Old 05-15-2004, 09:29 AM   #1 (permalink)
Drive Train "Clunk" Survey
For all of those experiencing the drive train "clunk" I have a couple of questions. First, I would like you to confirm that the clunk is not caused by utili-track covers sliding back and forth or by cleats stored in the utility bed side box. Assuming you have eliminated the possible extraneous causes:
At what mileage on the odometer did you first begint to experience the clunk?
Do you have a 2WD or 4WD truck?
Thanks in advance to all responders.
Old 05-15-2004, 03:03 PM   #2 (permalink)
goathead's Avatar
one thing to think about that i discovered by reading the owners manual is that if you have the VDC it actually is supposed to make a clunk sound when you first start the vehicle and put it into gear (forward or reverse). now, conversly, if this happens at every stop light, thats not normal. just look up VDC in owners manual for more info if this is the possible problem.
steve
steve
Old 05-15-2004, 03:05 PM   #3 (permalink)
Send a message via AIM to TIGHTIN
1. I do not have the utili-track.
2. It has always done it, I made the assumption it was "normal"
3. 2WD
Colin
04' KC Popular w/RF, Truxedo Lo Profile, Deepwater "Blue",
TIGHTIN is offline   Reply With Quote
Old 05-15-2004, 04:51 PM   #4 (permalink)
I do not have the Utilitrak.
It started at about 4k miles.
Mine is a 2WD CC XE.
Thanks Al
althepa is offline   Reply With Quote
