought it was the one with the fins that needs changed out.
04 SE KC. BT OR 140,000 miles.
06 LE KC. BT 83,000miles. S&B Intake. 22" magnaflow muffler. Bully Dog Power Pup. Truetrac, rear fog lights. 2.5" leveling kit. Air Lift airbags. Back up camera. 18x8.5 Viscera 506's w/ 325-60-18 Nitto Terra Grappler A/T's. Bushwacker fender flares color matched. 6000 hid low beams and fog lights.
titanmike is offline   Reply With Quote
Old 03-27-2010, 02:40 PM   #3 (permalink)
sblbdr's Avatar
iTrader Score: 2 reviews
Directly under the glovebox you will see the plug. Its either a 3 or 5 fin resistor. There is a Nissan bulletin which updates to the new 5 fin.
04 CC Long travel
sblbdr is offline   Reply With Quote
Old 03-27-2010, 05:02 PM   #4 (permalink)
titanmike's Avatar
I just looked at mine and unless i'm blind I don't have that part under there anywhere. I have the same thing as the other guy posted in the thread under this.
I Also have this. This clicks when you turn on and off the fan switch so i assume it has something to do with it. But neither part has a plug like the one listed as the part to buy. This is on my 06 le with dual climate control if that matters.
Old 03-27-2010, 09:19 PM   #5 (permalink)
vertigo72480's Avatar
Had to do this with my g/f's old Chevy Cavalier and my '99 Sentra. The resistor card is usually near the motor itself. Not sure on the T as I haven't had to take mine apart, but in your pictures titanmike, the first picture looks like a 10 amp resistor that most likely has nothing to do with the blower motor and the second picture is of a relay that probably controls the on off function of the blower system. neither of these is what you are looking for and if they work I would suggest you leave them alone.
Check out this link as it has an exploded diagram of parts placements: 270 Heater & Blower Unit :: Body Electrical :: Genuine Nissan Parts :: Titan Parts (A60) 2004-2010 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
This piece is probably mounted to the firewall in a housing to protect it.
vertigo72480 is offline   Reply With Quote
Old 03-27-2010, 10:58 PM   #6 (permalink)
titanmike's Avatar
I looked again and the parts that its showing do not look the same as what i actually have behind the glove box.
Old 11-17-2010, 12:39 PM   #7 (permalink)
I am having the same problem the dealer gave me the card looking thing to the right and all i can find is the componet on the left
sodmaster is offline   Reply With Quote
Advertisement
a/c blower motor changing speed on it's own. HavaTITAN Titan General Discussion 20 08-25-2009 12:20 PM
Gutless Blower Motor UtahJim Titan Problems & Dealer Service 5 08-22-2009 10:17 AM
Changed out A/C blower motor today(with pics) FLfinfan Titan FAQ & Howto Area 9 06-20-2009 07:06 AM
Heater blower motor question. FLfinfan Titan General Discussion 1 11-21-2008 02:44 PM
Blower motor HudsonValleyTitan Titan General Discussion 17 04-21-2006 03:06 PM
SEO by vBSEO 3.3.2
