Re: ECM Replaced
There have been ECM (ECU) Failures. Cost is what I'd expect for a replacement. Big chunk of change for sure. I'd ask them what points to the ECM being bad, as opposed to an ECU Relay or IPDM Failure, which is far more common.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
MD Chapter Director
